Not connected, Your IP: 216.73.216.28
trekkie.forever
ANSWERED Anti geo-location feature not working?
that's correct, please check the servers monitor ("Status" from the upper menu).
EDIT: the anti-geo block for BBC will be re-enabled as soon as the UK routing server datacenter solves the server issues.
BBC iPlayer seems to be down again from the US servers. Status says GB2 internal server is up.
Hello and thank you,
GB2 is up and running as you correctly noted but the the routing is not working from several servers. We're investigating.
Any luck on getting UK routing to work?
Apparently there's some new trick from BBC. Investigation goes on. Please connect to UK servers in the meantime.
