huckfinn 1 Posted ... I am new to AirVPN and VPNs in general. Last night I was able to connect to the service using my home computer without any problems. Today I am trying to connect using my office computer which passes through a network squid proxy but I have not been successful. As I looked at the programs installed by AirVPN I see that there are two: OpenVPN GUI and Air VPN. Both have settings for proxies. I've tried a combination of settings but nothing seems to work. AirVPN proxy setting activated + OpenVPN proxy setting activated (system settings)- Connection fails almost immediately. Log: 05/09/2013 - 10.39 Login... 05/09/2013 - 10.39 Login success. 05/09/2013 - 10.39 Contacting service... 05/09/2013 - 10.39 Connecting... 05/09/2013 - 10.39 xy MUST be used in TCP Client mode (i.e. --proto tcp-client) 05/09/2013 - 10.39 mation. 05/09/2013 - 10.39 Failed to start. AirVPN proxy setting None + OpenVPN proxy setting activated (system settings)- Connection attempt continues for a long time, without success. Log: 05/09/2013 - 10.44 Login... 05/09/2013 - 10.44 Login success. 05/09/2013 - 10.45 Contacting service... 05/09/2013 - 10.45 Connecting... 05/09/2013 - 10.45 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 05/09/2013 - 10.45 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 05/09/2013 - 10.45 Socket Buffers: R=[8192->8192] S=[8192->8192] 05/09/2013 - 10.45 UDPv4 link local: [undef] 05/09/2013 - 10.45 UDPv4 link remote: [AF_INET]119.81.1.122:443 05/09/2013 - 10.46 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 05/09/2013 - 10.46 TLS Error: TLS handshake failed AirVPN proxy setting None + OpenVPN proxy setting "Use OpenVPN config-file"- Connection attempt continues for a long time, without success.- I use port 80 thinking that it can more easily tunnel through the proxy. Log: 05/09/2013 - 10.48 Login... 05/09/2013 - 10.48 Login success. 05/09/2013 - 10.48 Contacting service... 05/09/2013 - 10.48 Connecting... 05/09/2013 - 10.48 OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 05/09/2013 - 10.48 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 05/09/2013 - 10.48 Socket Buffers: R=[8192->8192] S=[8192->8192] 05/09/2013 - 10.48 UDPv4 link local: [undef] 05/09/2013 - 10.48 UDPv4 link remote: [AF_INET]119.81.1.122:80 05/09/2013 - 10.49 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 05/09/2013 - 10.49 TLS Error: TLS handshake failed Any ideas? Thanks! Quote Share this post Link to post
Staff 9764 Posted ... Hello! You need to use TCP to connect to a proxy: just pick a TCP port. Socks and http proxies do not support UDP. Kind regards Quote Share this post Link to post
huckfinn 1 Posted ... Ok, now it works. Thanks! I have configured both the AirVPN and OpenVPN for connection through the proxy. Then when I open the connection, I chose a TCP port. It takes a bit of time to complete the connection (much longer than when I connect from home), but it works. The unexpected bonus is that I can configure one browser (i.e., Firefox) to use the company proxy so I'm using my company network and another browser/program (i.e., Chrome, uTorrent) to not use the company proxy and these pass through the VPN. So I can do two things at the same time. Very nice. Thanks again! 1 Staff reacted to this Quote Share this post Link to post
