Not connected, Your IP: 3.144.151.106
resettler
Comodo Firewall's default settings
I have just downloaded and installed the free version of Comodo Firewall (which is version 6.2).
Below are screen grabs of the firewall's default settings:
What I did was to remove all of them. Is that the correct way?
yes, no problems. Following the guide will make removal superfluous, anyway removal will do no harm.
