starbase1
Almost every site connection fails...
Right now almost every server returns an error.
I have tried uninstalling and re-installing the software, (Windows 7, 64 bit), but this does not fix anything.
I have a suspicion it might be to do with come changes I made to settings on DNS, as I was finding it left the DNS unusable after I stopped the service, (I had to reset the source of DNS to automatic).
Any ideas?
Could it be hanging onto bad settings?
How can I do a full complete reset if uninstalling and reinstalling does not work?
Maybe you could try the experimental client. But it would be nice with some logs too, if applicable and possible.
today there was/is a large DNS problem that affected a large portion of the United States and some of Europe because of a DDOS attack on the Dyn company.
Perhaps that is the problem you're experiencing?
I'm experiencing this too. Major websites such as Reddit and Twitter are down for me. There seems to be a huge attack on some big DNS servers.
Good suggestion, but this has been for some time.
Finally getting round to fixing it!
OK, I managed to turn on logging, tried a few connections, and found the log file.
I can't see how to attach a file...
But maybe this will be good enough, a log for one connection attempt:
I 2016.10.21 19:45:13 - Session starting.
I 2016.10.21 19:45:13 - Checking authorization ...
! 2016.10.21 19:45:13 - Connecting to Alamak (Romania, Bucharest)
. 2016.10.21 19:45:13 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.10.21 19:45:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.10.21 19:45:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.10.21 19:45:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.10.21 19:45:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:14 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.10.21 19:45:14 - OpenVPN > UDPv4 link local: [undef]
. 2016.10.21 19:45:14 - OpenVPN > UDPv4 link remote: [AF_INET]91.207.102.162:443
. 2016.10.21 19:45:14 - OpenVPN > TLS: Initial packet from [AF_INET]91.207.102.162:443, sid=7abb475f 5ca29d3f
. 2016.10.21 19:45:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.10.21 19:45:14 - OpenVPN > Validating certificate key usage
. 2016.10.21 19:45:14 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.10.21 19:45:14 - OpenVPN > VERIFY KU OK
. 2016.10.21 19:45:14 - OpenVPN > Validating certificate extended key usage
. 2016.10.21 19:45:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.10.21 19:45:14 - OpenVPN > VERIFY EKU OK
. 2016.10.21 19:45:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.10.21 19:45:14 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.10.21 19:45:14 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:14 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.10.21 19:45:14 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:14 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.10.21 19:45:14 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]91.207.102.162:443
. 2016.10.21 19:45:17 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.10.21 19:45:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.158 255.255.0.0'
. 2016.10.21 19:45:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.10.21 19:45:17 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.10.21 19:45:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.10.21 19:45:17 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.10.21 19:45:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.10.21 19:45:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.10.21 19:45:17 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.10.21 19:45:17 - OpenVPN > open_tun, tt->ipv6=0
. 2016.10.21 19:45:17 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{970BC10D-AFB7-4A0E-B0A4-FAAE1076E8E9}.tap
. 2016.10.21 19:45:17 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.10.21 19:45:17 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.158/255.255.0.0 [sUCCEEDED]
. 2016.10.21 19:45:17 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.158/255.255.0.0 on interface {970BC10D-AFB7-4A0E-B0A4-FAAE1076E8E9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.10.21 19:45:17 - OpenVPN > Successful ARP Flush on interface [10] {970BC10D-AFB7-4A0E-B0A4-FAAE1076E8E9}
. 2016.10.21 19:45:22 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.10.21 19:45:22 - OpenVPN > M:\Windows\system32\route.exe ADD 91.207.102.162 MASK 255.255.255.255 192.168.1.1
. 2016.10.21 19:45:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.10.21 19:45:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.10.21 19:45:22 - OpenVPN > M:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 11
. 2016.10.21 19:45:22 - OpenVPN > M:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.10.21 19:45:22 - OpenVPN > M:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:22 - Starting Management Interface
. 2016.10.21 19:45:22 - OpenVPN > Initialization Sequence Completed
I 2016.10.21 19:45:22 - Flushing DNS
I 2016.10.21 19:45:22 - Checking route
I 2016.10.21 19:45:23 - Checking DNS
E 2016.10.21 19:45:23 - DNS checking failed.
. 2016.10.21 19:45:23 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2016.10.21 19:45:23 - Disconnecting
. 2016.10.21 19:45:23 - Management - Send 'signal SIGTERM'
. 2016.10.21 19:45:23 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.10.21 19:45:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.10.21 19:45:24 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.10.21 19:45:28 - OpenVPN > M:\Windows\system32\route.exe DELETE 91.207.102.162 MASK 255.255.255.255 192.168.1.1
. 2016.10.21 19:45:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.10.21 19:45:28 - OpenVPN > M:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2016.10.21 19:45:28 - OpenVPN > M:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:28 - OpenVPN > M:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:28 - OpenVPN > Closing TUN/TAP interface
. 2016.10.21 19:45:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.10.21 19:45:28 - Connection terminated.
I 2016.10.21 19:45:31 - Checking authorization ...
! 2016.10.21 19:45:31 - Connecting to Hassaleh (Netherlands, Alblasserdam)
. 2016.10.21 19:45:31 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.10.21 19:45:31 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.10.21 19:45:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.10.21 19:45:31 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.10.21 19:45:31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:31 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.10.21 19:45:31 - OpenVPN > UDPv4 link local: [undef]
. 2016.10.21 19:45:31 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.39:443
. 2016.10.21 19:45:31 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.39:443, sid=9ccc0f0e e79c73e5
. 2016.10.21 19:45:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.10.21 19:45:31 - OpenVPN > Validating certificate key usage
. 2016.10.21 19:45:32 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.10.21 19:45:32 - OpenVPN > VERIFY KU OK
. 2016.10.21 19:45:32 - OpenVPN > Validating certificate extended key usage
. 2016.10.21 19:45:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.10.21 19:45:32 - OpenVPN > VERIFY EKU OK
. 2016.10.21 19:45:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.10.21 19:45:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.10.21 19:45:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.10.21 19:45:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.10.21 19:45:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.10.21 19:45:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.39:443
. 2016.10.21 19:45:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.10.21 19:45:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.42 255.255.0.0'
. 2016.10.21 19:45:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.10.21 19:45:34 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.10.21 19:45:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.10.21 19:45:34 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.10.21 19:45:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.10.21 19:45:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.10.21 19:45:34 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.10.21 19:45:34 - OpenVPN > open_tun, tt->ipv6=0
. 2016.10.21 19:45:34 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{970BC10D-AFB7-4A0E-B0A4-FAAE1076E8E9}.tap
. 2016.10.21 19:45:34 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.10.21 19:45:34 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.21.42/255.255.0.0 [sUCCEEDED]
. 2016.10.21 19:45:34 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.21.42/255.255.0.0 on interface {970BC10D-AFB7-4A0E-B0A4-FAAE1076E8E9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.10.21 19:45:34 - OpenVPN > Successful ARP Flush on interface [10] {970BC10D-AFB7-4A0E-B0A4-FAAE1076E8E9}
. 2016.10.21 19:45:39 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.10.21 19:45:39 - OpenVPN > M:\Windows\system32\route.exe ADD 213.152.161.39 MASK 255.255.255.255 192.168.1.1
. 2016.10.21 19:45:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.10.21 19:45:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.10.21 19:45:39 - OpenVPN > M:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 11
. 2016.10.21 19:45:39 - OpenVPN > M:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.10.21 19:45:39 - OpenVPN > M:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:39 - Starting Management Interface
. 2016.10.21 19:45:39 - OpenVPN > Initialization Sequence Completed
I 2016.10.21 19:45:39 - Flushing DNS
I 2016.10.21 19:45:39 - Checking route
I 2016.10.21 19:45:41 - Checking DNS
E 2016.10.21 19:45:41 - DNS checking failed.
. 2016.10.21 19:45:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2016.10.21 19:45:41 - Disconnecting
. 2016.10.21 19:45:41 - Management - Send 'signal SIGTERM'
. 2016.10.21 19:45:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.10.21 19:45:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.10.21 19:45:41 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.10.21 19:45:46 - OpenVPN > M:\Windows\system32\route.exe DELETE 213.152.161.39 MASK 255.255.255.255 192.168.1.1
. 2016.10.21 19:45:46 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.10.21 19:45:46 - OpenVPN > M:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2016.10.21 19:45:46 - OpenVPN > M:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:46 - OpenVPN > M:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.10.21 19:45:46 - Connection terminated.
. 2016.10.21 19:45:46 - OpenVPN > Closing TUN/TAP interface
. 2016.10.21 19:45:46 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2016.10.21 19:45:46 - Cancel requested.
! 2016.10.21 19:45:46 - Session terminated.
