Not connected, Your IP: 216.73.216.139
Pretty much what the title says. Running Debian sid with Eddie, connected to a bunch of servers with default settings and nothing seems to get it up. Any idea? Do you want me to send logs?
Logs are usually always help. From top to bottom, in spoilers.
Are you torrenting? If so, remember to port-forward. It depends what scenario you're looking at speed in .
here you go:
. 2018.12.26 22:02:21 - Eddie version: 2.17.2 / linux_x64, System: Linux, Name: Debian GNU/Linux buster/sid \n \l[?12l[?25h, Version: Linux [redacted] 4.18.0-3-amd64 #1 SMP Debian 4.18.20-2 (2018-11-23) x86_64 GNU/Linux, Mono/.Net: 4.6.2 (Debian 4.6.2.7+dfsg-2); Framework: v4.0.30319
. 2018.12.26 22:02:21 - Reading options from /home/[redacted]/.airvpn/default.xml
. 2018.12.26 22:02:22 - Command line arguments (5): path="/home/[redacted]/.airvpn" path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" console.mode="none" linux.dbus="unix:path=/run/user/1000/bus"
. 2018.12.26 22:02:22 - Profile path: /home/[redacted]/.airvpn/default.xml
. 2018.12.26 22:02:23 - OpenVPN Driver - Found, /dev/net/tun
. 2018.12.26 22:02:23 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.1a 20 Nov 2018, LZO 2.10 (/usr/sbin/openvpn)
. 2018.12.26 22:02:23 - SSH - Version: OpenSSH_7.9p1 Debian-4, OpenSSL 1.1.1a 20 Nov 2018 (/usr/bin/ssh)
. 2018.12.26 22:02:23 - SSL - Version: stunnel 5.50 (/usr/bin/stunnel4)
. 2018.12.26 22:02:23 - curl - Version: 7.62.0 (/usr/bin/curl)
. 2018.12.26 22:02:23 - Certification Authorities: /usr/share/eddie-ui/cacert.pem
I 2018.12.26 22:02:23 - Ready
. 2018.12.26 22:02:26 - Collect information about AirVPN completed
I 2018.12.26 22:06:09 - Session starting.
I 2018.12.26 22:06:09 - Checking authorization ...
! 2018.12.26 22:06:10 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2018.12.26 22:06:10 - OpenVPN > OpenVPN 2.4.6 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jul 30 2018
. 2018.12.26 22:06:10 - OpenVPN > library versions: OpenSSL 1.1.1a 20 Nov 2018, LZO 2.10
. 2018.12.26 22:06:10 - Connection to OpenVPN Management Interface
. 2018.12.26 22:06:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.12.26 22:06:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.12.26 22:06:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.12.26 22:06:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.12.26 22:06:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.12.26 22:06:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.205:443
. 2018.12.26 22:06:10 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984]
. 2018.12.26 22:06:10 - OpenVPN > UDP link local: (not bound)
. 2018.12.26 22:06:10 - OpenVPN > UDP link remote: [AF_INET]184.75.223.205:443
. 2018.12.26 22:06:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.12.26 22:06:10 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.205:443, sid=d06c4e55 fc28c96a
. 2018.12.26 22:06:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.12.26 22:06:11 - OpenVPN > VERIFY KU OK
. 2018.12.26 22:06:11 - OpenVPN > Validating certificate extended key usage
. 2018.12.26 22:06:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.12.26 22:06:11 - OpenVPN > VERIFY EKU OK
. 2018.12.26 22:06:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tyl, emailAddress=info@airvpn.org
. 2018.12.26 22:06:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.12.26 22:06:11 - OpenVPN > [Tyl] Peer Connection Initiated with [AF_INET]184.75.223.205:443
. 2018.12.26 22:06:12 - OpenVPN > SENT CONTROL [Tyl]: 'PUSH_REQUEST' (status=1)
. 2018.12.26 22:06:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.210.1,dhcp-option DNS6 fde6:7a:7d20:1bd2::1,tun-ipv6,route-gateway 10.31.210.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1bd2::1060/64 fde6:7a:7d20:1bd2::1,ifconfig 10.31.210.98 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2018.12.26 22:06:13 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.12.26 22:06:13 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.12.26 22:06:13 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.12.26 22:06:13 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.12.26 22:06:13 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.12.26 22:06:13 - OpenVPN > ROUTE_GATEWAY 192.168.86.1/255.255.255.0 IFACE=wlp3s0 HWADDR=74:df:bf:9c:72:89
. 2018.12.26 22:06:13 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.12.26 22:06:13 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.12.26 22:06:13 - OpenVPN > TUN/TAP device tun0 opened
. 2018.12.26 22:06:13 - OpenVPN > TUN/TAP TX queue length set to 100
. 2018.12.26 22:06:13 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.12.26 22:06:13 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2018.12.26 22:06:13 - OpenVPN > /sbin/ip addr add dev tun0 10.31.210.98/24 broadcast 10.31.210.255
. 2018.12.26 22:06:13 - OpenVPN > /sbin/ip -6 addr add fde6:7a:7d20:1bd2::1060/64 dev tun0
. 2018.12.26 22:06:19 - OpenVPN > /sbin/ip route add 184.75.223.205/32 via 192.168.86.1
. 2018.12.26 22:06:19 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.31.210.1
. 2018.12.26 22:06:19 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.31.210.1
. 2018.12.26 22:06:19 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1bd2::1 metric -1) dev tun0
. 2018.12.26 22:06:19 - OpenVPN > /sbin/ip -6 route add ::/3 dev tun0
. 2018.12.26 22:06:19 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1bd2::1 metric -1) dev tun0
. 2018.12.26 22:06:19 - OpenVPN > /sbin/ip -6 route add 2000::/4 dev tun0
. 2018.12.26 22:06:19 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1bd2::1 metric -1) dev tun0
. 2018.12.26 22:06:19 - OpenVPN > /sbin/ip -6 route add 3000::/4 dev tun0
. 2018.12.26 22:06:19 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1bd2::1 metric -1) dev tun0
. 2018.12.26 22:06:19 - OpenVPN > /sbin/ip -6 route add fc00::/7 dev tun0
. 2018.12.26 22:06:19 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2018.12.26 22:06:19 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2018.12.26 22:06:19 - Routes, added a new route, 184.75.223.203 for gateway 10.31.210.1
. 2018.12.26 22:06:19 - Routes, added a new route, 2606:6080:1002:5:a1ba:b510:7908:829e for gateway fde6:7a:7d20:1bd2::1
. 2018.12.26 22:06:19 - Flushing DNS
I 2018.12.26 22:06:20 - Checking route IPv4
I 2018.12.26 22:06:21 - Checking route IPv6
I 2018.12.26 22:06:23 - Checking DNS
! 2018.12.26 22:06:24 - Connected.
. 2018.12.26 22:06:24 - OpenVPN > Initialization Sequence Completed
! 2018.12.26 22:08:47 - Disconnecting
. 2018.12.26 22:08:47 - Routes, removed a route previously added, 184.75.223.203 for gateway 10.31.210.1
. 2018.12.26 22:08:47 - Routes, removed a route previously added, 2606:6080:1002:5:a1ba:b510:7908:829e for gateway fde6:7a:7d20:1bd2::1
. 2018.12.26 22:08:47 - Sending management termination signal
. 2018.12.26 22:08:47 - Management - Send 'signal SIGTERM'
. 2018.12.26 22:08:47 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.12.26 22:08:47 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip route del 184.75.223.205/32
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip route del 0.0.0.0/1
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip route del 128.0.0.0/1
. 2018.12.26 22:08:52 - OpenVPN > delete_route_ipv6(::/3)
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip -6 route del ::/3 dev tun0
. 2018.12.26 22:08:52 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip -6 route del 2000::/4 dev tun0
. 2018.12.26 22:08:52 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip -6 route del 3000::/4 dev tun0
. 2018.12.26 22:08:52 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip -6 route del fc00::/7 dev tun0
. 2018.12.26 22:08:52 - OpenVPN > Closing TUN/TAP interface
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip addr del dev tun0 10.31.210.98/24
. 2018.12.26 22:08:52 - OpenVPN > /sbin/ip -6 addr del fde6:7a:7d20:1bd2::1060/64 dev tun0
. 2018.12.26 22:08:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.12.26 22:08:52 - Connection terminated.
. 2018.12.26 22:08:52 - DNS of the system restored to original settings (Rename method)
. 2018.12.26 22:08:52 - Flushing DNS
! 2018.12.26 22:08:54 - Session terminated.
I 2018.12.26 22:09:17 - Session starting.
I 2018.12.26 22:09:17 - Checking authorization ...
! 2018.12.26 22:09:17 - Connecting to Ain (Sweden, Stockholm)
. 2018.12.26 22:09:18 - OpenVPN > OpenVPN 2.4.6 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jul 30 2018
. 2018.12.26 22:09:18 - OpenVPN > library versions: OpenSSL 1.1.1a 20 Nov 2018, LZO 2.10
. 2018.12.26 22:09:18 - Connection to OpenVPN Management Interface
. 2018.12.26 22:09:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.12.26 22:09:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.12.26 22:09:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.12.26 22:09:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.12.26 22:09:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.12.26 22:09:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.104.82:443
. 2018.12.26 22:09:18 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984]
. 2018.12.26 22:09:18 - OpenVPN > UDP link local: (not bound)
. 2018.12.26 22:09:18 - OpenVPN > UDP link remote: [AF_INET]128.127.104.82:443
. 2018.12.26 22:09:18 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.12.26 22:09:18 - OpenVPN > TLS: Initial packet from [AF_INET]128.127.104.82:443, sid=1daa11b1 e8e84104
. 2018.12.26 22:09:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.12.26 22:09:18 - OpenVPN > VERIFY KU OK
. 2018.12.26 22:09:18 - OpenVPN > Validating certificate extended key usage
. 2018.12.26 22:09:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.12.26 22:09:18 - OpenVPN > VERIFY EKU OK
. 2018.12.26 22:09:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ain, emailAddress=info@airvpn.org
. 2018.12.26 22:09:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.12.26 22:09:19 - OpenVPN > [Ain] Peer Connection Initiated with [AF_INET]128.127.104.82:443
. 2018.12.26 22:09:20 - OpenVPN > SENT CONTROL [Ain]: 'PUSH_REQUEST' (status=1)
. 2018.12.26 22:09:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.226.1,dhcp-option DNS6 fde6:7a:7d20:e2::1,tun-ipv6,route-gateway 10.4.226.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:e2::10f7/64 fde6:7a:7d20:e2::1,ifconfig 10.4.226.249 255.255.255.0,peer-id 6,cipher AES-256-GCM'
. 2018.12.26 22:09:21 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.12.26 22:09:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.12.26 22:09:21 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.12.26 22:09:21 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.12.26 22:09:21 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.12.26 22:09:21 - OpenVPN > ROUTE_GATEWAY 192.168.86.1/255.255.255.0 IFACE=wlp3s0 HWADDR=74:df:bf:9c:72:89
. 2018.12.26 22:09:21 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.12.26 22:09:21 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.12.26 22:09:21 - OpenVPN > TUN/TAP device tun0 opened
. 2018.12.26 22:09:21 - OpenVPN > TUN/TAP TX queue length set to 100
. 2018.12.26 22:09:21 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.12.26 22:09:21 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2018.12.26 22:09:21 - OpenVPN > /sbin/ip addr add dev tun0 10.4.226.249/24 broadcast 10.4.226.255
. 2018.12.26 22:09:21 - OpenVPN > /sbin/ip -6 addr add fde6:7a:7d20:e2::10f7/64 dev tun0
. 2018.12.26 22:09:26 - OpenVPN > /sbin/ip route add 128.127.104.82/32 via 192.168.86.1
. 2018.12.26 22:09:26 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.226.1
. 2018.12.26 22:09:26 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.226.1
. 2018.12.26 22:09:26 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:e2::1 metric -1) dev tun0
. 2018.12.26 22:09:26 - OpenVPN > /sbin/ip -6 route add ::/3 dev tun0
. 2018.12.26 22:09:26 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:e2::1 metric -1) dev tun0
. 2018.12.26 22:09:26 - OpenVPN > /sbin/ip -6 route add 2000::/4 dev tun0
. 2018.12.26 22:09:26 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:e2::1 metric -1) dev tun0
. 2018.12.26 22:09:26 - OpenVPN > /sbin/ip -6 route add 3000::/4 dev tun0
. 2018.12.26 22:09:26 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:e2::1 metric -1) dev tun0
. 2018.12.26 22:09:26 - OpenVPN > /sbin/ip -6 route add fc00::/7 dev tun0
. 2018.12.26 22:09:26 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2018.12.26 22:09:26 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2018.12.26 22:09:26 - Routes, added a new route, 128.127.104.80 for gateway 10.4.226.1
. 2018.12.26 22:09:26 - Routes, added a new route, 2a00:7142:20:8264:9081:c057:c9e3:a141 for gateway fde6:7a:7d20:e2::1
. 2018.12.26 22:09:26 - Flushing DNS
I 2018.12.26 22:09:27 - Checking route IPv4
I 2018.12.26 22:09:28 - Checking route IPv6
I 2018.12.26 22:09:30 - Checking DNS
! 2018.12.26 22:09:32 - Connected.
. 2018.12.26 22:09:32 - OpenVPN > Initialization Sequence Completed
! 2018.12.26 22:10:16 - Disconnecting
. 2018.12.26 22:10:16 - Routes, removed a route previously added, 128.127.104.80 for gateway 10.4.226.1
. 2018.12.26 22:10:16 - Routes, removed a route previously added, 2a00:7142:20:8264:9081:c057:c9e3:a141 for gateway fde6:7a:7d20:e2::1
. 2018.12.26 22:10:16 - Sending management termination signal
. 2018.12.26 22:10:16 - Management - Send 'signal SIGTERM'
. 2018.12.26 22:10:16 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.12.26 22:10:16 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip route del 128.127.104.82/32
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip route del 0.0.0.0/1
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip route del 128.0.0.0/1
. 2018.12.26 22:10:21 - OpenVPN > delete_route_ipv6(::/3)
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip -6 route del ::/3 dev tun0
. 2018.12.26 22:10:21 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip -6 route del 2000::/4 dev tun0
. 2018.12.26 22:10:21 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip -6 route del 3000::/4 dev tun0
. 2018.12.26 22:10:21 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip -6 route del fc00::/7 dev tun0
. 2018.12.26 22:10:21 - OpenVPN > Closing TUN/TAP interface
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip addr del dev tun0 10.4.226.249/24
. 2018.12.26 22:10:21 - OpenVPN > /sbin/ip -6 addr del fde6:7a:7d20:e2::10f7/64 dev tun0
. 2018.12.26 22:10:21 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.12.26 22:10:21 - Connection terminated.
. 2018.12.26 22:10:21 - DNS of the system restored to original settings (Rename method)
. 2018.12.26 22:10:21 - Flushing DNS
! 2018.12.26 22:10:22 - Session terminated.
i think torrenting speeds are actually fine
