gladde
Howto build eddie-cli for ARMv6?
I want to use the eddie-cli client on a raspberry pi zero, but the download for eddie-cli linux arm potable is built for ARMv7 (Raspberry Pi 2 3 3+).
Therefore I got the code from GitHub and followed the guide to build the code. But it seems it doesn't try to build the ARM versions of eddy-cli.
Can anyone explain how I could build the ARM version of eddie-cli?
Thanks!
Well I have solved this problem myself
I first installed mono on the raspberry pi zero:
sudo apt-get install mono-complete
Then I downloaded the linux ARMv7 portable mono cli client (eddie-cli_2.16.3_linux_armhf_mono.tar.gz)
I removed the ARMv7 executables and replaced them with the ARMv6 versions. Getting the ARMv6 versions with apt-get:
sudo apt-get install openvpn stunnel
I also removed the start executable "eddie-cli" and added "eddie-cli.sh" bash script:
#!/bin/bash
mono Eddie-CLI.exe "$@"
The only difference is that you need to use "eddie-cli.sh". But it works!
Here you can download the file with all "patched" eddie-cli_2.16.3_linux_armv6_mono.tar.gz
If you would like to autostart the client when your raspberry pi starts you can setup a service to do so. It is described in this post https://airvpn.org/topic/26171-running-eddie-as-a-service-on-a-raspberry-pi-osmc/
Cheers,
Gladde
