Hello !
​No. Check the very first section of my guide, after the introduction, to get a full answer to that question. Welcome to AirVPN however!
The best thing to do is build or buy a pfsense box or some other good firewall software. These are powerful enough to run openvpn at good speeds for the whole house. It doesn't take much understanding to configure them to your needs and there is an excellent setup guide in this forum.
Consumer routers will probably not make you happy.  The best can run openvpn at about 60mbit/s, max.  The best.  Not an asus n66 or the like.
You're most welcome. You can come ask us about router advice when you get that far. I wish you good luck!
