Not connected, Your IP: 216.73.216.13
Hello again!
I'm having trouble getting even close to my full speed with AirVPN active.
http://speedof.me/show.php?img=170705220555-7576.png  << With VPN active
http://speedof.me/show.php?img=170705220653-2928.png  << VPN not active
I have tried different protocols, different openvpn directives.  I am on Windows 10, latest edition, fully up to date.  I am using the latest beta Eddie, 2.13.2, though 2.12.4 has the same issue.  I'm on the latest TAP but I have tried 9.9, it doesn't seem to make a difference.  I have tried different servers all around me, and they all seem to have the same problem, though at varying degrees.  Attached is my log - let me know if you see anything.  I go through phases where I just deal with the lackluster speeds, but sometimes I have a task that requires bandwidth and having a less than stellar connection really bites.  I'd love to get this figured out once and for all.
Should I try a specific TAP version?  I was under the impression that the newest one fixed the W10 issues. I reset Eddie to default settings, let me know what I should try - one at a time - to see if it helps.
I 2017.07.05 18:11:31 - Session starting.
. 2017.07.05 18:11:31 - IPv6 disabled with packet filtering.
I 2017.07.05 18:11:31 - Checking authorization ...
! 2017.07.05 18:11:32 - Connecting to Rana (Canada, Toronto, Ontario)
. 2017.07.05 18:11:32 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2017.07.05 18:11:32 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.07.05 18:11:32 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.07.05 18:11:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.07.05 18:11:32 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.07.05 18:11:32 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.07.05 18:11:32 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.19.94.132:443
. 2017.07.05 18:11:32 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.07.05 18:11:32 - OpenVPN > UDP link local: (not bound)
. 2017.07.05 18:11:32 - OpenVPN > UDP link remote: [AF_INET]199.19.94.132:443
. 2017.07.05 18:11:32 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.94.132:443, sid=3c8efb63 52df6644
. 2017.07.05 18:11:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.07.05 18:11:32 - OpenVPN > VERIFY KU OK
. 2017.07.05 18:11:32 - OpenVPN > Validating certificate extended key usage
. 2017.07.05 18:11:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.07.05 18:11:32 - OpenVPN > VERIFY EKU OK
. 2017.07.05 18:11:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.07.05 18:11:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.07.05 18:11:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.94.132:443
. 2017.07.05 18:11:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.07.05 18:11:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.58.95 255.255.0.0'
. 2017.07.05 18:11:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.07.05 18:11:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.07.05 18:11:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.07.05 18:11:35 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.07.05 18:11:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.07.05 18:11:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.07.05 18:11:35 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.07.05 18:11:35 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.07.05 18:11:35 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.07.05 18:11:35 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.07.05 18:11:35 - OpenVPN > interactive service msg_channel=0
. 2017.07.05 18:11:35 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=6 HWADDR=4c:cc:6a:6c:0c:86
. 2017.07.05 18:11:35 - OpenVPN > open_tun
. 2017.07.05 18:11:35 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8FA98E4A-384C-41D4-B12D-2DA56B0AF9BF}.tap
. 2017.07.05 18:11:35 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.07.05 18:11:35 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.58.95/255.255.0.0 [sUCCEEDED]
. 2017.07.05 18:11:35 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.58.95/255.255.0.0 on interface {8FA98E4A-384C-41D4-B12D-2DA56B0AF9BF} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.07.05 18:11:35 - OpenVPN > Successful ARP Flush on interface [17] {8FA98E4A-384C-41D4-B12D-2DA56B0AF9BF}
. 2017.07.05 18:11:35 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.07.05 18:11:40 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.07.05 18:11:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 199.19.94.132 MASK 255.255.255.255 192.168.1.1
. 2017.07.05 18:11:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.07.05 18:11:40 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.07.05 18:11:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.07.05 18:11:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.07.05 18:11:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.07.05 18:11:40 - OpenVPN > WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
. 2017.07.05 18:11:40 - Starting Management Interface
. 2017.07.05 18:11:40 - OpenVPN > Initialization Sequence Completed
. 2017.07.05 18:11:40 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2017.07.05 18:11:40 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2017.07.05 18:11:40 - DNS leak protection with packet filtering enabled.
. 2017.07.05 18:11:40 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.07.05 18:11:40 - Flushing DNS
! 2017.07.05 18:11:43 - Connected.
. 2017.07.05 18:11:43 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.07.05 18:11:43 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2017.07.05 18:11:50 - Disconnecting
. 2017.07.05 18:11:50 - Management - Send 'signal SIGTERM'
. 2017.07.05 18:11:50 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.07.05 18:11:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.07.05 18:11:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 199.19.94.132 MASK 255.255.255.255 192.168.1.1
. 2017.07.05 18:11:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.07.05 18:11:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.07.05 18:11:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.07.05 18:11:55 - OpenVPN > Closing TUN/TAP interface
. 2017.07.05 18:11:55 - OpenVPN > TAP: DHCP address released
. 2017.07.05 18:11:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.07.05 18:11:55 - Connection terminated.
. 2017.07.05 18:11:55 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.07.05 18:11:55 - DNS leak protection with packet filtering disabled.
. 2017.07.05 18:11:55 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2017.07.05 18:11:55 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
. 2017.07.05 18:11:55 - IPv6 restored with packet filtering.
. 2017.07.05 18:11:55 - Flushing DNS
! 2017.07.05 18:11:58 - Session terminated.
Have you tried disabling IPv6 on all interfaces including TAP?
Have you tried disabling any anti-virus or firewall software you're running?
Have you tried with and without Network Lock?
Have you tried servers which aren't near you geographically?
Have you tried running Eddie from a different computer on the same network?
Have you tried different send and receive buffer sizes in Eddie?
Have you tried different speedtests?
From 2-3 weeks ago the speed of Airvpn is very poor, changing all servers with better performance. If I'm not change anything about my connection I'm not understand why I must change all when suddenly Airvpn moves less than 5% of my real fiber speef
Enviado desde mi ASUS_Z012D mediante Tapatalk
Do you believe that the speed of the AirVPN servers changes?  Do you believe that AirVPN controls all the internet between you and the servers?
