flat4 95 Posted ... connected to pollux from the central ok Down: 12.728 Mbit/s Out, 1.860 Mbit/s In (14%), 20MB - Up: 12.573 Mbit/s Out, 10.679 Mbit/s In (84%), 20MB - Date: Thu, 19 Feb 2015 19:10:45 GMT - Buffers: 20MB/20MB - Laps: 3, Time: 195.29 secs :no: Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
Tech Jedi Alex 1524 Posted ... What's your ISP, your OS, your client (with version)? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
flat4 95 Posted ... What's your ISP, your OS, your client (with version)? ATT (fiber) thru Quest, Windows 7 64 bit, Eddie client latest. To be clear I'm located in Central Oklahoma. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
Tech Jedi Alex 1524 Posted ... Please try to connect via SSH or SSL (Settings > Protocols). Post your results here. Note: A regular download of a big file, a linux distribution for example, can be more accurate if you want to determine your maximum download speed. 1 nexsteppe reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
flat4 95 Posted ... I will try and post the results Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
flat4 95 Posted ... WOW!! used SSL and that made a big differenceDown: 11.495 Mbit/s Out, 11.541 Mbit/s In (100%), 20MB - Up: 11.750 Mbit/s Out, 11.289 Mbit/s In (96%), 20MB - Date: Fri, 20 Feb 2015 21:14:33 GMT - Buffers: 20MB/20MB - Laps: 3, Time: 90.97 secs Why is that? Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
Staff 10465 Posted ... @flat4 Hello! The first possible reasons that come to mind:1) Your ISP performs traffic shaping against UDP and/or OpenVPN2) You have a tool in your router or in your computer that de-prioritizes UDP packets. In both cases, wrapping OpenVPN inside an additional TLS tunnel fixes the issue. However, if the problem lies in your system and you manage to solve it, you will have better performance with UDP direct connections than with OpenVPN over SSL, because of the overhead caused by two tunnels instead of one, and the important fact that OpenVPN is forced to work in TCP when it must connect to stunnel (since UDP can't be supported by stunnel). Kind regards 1 nexsteppe reacted to this Quote Share this post Link to post
flat4 95 Posted ... Thanks for the great info never thought that traffic shaping was being used but I'm not surprised. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
rainmakerraw 94 Posted ... Whenever I use the speed test on Air's website I only get results around 19 Megabits per second. I have a 160Mbps cable line and get full speed from Air's servers on real downloads (eg Ubuntu torrents). It can't be throttling/shaping from the ISP as real downloads give full speed. I guess a quirk of the site's tester? Maybe test your real world speed and see if it's much better than the test tool suggests. I know mine is! Quote Share this post Link to post
