Wieschie 0 Posted ... I cannot stay connected to AirVPN for very long. Initially I have no problem connecting, but after a short while (generally under 10 minutes) my client disconnects and tries to reconnect but fails. If I close the client I can't get internet access on my local network either - I have to restart my computer to get any internet access at all. I am running the 1.7 AirVPN client on Windows 7 64 bit. This problem occurs on all servers. Quote Share this post Link to post
Staff 10488 Posted ... I cannot stay connected to AirVPN for very long.Initially I have no problem connecting, but after a short while (generally under 10 minutes) my client disconnects and tries to reconnect but fails. If I close the client I can't get internet access on my local network either - I have to restart my computer to get any internet access at all.I am running the 1.7 AirVPN client on Windows 7 64 bit. This problem occurs on all servers.Hello!If a disconnection occurs, OpenVPN re-establishes the previous routing table and tries immediately to perform a new connection. The fact that you have to reboot might suggest that you have some crash in your system, especially considering the fact that nothing in our servers pushed routes affects your local network (unless you have a conflicting network in 10.4.0.0 -> 10.9.255.255). Can you please send us the Air client logs? Also, it's worth trying a connection to a TCP port (if you did not try it yet) in order to check whether it mitigates the problem.Kind regards Quote Share this post Link to post
Wieschie 0 Posted ... I will reconnect and post the logs when I get the error. Is it possible to connect with TCP via the client or do I need to use openvpn? Quote Share this post Link to post
Wieschie 0 Posted ... I have been connected for 4 hours without trouble. This is the only time I have not tried to torrent while connected. Tomorrow I will experiment more with UTorrent (v3.2) and see if that's involved in the problems. Quote Share this post Link to post
Staff 10488 Posted ... I will reconnect and post the logs when I get the error. Is it possible to connect with TCP via the client or do I need to use openvpn?Hello!With the Air client, you can select the connection port in the "Modes" tab.Kind regards Quote Share this post Link to post
Wieschie 0 Posted ... Here are the logs from both udp and tcp connections (sadly tcp had a similar problem). TCP: http://pastebin.com/raw.php?i=FxNc81PM UDP: http://pastebin.com/raw.php?i=6Jn1QLyf Quote Share this post Link to post
Staff 10488 Posted ... Here are the logs from both udp and tcp connections (sadly tcp had a similar problem).TCP: http://pastebin.com/raw.php?i=FxNc81PMUDP: http://pastebin.com/raw.php?i=6Jn1QLyfHello!None of the logs you linked pertains to TCP connections, they both show Vega / 443 UDP connections. While the second linked log shows problem in your connectivity, the first log is just fine, it shows that you could stay connected for hours, from 10:45 AM till 2:09 PM (the TLS renegotiation is ok, it happens every hour for additional security, with overlapping windows in order to cause no delays or latency). So the problem appears to be inconstant.Can you please try a connection to a TCP port to make a comparison?Kind regards Quote Share this post Link to post
Wieschie 0 Posted ... I'm not sure what happened the first time I tried tcp but it seems to be working well now. Thanks, and sorry for the trouble Quote Share this post Link to post
