Not connected, Your IP: 3.133.109.211
dwright
ANSWERED Problem connecting by country
Recently when I try to connect to a particular country, I get the following error:
Wed Sep 11 22:45:08 2013 OpenVPN 2.3.2 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jun  3 2013
Wed Sep 11 22:45:08 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25357
Wed Sep 11 22:45:08 2013 Need hold release from management interface, waiting...
Wed Sep 11 22:45:08 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25357
Wed Sep 11 22:45:09 2013 MANAGEMENT: CMD 'state on'
Wed Sep 11 22:45:09 2013 MANAGEMENT: CMD 'log all on'
Wed Sep 11 22:45:09 2013 MANAGEMENT: CMD 'hold off'
Wed Sep 11 22:45:09 2013 MANAGEMENT: CMD 'hold release'
Wed Sep 11 22:45:09 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Sep 11 22:45:09 2013 MANAGEMENT: >STATE:1378935909,RESOLVE,,,
Wed Sep 11 22:45:30 2013 RESOLVE: Cannot resolve host address: gb.vpn.airdns.org: No such host is known.
Wed Sep 11 22:45:30 2013 MANAGEMENT: >STATE:1378935930,RESOLVE,,,
Wed Sep 11 22:45:42 2013 RESOLVE: Cannot resolve host address: gb.vpn.airdns.org: No such host is known
I can connect when I select a specific server. eg Andromeda.
Anyone know why this has started happening all of a sudden? I did a TrueCrypt full disk encryption around the time it started, but I can't see how it would cause this...
Anyone know to fix?
The problems is:
Your DNS can't resolve that name. For our records, can you tell us which DNS your system is querying?
In order to solve the problem radically please re-generate the configuration file(s) in the following way:
- tick "Advanced Mode"
- tick "Resolved hosts in .ovpn files"
- tick "All servers for area or region"
In this way the Configuration Generator will insert only IP addresses (not names) in the configuration files.
Hi, thanks for the answer. I use the following DNS servers: 37.139.10.30 and 195.46.245.59. Is this the information you're looking for? I got them from OpenNIC.
Though, I've been using these DNS servers for a while and haven't had this problem. I'll regenerate my config files and see if it goes away.
