Not connected, Your IP: 216.73.216.51
tusker
Can't connect normally after closing AirVPN session.
I was running AirVPN on my Surface Book. From the moment I disconnected I have been unable to connect to the internet (over WiFi) all my other devices connect fine to the router, so there is definitely no problem there. I have tried soft and hard reboots of the Surface but to no avail.
Hello !
I believe that's a common sort of bug and it's because the normal settings don't return after AirVPN has changed them.
You can try go to your adapter settings and setting your DNS servers and IP address and all that to obtain automatically .
Alternatively, you can go into the Eddie client and copy/paste the logs here for us to see. Just remember to use spoiler tags.
