Not connected, Your IP: 216.73.217.74
The Illusive Man
Disconnecting when torrent client tuns
I'm  using kaspersky total security 2016, airpvn client 2.10.3 and TAP driver 9.0.0.21.
Whenever I start a torrent client, doesn't matter which one utorrent, tixati, qbittorent etc within 5 minutes my vpn client gets stuck in a disconnecting loop giving the message "Assertion failed at misc.c:779 "
I have already followed the steps in the link below but unfortunately that has made no difference.
https://airvpn.org/topic/17433-how-tofix-disconect-problems-with-kaspersky/
Here is a log file
http://s000.tinyupload.com/index.php?file_id=08295314778342552424
Any suggestions would be greatly appreciated.
I tried your site to read your log but my anti virus claimed "harmful site".
Are you trying to connect to Canadian servers?
No. I always use either Netherlands or German servers
Hello !
OP I recommend just pasting your logs into some spoiler tags, for us to view them easily.
I 2016.07.12 13:55:53 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.07.12 13:55:53 - Reading options from C:\Program Files\AirVPN\AirVPN.xml
. 2016.07.12 13:55:54 - Data Path: C:\Program Files\AirVPN
. 2016.07.12 13:55:54 - App Path: C:\Program Files\AirVPN
. 2016.07.12 13:55:54 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.07.12 13:55:54 - Command line arguments (0):
. 2016.07.12 13:55:54 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.07.12 13:55:54 - Updating systems & servers data ...
I 2016.07.12 13:55:54 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.07.12 13:55:54 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.07.12 13:55:54 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.07.12 13:55:54 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.07.12 13:55:54 - Ready
. 2016.07.12 13:55:54 - Systems & servers data update completed
I 2016.07.12 13:55:55 - Session starting.
I 2016.07.12 13:56:02 - Checking authorization ...
! 2016.07.12 13:56:02 - Connecting to Salm (Netherlands, Alblasserdam)
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[ui]: Reading configuration from file C:\Program Files\AirVPN\86e3137730c7241329ba636ebf4f1bdf335aadfb051823d676ad336177682463.tmp.ssl
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG6[ui]: Initializing service [openvpn]
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[ui]: Configuration successful
. 2016.07.12 13:56:03 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.12 13:56:03 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.12 13:56:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.12 13:56:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.12 13:56:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:56:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:56:03 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.12 13:56:03 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:5468 [nonblock]
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49170
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG6[0]: Failover strategy: round-robin
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG6[0]: s_connect: connecting 213.152.161.21:443
. 2016.07.12 13:56:03 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:5468
. 2016.07.12 13:56:03 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.12 13:56:03 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:5468
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[0]: s_connect: connected 213.152.161.21:443
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.64:49171
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG6[0]: SNI: sending servername: 213.152.161.21
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG6[0]: CERT: Locally installed certificate matched
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG6[0]: SSL connected: new session negotiated
. 2016.07.12 13:56:03 - SSL > 2016.07.12 13:56:03 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.07.12 13:56:03 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:5468, sid=98772e18 056d75fe
. 2016.07.12 13:56:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.12 13:56:03 - OpenVPN > Validating certificate key usage
. 2016.07.12 13:56:03 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.12 13:56:03 - OpenVPN > VERIFY KU OK
. 2016.07.12 13:56:03 - OpenVPN > Validating certificate extended key usage
. 2016.07.12 13:56:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.12 13:56:03 - OpenVPN > VERIFY EKU OK
. 2016.07.12 13:56:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.12 13:56:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.12 13:56:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:56:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.12 13:56:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:56:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.12 13:56:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:5468
. 2016.07.12 13:56:05 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.12 13:56:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.1.32 255.255.0.0'
. 2016.07.12 13:56:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.12 13:56:05 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.12 13:56:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.12 13:56:05 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.12 13:56:05 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.12 13:56:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.12 13:56:05 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.12 13:56:05 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.12 13:56:05 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{1592787E-EAE0-432D-98E6-A8925151588C}.tap
. 2016.07.12 13:56:05 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.07.12 13:56:05 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.1.32/255.255.0.0 [sUCCEEDED]
. 2016.07.12 13:56:05 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.1.32/255.255.0.0 on interface {1592787E-EAE0-432D-98E6-A8925151588C} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.07.12 13:56:05 - OpenVPN > Successful ARP Flush on interface [12] {1592787E-EAE0-432D-98E6-A8925151588C}
. 2016.07.12 13:56:10 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.07.12 13:56:10 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2016.07.12 13:56:10 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.07.12 13:56:10 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.12 13:56:10 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2016.07.12 13:56:10 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.12 13:56:10 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.12 13:56:10 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.21 MASK 255.255.255.255 192.168.1.254
. 2016.07.12 13:56:10 - Starting Management Interface
. 2016.07.12 13:56:10 - OpenVPN > Initialization Sequence Completed
I 2016.07.12 13:56:11 - DNS of a network adapter forced (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.12 13:56:11 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.12 13:56:11 - Flushing DNS
I 2016.07.12 13:56:11 - Checking route
I 2016.07.12 13:56:11 - Checking DNS
! 2016.07.12 13:56:11 - Connected.
. 2016.07.12 13:56:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.12 13:56:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.12 14:17:13 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.07.12 14:17:13 - SSL > 2016.07.12 14:17:13 LOG6[0]: writesocket: Socket is closed
. 2016.07.12 14:17:13 - SSL > 2016.07.12 14:17:13 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.07.12 14:17:13 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.07.12 14:17:13 - SSL > 2016.07.12 14:17:13 LOG5[0]: Connection closed: 90879683 byte(s) sent to SSL, 897343408 byte(s) sent to socket
. 2016.07.12 14:17:13 - OpenVPN > Restart pause, 5 second(s)
! 2016.07.12 14:17:13 - Disconnecting
. 2016.07.12 14:17:13 - Management - Send 'signal SIGTERM'
. 2016.07.12 14:17:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.12 14:17:13 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.07.12 14:17:13 - OpenVPN > Assertion failed at misc.c:779
. 2016.07.12 14:17:13 - OpenVPN > Exiting due to fatal error
. 2016.07.12 14:17:13 - Connection terminated.
I 2016.07.12 14:17:13 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.12 14:17:13 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.12 13:27:40 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.07.12 13:27:40 - Reading options from C:\Program Files\AirVPN\AirVPN.xml
. 2016.07.12 13:27:40 - Data Path: C:\Program Files\AirVPN
. 2016.07.12 13:27:40 - App Path: C:\Program Files\AirVPN
. 2016.07.12 13:27:40 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.07.12 13:27:40 - Command line arguments (0):
. 2016.07.12 13:27:40 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.07.12 13:27:40 - Updating systems & servers data ...
I 2016.07.12 13:27:41 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.07.12 13:27:41 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.07.12 13:27:41 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.07.12 13:27:41 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
W 2016.07.12 13:27:41 - Recovery. Unexpected crash?
I 2016.07.12 13:27:41 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.12 13:27:41 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
! 2016.07.12 13:27:41 - Ready
. 2016.07.12 13:27:41 - Systems & servers data update completed
I 2016.07.12 13:27:43 - Session starting.
I 2016.07.12 13:27:49 - Checking authorization ...
! 2016.07.12 13:27:49 - Connecting to Salm (Netherlands, Alblasserdam)
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[ui]: Reading configuration from file C:\Program Files\AirVPN\11a6c723fb940a356d53601d675f55bde2c3c8bb70e3ace3b1b96fed78c6d224.tmp.ssl
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG6[ui]: Initializing service [openvpn]
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[ui]: Configuration successful
. 2016.07.12 13:27:50 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.12 13:27:50 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.12 13:27:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.12 13:27:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.12 13:27:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:27:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:27:50 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.12 13:27:50 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:48635 [nonblock]
. 2016.07.12 13:27:50 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:48635
. 2016.07.12 13:27:50 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.12 13:27:50 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:48635
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:59774
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG6[0]: Failover strategy: round-robin
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG6[0]: s_connect: connecting 213.152.161.21:443
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[0]: s_connect: connected 213.152.161.21:443
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.64:59775
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG6[0]: SNI: sending servername: 213.152.161.21
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG6[0]: CERT: Locally installed certificate matched
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG6[0]: SSL connected: new session negotiated
. 2016.07.12 13:27:50 - SSL > 2016.07.12 13:27:50 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.07.12 13:27:50 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:48635, sid=44224ce3 021bc2ba
. 2016.07.12 13:27:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.12 13:27:50 - OpenVPN > Validating certificate key usage
. 2016.07.12 13:27:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.12 13:27:50 - OpenVPN > VERIFY KU OK
. 2016.07.12 13:27:50 - OpenVPN > Validating certificate extended key usage
. 2016.07.12 13:27:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.12 13:27:50 - OpenVPN > VERIFY EKU OK
. 2016.07.12 13:27:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.12 13:27:51 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.12 13:27:51 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:27:51 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.12 13:27:51 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.12 13:27:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.12 13:27:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:48635
. 2016.07.12 13:27:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.12 13:27:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.1.32 255.255.0.0'
. 2016.07.12 13:27:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.12 13:27:53 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.12 13:27:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.12 13:27:53 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.12 13:27:53 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.12 13:27:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.12 13:27:53 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.12 13:27:53 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.12 13:27:53 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{1592787E-EAE0-432D-98E6-A8925151588C}.tap
. 2016.07.12 13:27:53 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.07.12 13:27:53 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.1.32/255.255.0.0 [sUCCEEDED]
. 2016.07.12 13:27:53 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.1.32/255.255.0.0 on interface {1592787E-EAE0-432D-98E6-A8925151588C} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.07.12 13:27:53 - OpenVPN > Successful ARP Flush on interface [12] {1592787E-EAE0-432D-98E6-A8925151588C}
. 2016.07.12 13:27:58 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.07.12 13:27:58 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2016.07.12 13:27:58 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2016.07.12 13:27:58 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.07.12 13:27:58 - OpenVPN > Route addition fallback to route.exe
. 2016.07.12 13:27:58 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.07.12 13:27:58 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2016.07.12 13:27:58 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.12 13:27:58 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=12]
. 2016.07.12 13:27:58 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.12 13:27:58 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.21 MASK 255.255.255.255 192.168.1.254
. 2016.07.12 13:27:58 - Starting Management Interface
. 2016.07.12 13:27:58 - OpenVPN > Initialization Sequence Completed
I 2016.07.12 13:27:58 - DNS of a network adapter forced (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.12 13:27:58 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.12 13:27:58 - Flushing DNS
I 2016.07.12 13:27:58 - Checking route
I 2016.07.12 13:27:59 - Checking DNS
! 2016.07.12 13:27:59 - Connected.
. 2016.07.12 13:27:59 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.12 13:27:59 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.12 13:35:26 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.07.12 13:35:26 - SSL > 2016.07.12 13:35:26 LOG6[0]: writesocket: Socket is closed
. 2016.07.12 13:35:26 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.07.12 13:35:26 - SSL > 2016.07.12 13:35:26 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.07.12 13:35:26 - SSL > 2016.07.12 13:35:26 LOG5[0]: Connection closed: 326415985 byte(s) sent to SSL, 739130452 byte(s) sent to socket
. 2016.07.12 13:35:26 - OpenVPN > Restart pause, 5 second(s)
! 2016.07.12 13:35:26 - Disconnecting
. 2016.07.12 13:35:26 - Management - Send 'signal SIGTERM'
. 2016.07.12 13:35:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.12 13:35:26 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.07.12 13:35:26 - OpenVPN > Assertion failed at misc.c:779
. 2016.07.12 13:35:26 - OpenVPN > Exiting due to fatal error
. 2016.07.12 13:35:26 - Connection terminated.
I 2016.07.12 13:35:26 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.12 13:35:26 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.12 13:35:29 - Checking authorization ...
Maybe try a different TAP driver.
i guess I can try it, although the reason Ive stuck to 9.0.0.21 is other versions gave me serious problems with constant BSOD errors.
Anyway il give it a shot, thanks
Regarding TAP...
So the different TAP driver seems to have fixed the problem.  Ive tried numerous versions and did get a lot of errors, but i've been using 9.0.0.9 since last night and so far haven't had any crashes or disconnections.
Unfortunately the problem has started up again.
Haven't changed a single thing, nothing has been updated, no new programs have been installed, anti-virus and firewall settings haven't been touched.
I 2016.07.21 11:40:43 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.07.21 11:40:43 - Reading options from C:\Users\J\AppData\Local\AirVPN\AirVPN.xml
. 2016.07.21 11:40:43 - Data Path: C:\Users\J\AppData\Local\AirVPN
. 2016.07.21 11:40:43 - App Path: C:\Program Files\AirVPN
. 2016.07.21 11:40:43 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.07.21 11:40:43 - Command line arguments (1): path="home"
. 2016.07.21 11:40:43 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.07.21 11:40:43 - Updating systems & servers data ...
I 2016.07.21 11:40:43 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.9.1
I 2016.07.21 11:40:43 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.07.21 11:40:43 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.07.21 11:40:43 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.07.21 11:40:43 - Ready
. 2016.07.21 11:40:44 - Systems & servers data update completed
I 2016.07.21 11:40:56 - Session starting.
I 2016.07.21 11:40:56 - Network adapter DHCP switched to static (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 11:40:59 - Checking authorization ...
W 2016.07.21 11:40:59 - Authorization check failed, continue anyway ({1])
! 2016.07.21 11:40:59 - Connecting to Alshat (Netherlands, Alblasserdam)
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:40:59 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:40:59 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:40:59 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:40:59 LOG5[ui]: Reading configuration from file C:\Users\J\AppData\Local\AirVPN\b14d43eb29071a8aa59faf554734dd3393241f6acd85a1e7292f9522fc79ec38.tmp.ssl
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:40:59 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG6[ui]: Initializing service [openvpn]
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG5[ui]: Configuration successful
. 2016.07.21 11:41:00 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.21 11:41:00 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.21 11:41:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.21 11:41:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.21 11:41:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:41:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:41:00 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.21 11:41:00 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:28504 [nonblock]
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49215
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG6[0]: Failover strategy: round-robin
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG6[0]: s_connect: connecting 213.152.161.6:443
. 2016.07.21 11:41:00 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:28504
. 2016.07.21 11:41:00 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.21 11:41:00 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:28504
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG5[0]: s_connect: connected 213.152.161.6:443
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.64:49216
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG6[0]: SNI: sending servername: 213.152.161.6
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG6[0]: CERT: Locally installed certificate matched
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG6[0]: SSL connected: new session negotiated
. 2016.07.21 11:41:00 - SSL > 2016.07.21 11:41:00 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.07.21 11:41:00 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:28504, sid=91ff7a30 54adbd67
. 2016.07.21 11:41:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.21 11:41:00 - OpenVPN > Validating certificate key usage
. 2016.07.21 11:41:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.21 11:41:00 - OpenVPN > VERIFY KU OK
. 2016.07.21 11:41:00 - OpenVPN > Validating certificate extended key usage
. 2016.07.21 11:41:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.21 11:41:00 - OpenVPN > VERIFY EKU OK
. 2016.07.21 11:41:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.21 11:41:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 11:41:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:41:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 11:41:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:41:00 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.21 11:41:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:28504
. 2016.07.21 11:41:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.21 11:41:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.245 255.255.0.0'
. 2016.07.21 11:41:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.21 11:41:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.21 11:41:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.21 11:41:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.21 11:41:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.21 11:41:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.21 11:41:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.21 11:41:03 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.21 11:41:03 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{1592787E-EAE0-432D-98E6-A8925151588C}.tap
. 2016.07.21 11:41:03 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.07.21 11:41:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.245/255.255.0.0 [sUCCEEDED]
. 2016.07.21 11:41:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.245/255.255.0.0 on interface {1592787E-EAE0-432D-98E6-A8925151588C} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.07.21 11:41:03 - OpenVPN > Successful ARP Flush on interface [12] {1592787E-EAE0-432D-98E6-A8925151588C}
. 2016.07.21 11:41:08 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.07.21 11:41:08 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:41:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.07.21 11:41:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.21 11:41:08 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:41:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.07.21 11:41:08 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:41:08 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.6 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:41:08 - Starting Management Interface
. 2016.07.21 11:41:08 - OpenVPN > Initialization Sequence Completed
I 2016.07.21 11:41:08 - DNS of a network adapter forced (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 11:41:08 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.21 11:41:08 - Flushing DNS
I 2016.07.21 11:41:08 - Checking route
I 2016.07.21 11:41:08 - Checking DNS
! 2016.07.21 11:41:08 - Connected.
. 2016.07.21 11:41:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.21 11:41:08 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2016.07.21 11:56:49 - Disconnecting
. 2016.07.21 11:56:49 - Management - Send 'signal SIGTERM'
. 2016.07.21 11:56:49 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.21 11:56:49 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.6 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:56:49 - SSL > 2016.07.21 11:56:49 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2016.07.21 11:56:49 - SSL > 2016.07.21 11:56:49 LOG5[0]: Connection reset: 716742158 byte(s) sent to SSL, 1093047845 byte(s) sent to socket
. 2016.07.21 11:56:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.07.21 11:56:49 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:56:49 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:56:49 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:56:49 - OpenVPN > Closing TUN/TAP interface
. 2016.07.21 11:56:49 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.07.21 11:56:49 - Connection terminated.
I 2016.07.21 11:56:49 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 11:56:49 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.21 11:56:52 - Checking authorization ...
! 2016.07.21 11:56:52 - Connecting to Seginus (Germany, Frankfurt)
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[ui]: Reading configuration from file C:\Users\J\AppData\Local\AirVPN\4d58f2308e5709c21f57417f0f34b3f494dc6427fad181c14e1726783d6ccf27.tmp.ssl
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG6[ui]: Initializing service [openvpn]
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[ui]: Configuration successful
. 2016.07.21 11:56:53 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.21 11:56:53 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.21 11:56:53 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.21 11:56:53 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.21 11:56:53 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:56:53 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:56:53 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.21 11:56:53 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:55132 [nonblock]
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:51796
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG6[0]: Failover strategy: round-robin
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG6[0]: s_connect: connecting 178.162.198.110:443
. 2016.07.21 11:56:53 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:55132
. 2016.07.21 11:56:53 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.21 11:56:53 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:55132
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[0]: s_connect: connected 178.162.198.110:443
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.64:51797
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG6[0]: SNI: sending servername: 178.162.198.110
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG6[0]: CERT: Locally installed certificate matched
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG6[0]: SSL connected: new session negotiated
. 2016.07.21 11:56:53 - SSL > 2016.07.21 11:56:53 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.07.21 11:56:53 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:55132, sid=97dbca94 93ef76c1
. 2016.07.21 11:56:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.21 11:56:53 - OpenVPN > Validating certificate key usage
. 2016.07.21 11:56:53 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.21 11:56:53 - OpenVPN > VERIFY KU OK
. 2016.07.21 11:56:53 - OpenVPN > Validating certificate extended key usage
. 2016.07.21 11:56:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.21 11:56:53 - OpenVPN > VERIFY EKU OK
. 2016.07.21 11:56:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.21 11:56:54 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 11:56:54 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:56:54 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 11:56:54 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:56:54 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.21 11:56:54 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:55132
. 2016.07.21 11:56:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.21 11:56:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.3.57 255.255.0.0'
. 2016.07.21 11:56:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.21 11:56:56 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.21 11:56:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.21 11:56:56 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.21 11:56:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.21 11:56:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.21 11:56:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.21 11:56:56 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.21 11:56:56 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{1592787E-EAE0-432D-98E6-A8925151588C}.tap
. 2016.07.21 11:56:56 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.07.21 11:56:56 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.3.57/255.255.0.0 [sUCCEEDED]
. 2016.07.21 11:56:56 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.3.57/255.255.0.0 on interface {1592787E-EAE0-432D-98E6-A8925151588C} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.07.21 11:56:56 - OpenVPN > Successful ARP Flush on interface [12] {1592787E-EAE0-432D-98E6-A8925151588C}
. 2016.07.21 11:57:01 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.07.21 11:57:01 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:57:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.07.21 11:57:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.21 11:57:01 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:57:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.07.21 11:57:01 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:57:01 - OpenVPN > C:\Windows\system32\route.exe ADD 178.162.198.110 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:57:01 - Starting Management Interface
. 2016.07.21 11:57:01 - OpenVPN > Initialization Sequence Completed
I 2016.07.21 11:57:01 - DNS of a network adapter forced (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 11:57:01 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.21 11:57:01 - Flushing DNS
I 2016.07.21 11:57:01 - Checking route
I 2016.07.21 11:57:02 - Checking DNS
! 2016.07.21 11:57:02 - Connected.
. 2016.07.21 11:57:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.21 11:57:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2016.07.21 11:58:06 - Disconnecting
. 2016.07.21 11:58:06 - Management - Send 'signal SIGTERM'
. 2016.07.21 11:58:06 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.21 11:58:06 - SSL > 2016.07.21 11:58:06 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2016.07.21 11:58:06 - OpenVPN > C:\Windows\system32\route.exe DELETE 178.162.198.110 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:58:06 - SSL > 2016.07.21 11:58:06 LOG5[0]: Connection reset: 523165 byte(s) sent to SSL, 556327 byte(s) sent to socket
. 2016.07.21 11:58:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.07.21 11:58:06 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:58:06 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:58:06 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:58:06 - OpenVPN > Closing TUN/TAP interface
. 2016.07.21 11:58:06 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.07.21 11:58:06 - Connection terminated.
I 2016.07.21 11:58:06 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 11:58:06 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.21 11:58:09 - Checking authorization ...
! 2016.07.21 11:58:09 - Connecting to Alshat (Netherlands, Alblasserdam)
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[ui]: Reading configuration from file C:\Users\J\AppData\Local\AirVPN\a6331b8ae785f17988b1325067c6047510387cfd8fdfa8909785eb8a1824161a.tmp.ssl
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG6[ui]: Initializing service [openvpn]
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[ui]: Configuration successful
. 2016.07.21 11:58:09 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.21 11:58:09 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.21 11:58:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.21 11:58:09 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.21 11:58:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:58:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:58:09 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.21 11:58:09 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:63902 [nonblock]
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:51983
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG6[0]: Failover strategy: round-robin
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG6[0]: s_connect: connecting 213.152.161.6:443
. 2016.07.21 11:58:09 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:63902
. 2016.07.21 11:58:09 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.21 11:58:09 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:63902
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[0]: s_connect: connected 213.152.161.6:443
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.64:51984
. 2016.07.21 11:58:09 - SSL > 2016.07.21 11:58:09 LOG6[0]: SNI: sending servername: 213.152.161.6
. 2016.07.21 11:58:10 - SSL > 2016.07.21 11:58:10 LOG6[0]: CERT: Locally installed certificate matched
. 2016.07.21 11:58:10 - SSL > 2016.07.21 11:58:10 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.07.21 11:58:10 - SSL > 2016.07.21 11:58:10 LOG6[0]: SSL connected: new session negotiated
. 2016.07.21 11:58:10 - SSL > 2016.07.21 11:58:10 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.07.21 11:58:10 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:63902, sid=b3f17c79 469457ec
. 2016.07.21 11:58:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.21 11:58:10 - OpenVPN > Validating certificate key usage
. 2016.07.21 11:58:10 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.21 11:58:10 - OpenVPN > VERIFY KU OK
. 2016.07.21 11:58:10 - OpenVPN > Validating certificate extended key usage
. 2016.07.21 11:58:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.21 11:58:10 - OpenVPN > VERIFY EKU OK
. 2016.07.21 11:58:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.21 11:58:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 11:58:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:58:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 11:58:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 11:58:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.21 11:58:10 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:63902
. 2016.07.21 11:58:12 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.21 11:58:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.245 255.255.0.0'
. 2016.07.21 11:58:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.21 11:58:12 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.21 11:58:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.21 11:58:12 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.21 11:58:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.21 11:58:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.21 11:58:12 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.21 11:58:12 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.21 11:58:12 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{1592787E-EAE0-432D-98E6-A8925151588C}.tap
. 2016.07.21 11:58:12 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.07.21 11:58:12 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.245/255.255.0.0 [sUCCEEDED]
. 2016.07.21 11:58:12 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.245/255.255.0.0 on interface {1592787E-EAE0-432D-98E6-A8925151588C} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.07.21 11:58:12 - OpenVPN > Successful ARP Flush on interface [12] {1592787E-EAE0-432D-98E6-A8925151588C}
. 2016.07.21 11:58:17 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.07.21 11:58:17 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:58:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.07.21 11:58:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.21 11:58:17 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:58:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.07.21 11:58:17 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.07.21 11:58:17 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.6 MASK 255.255.255.255 192.168.1.254
. 2016.07.21 11:58:17 - Starting Management Interface
. 2016.07.21 11:58:17 - OpenVPN > Initialization Sequence Completed
I 2016.07.21 11:58:17 - DNS of a network adapter forced (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 11:58:17 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.21 11:58:17 - Flushing DNS
I 2016.07.21 11:58:17 - Checking route
I 2016.07.21 11:58:17 - Checking DNS
! 2016.07.21 11:58:18 - Connected.
. 2016.07.21 11:58:18 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.21 11:58:18 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.21 12:10:44 - Updating systems & servers data ...
. 2016.07.21 12:10:45 - Systems & servers data update completed
. 2016.07.21 12:40:45 - Updating systems & servers data ...
. 2016.07.21 12:40:45 - Systems & servers data update completed
. 2016.07.21 12:58:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.21 12:58:10 - OpenVPN > Validating certificate key usage
. 2016.07.21 12:58:10 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.21 12:58:10 - OpenVPN > VERIFY KU OK
. 2016.07.21 12:58:10 - OpenVPN > Validating certificate extended key usage
. 2016.07.21 12:58:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.21 12:58:10 - OpenVPN > VERIFY EKU OK
. 2016.07.21 12:58:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.21 12:58:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 12:58:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 12:58:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 12:58:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 12:58:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.21 13:10:45 - Updating systems & servers data ...
. 2016.07.21 13:10:47 - Systems & servers data update completed
. 2016.07.21 13:40:47 - Updating systems & servers data ...
. 2016.07.21 13:40:48 - Systems & servers data update completed
I 2016.07.21 13:58:09 - Renewing TLS key
. 2016.07.21 13:58:09 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.21 13:58:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.21 13:58:11 - OpenVPN > Validating certificate key usage
. 2016.07.21 13:58:11 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.21 13:58:11 - OpenVPN > VERIFY KU OK
. 2016.07.21 13:58:11 - OpenVPN > Validating certificate extended key usage
. 2016.07.21 13:58:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.21 13:58:11 - OpenVPN > VERIFY EKU OK
. 2016.07.21 13:58:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.21 13:58:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 13:58:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 13:58:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.21 13:58:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 13:58:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.21 14:10:48 - Updating systems & servers data ...
. 2016.07.21 14:10:49 - Systems & servers data update completed
. 2016.07.21 14:35:18 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.07.21 14:35:18 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.07.21 14:35:18 - OpenVPN > Restart pause, 5 second(s)
! 2016.07.21 14:35:18 - Disconnecting
. 2016.07.21 14:35:18 - Management - Send 'signal SIGTERM'
. 2016.07.21 14:35:18 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.21 14:35:18 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.07.21 14:35:18 - OpenVPN > Assertion failed at misc.c:779
. 2016.07.21 14:35:18 - OpenVPN > Exiting due to fatal error
. 2016.07.21 14:35:18 - Connection terminated.
I 2016.07.21 14:35:18 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 14:35:18 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.21 14:35:49 - DHCP of a network adapter restored to original settings (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
! 2016.07.21 14:35:49 - Session terminated.
I 2016.07.21 14:35:54 - Session starting.
I 2016.07.21 14:35:54 - Network adapter DHCP switched to static (Qualcomm Atheros AR8161/8165 PCI-E Gigabit Ethernet Controller (NDIS 6.20))
I 2016.07.21 14:35:57 - Checking authorization ...
! 2016.07.21 14:36:19 - Connecting to Alshat (Netherlands, Alblasserdam)
. 2016.07.21 14:36:44 - SSL > 2016.07.21 14:36:19 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.21 14:36:44 - SSL > 2016.07.21 14:36:19 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.21 14:36:44 - SSL > 2016.07.21 14:36:19 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.21 14:36:44 - SSL > 2016.07.21 14:36:19 LOG5[ui]: Reading configuration from file C:\Users\J\AppData\Local\AirVPN\47d922b613f8294dc8c69dc54ed9a96e95b5981f175ea27423ecd1e24199752b.tmp.ssl
. 2016.07.21 14:36:44 - SSL > 2016.07.21 14:36:19 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.21 14:36:44 - SSL > 2016.07.21 14:36:19 LOG6[ui]: Initializing service [openvpn]
. 2016.07.21 14:36:45 - SSL > 2016.07.21 14:36:19 LOG5[ui]: Configuration successful
. 2016.07.21 14:36:45 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.21 14:36:45 - SSL > 2016.07.21 14:36:45 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:54025
. 2016.07.21 14:36:45 - SSL > 2016.07.21 14:36:45 LOG6[0]: Failover strategy: round-robin
. 2016.07.21 14:36:45 - SSL > 2016.07.21 14:36:45 LOG6[0]: s_connect: connecting 213.152.161.6:443
. 2016.07.21 14:36:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.21 14:36:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.21 14:36:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.21 14:36:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 14:36:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 14:36:45 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.21 14:36:45 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:50497 [nonblock]
. 2016.07.21 14:36:45 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:50497
. 2016.07.21 14:36:45 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.21 14:36:45 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:50497
. 2016.07.21 14:36:55 - SSL > 2016.07.21 14:36:55 LOG3[0]: s_connect: s_poll_wait 213.152.161.6:443: TIMEOUTconnect exceeded
. 2016.07.21 14:36:55 - OpenVPN > Connection reset, restarting [-1]
. 2016.07.21 14:36:55 - SSL > 2016.07.21 14:36:55 LOG5[0]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket
. 2016.07.21 14:36:55 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.07.21 14:36:55 - OpenVPN > Restart pause, 5 second(s)
! 2016.07.21 14:36:55 - Disconnecting
. 2016.07.21 14:36:55 - Connection terminated.
I 2016.07.21 14:36:58 - Checking authorization ...
! 2016.07.21 14:36:58 - Connecting to Tauri (Germany, Frankfurt)
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG5[ui]: Reading configuration from file C:\Users\J\AppData\Local\AirVPN\e578dcb3840f732250f5ee7e801238aee55613defd318b56c257d514a9d7115d.tmp.ssl
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG6[ui]: Initializing service [openvpn]
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG5[ui]: Configuration successful
. 2016.07.21 14:36:58 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.21 14:36:58 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.21 14:36:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.21 14:36:58 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.21 14:36:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 14:36:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 14:36:58 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.21 14:36:58 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:22800 [nonblock]
. 2016.07.21 14:36:58 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:22800
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:54051
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG6[0]: Failover strategy: round-robin
. 2016.07.21 14:36:58 - SSL > 2016.07.21 14:36:58 LOG6[0]: s_connect: connecting 46.165.208.106:443
. 2016.07.21 14:36:58 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.21 14:36:58 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:22800
. 2016.07.21 14:37:08 - SSL > 2016.07.21 14:37:08 LOG3[0]: s_connect: s_poll_wait 46.165.208.106:443: TIMEOUTconnect exceeded
. 2016.07.21 14:37:08 - SSL > 2016.07.21 14:37:08 LOG5[0]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket
. 2016.07.21 14:37:08 - OpenVPN > Connection reset, restarting [-1]
. 2016.07.21 14:37:08 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.07.21 14:37:08 - OpenVPN > Restart pause, 5 second(s)
! 2016.07.21 14:37:08 - Disconnecting
. 2016.07.21 14:37:08 - Connection terminated.
I 2016.07.21 14:37:11 - Checking authorization ...
! 2016.07.21 14:37:11 - Connecting to Tauri (Germany, Frankfurt)
. 2016.07.21 14:37:11 - SSL > 2016.07.21 14:37:11 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.07.21 14:37:11 - SSL > 2016.07.21 14:37:11 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.07.21 14:37:11 - SSL > 2016.07.21 14:37:11 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.07.21 14:37:11 - SSL > 2016.07.21 14:37:11 LOG5[ui]: Reading configuration from file C:\Users\J\AppData\Local\AirVPN\9d1c9399eaf6226955232d6f3cf583791f6c969bb7fb567d1783e32a3d273f2f.tmp.ssl
. 2016.07.21 14:37:11 - SSL > 2016.07.21 14:37:11 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.07.21 14:37:11 - SSL > 2016.07.21 14:37:11 LOG6[ui]: Initializing service [openvpn]
. 2016.07.21 14:37:11 - SSL > 2016.07.21 14:37:11 LOG5[ui]: Configuration successful
. 2016.07.21 14:37:12 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.21 14:37:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.21 14:37:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.21 14:37:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.21 14:37:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 14:37:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.21 14:37:12 - OpenVPN > Socket Buffers: R=[516096->131072] S=[172032->131072]
. 2016.07.21 14:37:12 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:40288 [nonblock]
. 2016.07.21 14:37:12 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:40288
. 2016.07.21 14:37:12 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.21 14:37:12 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:40288
. 2016.07.21 14:37:12 - SSL > 2016.07.21 14:37:12 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:54067
. 2016.07.21 14:37:12 - SSL > 2016.07.21 14:37:12 LOG6[0]: Failover strategy: round-robin
. 2016.07.21 14:37:12 - SSL > 2016.07.21 14:37:12 LOG6[0]: s_connect: connecting 46.165.208.106:443
I've already said that I think it's your security software.  Have you tested with all your Kaspersky (or any other 3rd party stuff) disabled?
As go558a83nk said, maybe you should check your antivirus/firewall exceptions lists; especially your firewall, if you're torrenting.
it's about some security software freaking out when all those UDP connections are made by torrenting.  at least that's what I remember from some previous problems that, if I recall correctly, were the same as this sounds.
Sounds reasonable. But you know, you can't tell a firewall a UDP joke, because they just don't get it.
