ragnar 0 Posted ... Firmware: DD-WRT v3.0-r29300M kongac (03/30/16) I have this router plugged into my Apple Airport Extreme which is setup as DHCP and NAT. I get pass-through traffic, however the VPN does not seem to be connecting. Quote Share this post Link to post
YLwpLUbcf77U 32 Posted ... I've the same router and am running DD-WRT w/ no issue using it as an Open VPN client with AirVPN. Differences from your screenshot and my setup: On my settings page, I have both Gateway and Local DNS set to 0.0.0.0DHCP Server, not Forwarder.My time settings are different though this is probably a non-issue.I'm connecting to an actual IP, not a hostname.TLS Cipher set to 'None'. Try giving those settings a shot though the issue could be your Apple Airport device blocking the VPN. Also check the DD-WRT VPN Status page and see what the logs say. Quote Share this post Link to post
zhang888 1067 Posted ... From your settings, it looks like you are trying to use TLS-RSA-WITH-AES-128-CBC-SHA.Switch it to TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 (or none, to negotiate it during the connection). For a complete manual, please look here:https://airvpn.org/ddwrt/ Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
ragnar 0 Posted ... It's still not working, I have attempted to use another server and the ddwrt router is connected straight into my cable modem from Comcast. Clientlog: 19700101 10:08:52 I OpenVPN 2.3.10 arm-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Mar 30 2016 19700101 10:08:52 I library versions: OpenSSL 1.0.2g 1 Mar 2016 LZO 2.09 19700101 10:08:52 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16 19700101 10:08:52 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 19700101 10:08:52 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible 19700101 10:08:52 W WARNING: Your certificate is not yet valid! 19700101 10:08:52 W WARNING: file '/tmp/openvpncl/ta.key' is group or others accessible 19700101 10:08:52 I Control Channel Authentication: using '/tmp/openvpncl/ta.key' as a OpenVPN static key file 19700101 10:08:52 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 19700101 10:08:52 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 19700101 10:08:52 Socket Buffers: R=[180224->180224] S=[180224->180224] 19700101 10:08:57 N RESOLVE: Cannot resolve host address: ch.vpn.airdns.org: Try again 19700101 10:09:02 N RESOLVE: Cannot resolve host address: ch.vpn.airdns.org: Try again 19700101 10:09:02 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:09:02 D MANAGEMENT: CMD 'state' 19700101 10:09:02 MANAGEMENT: Client disconnected 19700101 10:09:02 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:09:02 D MANAGEMENT: CMD 'state' 19700101 10:09:02 MANAGEMENT: Client disconnected 19700101 10:09:02 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:09:02 D MANAGEMENT: CMD 'state' 19700101 10:09:02 MANAGEMENT: Client disconnected 19700101 10:09:03 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:09:03 D MANAGEMENT: CMD 'status 2' 19700101 10:09:03 MANAGEMENT: Client disconnected 19700101 10:09:03 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:09:03 D MANAGEMENT: CMD 'log 500' 19700101 10:09:03 MANAGEMENT: Client disconnected 19700101 10:09:12 N RESOLVE: Cannot resolve host address: ch.vpn.airdns.org: Try again 19700101 10:09:22 N RESOLVE: Cannot resolve host address: ch.vpn.airdns.org: Try again 19700101 10:09:32 N RESOLVE: Cannot resolve host address: ch.vpn.airdns.org: Try again 19700101 10:09:42 NOTE: --mute triggered... 19700101 10:12:52 20 variation(s) on previous 3 message(s) suppressed by --mute 19700101 10:12:52 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:12:52 D MANAGEMENT: CMD 'state' 19700101 10:12:52 MANAGEMENT: Client disconnected 19700101 10:12:52 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:12:52 D MANAGEMENT: CMD 'state' 19700101 10:12:52 MANAGEMENT: Client disconnected 19700101 10:12:52 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:12:52 D MANAGEMENT: CMD 'state' 19700101 10:12:52 MANAGEMENT: Client disconnected 19700101 10:12:52 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:12:52 D MANAGEMENT: CMD 'status 2' 19700101 10:12:52 MANAGEMENT: Client disconnected 19700101 10:12:52 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19700101 10:12:52 D MANAGEMENT: CMD 'log 500' 19691231 19:00:00 ca /tmp/openvpncl/ca.crt cert /tmp/openvpncl/client.crt key /tmp/openvpncl/client.key management 127.0.0.1 16 management-log-cache 100 verb 3 mute 3 syslog writepid /var/run/openvpncl.pid client resolv-retry infinite nobind persist-key persist-tun script-security 2 dev tun1 proto udp cipher aes-256-cbc auth sha1 remote ch.vpn.airdns.org 443 comp-lzo no tun-mtu 1500 mtu-disc yes ns-cert-type server fast-io tun-ipv6 tls-auth /tmp/openvpncl/ta.key 1 Quote Share this post Link to post
zhang888 1067 Posted ... Now you have another (DNS) problem.Try using an IP address (46.19.137.114) instead of the ch.vpn.airdns.org hostname. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
ragnar 0 Posted ... I still get network unreachable. 19691231 19:03:19 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 19691231 19:03:19 Socket Buffers: R=[180224->180224] S=[180224->180224] 19691231 19:03:19 I UDPv4 link local: [undef] 19691231 19:03:19 I UDPv4 link remote: [AF_INET]46.19.137.114:443 19691231 19:03:19 N write UDPv4: Network unreachable (code=101) 19691231 19:03:22 N write UDPv4: Network unreachable (code=101) 19691231 19:03:23 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19691231 19:03:23 D MANAGEMENT: CMD 'state' 19691231 19:03:23 MANAGEMENT: Client disconnected 19691231 19:03:23 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19691231 19:03:23 D MANAGEMENT: CMD 'state' 19691231 19:03:23 MANAGEMENT: Client disconnected 19691231 19:03:23 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19691231 19:03:23 D MANAGEMENT: CMD 'state' 19691231 19:03:23 MANAGEMENT: Client disconnected 19691231 19:03:23 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19691231 19:03:23 D MANAGEMENT: CMD 'status 2' 19691231 19:03:23 MANAGEMENT: Client disconnected 19691231 19:03:23 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 19691231 19:03:23 D MANAGEMENT: CMD 'log 500' 19691231 19:00:00 Quote Share this post Link to post
ragnar 0 Posted ... On the settings page, I have DHCP Server turned on and 10.4.0.1 in the Static DNS 1 entry. Quote Share this post Link to post
zhang888 1067 Posted ... If you see a network unreachable message this means something on your WAN side is not functioning or misconfigured.This is not related to VPN, your router cannot reach the VPN server during the connection attempt. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
TonyM 0 Posted ... I personally have had many dns issues and nat issues with airvpn .I would suggest this as I have had a similar problem to what I see you having.First check the spec page and depending on your connection port example "443",use the dns in the first static box.For the second 2 boxes use 208.67.222.222 and 208.67.220.220.Then also make sure your ntp sever is set to enable of couse and that your router has the correct time.After all these simple checks and solutions,you should be up and running.Also update the ta cert with a new downloaded version as I have seen this fix the tls errors some get.Hope this helps. Quote Share this post Link to post
Staff 10387 Posted ... Hello! First you need to solve the most basic problem and only then a proper troubleshooting can be done, because the first failure may cause all the other apparent problems.19700101 10:08:52 W WARNING: Your certificate is not yet valid!Not only this means that your router date is wrong (preventing any successful handshake), but also that the router probably can't even reach an NTP server. Please check.Kind regards 2 LZ1 and Wolf666 reacted to this Quote Share this post Link to post
TonyM 0 Posted ... I am having an issue with DNS right now.Whenever I set the 10.5.0.1 as static in first slot and whatever other dns in 2nd and 3rd I am getting a tls error and log shows 1969 all the way down to bottom.I deleted the 10.5.0.1 and used just open dns in slot 1 and 2 and the error went away,it connected and date went back to normal except at bottom 1 entry says 1969 Quote Share this post Link to post
