DnrVDlmu8y
Label independent client configs with their geo-location
Currently, when you use the config generator, and you download specific servers, you get a long list of servers by their production name.
If possible, could you also add a location to make it easier for users to select a VPN server that would better suit them?
For instance, If I were located in the UK, a Miami or Chicago node might be better suited for me compared to a Los Angeles node (which is what my default American config generates).
Example
Original file name: AirVPN_US-Yildun_UDP-443
Revised file name: AirVPN_US_Miami-Yildun_UDP-443
Or something a long those lines, it would just make it so much easier when having to select a VPN node.
Hmm, yes, interesting suggestion
(Sent via Tapatalk - this generally means I'm not sitting in front of my PC)
