Not connected, Your IP: 216.73.217.175
EDIT 20:04 CET+1 06-May-13 Problem solved
We regret to inform you that we are currently experiencing DNS problems on the following servers in the Netherlands:
  • Ophiuchi
  • Leporis
  • Lyncis
  • Orionis
  • Castor
  • Corvi
The problem affects DNS resolution. You might be unable to resolve some (and only some) names with our internal DNS (10.4.0.1, 10.5.0.1, ... , 10.9.0.1).
The problem is external: it is not caused by our DNS or configuration. We're anyway working to solve it as soon as possible.
In the meantime, as a momentary work-around (not compromising security):
  • on Linux, OpenBSD and FreeBSD, just set a public DNS on your nameservers list after the connection. Example: in /etc/resolv.conf add the line "nameserver "
  • on Windows, on your TAP-Win32 network interface (NOT on your physical network card) after the connection set preferred and alternate DNS IP address
  • alternatively, simply connect to any of our servers not included in the above list
We will update this post as soon as the problem is solved. We apologize for the inconvenience not caused by us.
