Zaroad
Unable to connect to Furud using SSL
Hi, I'm not able tu use Furud with SSL tunneling. Is anybody also getting 'TIMEOUTconnect exceeded' error?
I 2016.06.30 08:33:33 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.06.30 08:33:33 - Reading options from E:\Program Files\AirVPN\AirVPN.xml
. 2016.06.30 08:33:33 - Data Path: E:\Program Files\AirVPN
. 2016.06.30 08:33:33 - App Path: E:\Program Files\AirVPN
. 2016.06.30 08:33:33 - Executable Path: E:\Program Files\AirVPN\AirVPN.exe
. 2016.06.30 08:33:33 - Command line arguments (0):
. 2016.06.30 08:33:33 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.06.30 08:33:33 - Updating systems & servers data ...
. 2016.06.30 08:33:34 - Systems & servers data update completed
I 2016.06.30 08:33:34 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.06.30 08:33:34 - OpenVPN - Version: OpenVPN 2.3.8 (E:\Program Files\AirVPN\openvpn.exe)
I 2016.06.30 08:33:34 - SSH - Version: plink 0.63 (E:\Program Files\AirVPN\plink.exe)
I 2016.06.30 08:33:34 - SSL - Version: stunnel 5.17 (E:\Program Files\AirVPN\stunnel.exe)
! 2016.06.30 08:33:34 - Activation of Network Lock - Windows Firewall
! 2016.06.30 08:33:37 - Ready
. 2016.06.30 08:33:42 - Updating systems & servers data ...
. 2016.06.30 08:33:43 - Systems & servers data update completed
I 2016.06.30 08:34:14 - Session starting.
I 2016.06.30 08:34:14 - Checking authorization ...
! 2016.06.30 08:34:14 - Connecting to Furud (France, Villeneuve d'Ascq)
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:14 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:14 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:14 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:14 LOG5[ui]: Reading configuration from file E:\Program Files\AirVPN\2f5f8afd91e6a2d4c562d106a271082438dd771617860199673e155a8122bda3.tmp.ssl
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:14 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:15 LOG6[ui]: Initializing service [openvpn]
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:15 LOG5[ui]: Configuration successful
. 2016.06.30 08:34:15 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.06.30 08:34:15 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.30 08:34:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.30 08:34:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.30 08:34:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.30 08:34:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.30 08:34:15 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288]
. 2016.06.30 08:34:15 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:3642 [nonblock]
. 2016.06.30 08:34:15 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:3642
. 2016.06.30 08:34:15 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.06.30 08:34:15 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:3642
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:15 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49685
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:15 LOG6[0]: Failover strategy: round-robin
. 2016.06.30 08:34:15 - SSL > 2016.06.30 08:34:15 LOG6[0]: s_connect: connecting 46.29.125.15:443
. 2016.06.30 08:34:25 - SSL > 2016.06.30 08:34:25 LOG3[0]: s_connect: s_poll_wait 46.29.125.15:443: TIMEOUTconnect exceeded
. 2016.06.30 08:34:25 - OpenVPN > Connection reset, restarting [-1]
. 2016.06.30 08:34:25 - SSL > 2016.06.30 08:34:25 LOG5[0]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket
. 2016.06.30 08:34:25 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.06.30 08:34:25 - OpenVPN > Restart pause, 5 second(s)
! 2016.06.30 08:34:25 - Disconnecting
. 2016.06.30 08:34:25 - Connection terminated.
I 2016.06.30 08:34:27 - Cancel requested.
! 2016.06.30 08:34:27 - Session terminated.
Furud is the only server I can remember that has never worked with SSL for me
Where do one change entry IP for SSL?
Doesn't work for me either. But i think there is no real problem here. You can switch to Marfic or Thuban. Both servers do offer more bandwidth too. Furud has only 100MBit uplink. So you'll be better off connecting to Thuban or Marfic.
Regards
Fox
Furud is 1gbit but they can only guarantee 100mbit.
Furud is actually one of the very fastest servers for me
Anyone know why this is the only server that won't work with SSL?
Is it fixable?
One of the best servers for downloading stuff IME!
Is it fixable?  ;)
We are aware of the problem which is caused by a non-working IP address (null routed?). We have repeatedly contacted datacenter (ATE) support service (and other e-mail addresses of theirs) and they never replied. We are considering to drop them because of this intolerable lack of care.
