Not connected, Your IP: 18.117.216.229
drewwheelerosman
Internet pages will not load
I connect to a server on airvpn then when i try load google the page doesn't load
Can you please send us your client logs? What is your OS?
Hi
my OS is windows 7
and i dont now where to find my client logs ( im new to this )
Please right-click on the Air client dock icon, select "Logs" and click on "Copy to clipboard", finally paste here.
13/03/2013 - 19:34 AirVPN client version: 1.8
13/03/2013 - 19:34 Reading options from C:\Users\Samsung\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
13/03/2013 - 19:34 OpenVPN bundle version: OpenVPN 2.3.0
13/03/2013 - 19:34 OpenVPN current version: OpenVPN 2.3.0
13/03/2013 - 19:34 Ready.
13/03/2013 - 19:34 Login...
13/03/2013 - 19:34 Login success.
13/03/2013 - 19:34 Contacting service...
13/03/2013 - 19:34 Connecting...
13/03/2013 - 19:34 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
13/03/2013 - 19:34 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
13/03/2013 - 19:34 Socket Buffers: R=[8192->8192] S=[8192->8192]
13/03/2013 - 19:34 UDPv4 link local: [undef]
13/03/2013 - 19:34 UDPv4 link remote: [AF_INET]94.242.205.234:443
13/03/2013 - 19:34 TLS: Initial packet from [AF_INET]94.242.205.234:443, sid=4348cae4 5dc870e7
13/03/2013 - 19:35 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
13/03/2013 - 19:35 VERIFY OK: nsCertType=SERVER
13/03/2013 - 19:35 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
13/03/2013 - 19:35 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
13/03/2013 - 19:35 TLS Error: TLS handshake failed
13/03/2013 - 19:35 SIGUSR1[soft,tls-error] received, process restarting
13/03/2013 - 19:35 Restart pause, 2 second(s)
13/03/2013 - 19:35 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
13/03/2013 - 19:35 Socket Buffers: R=[8192->8192] S=[8192->8192]
13/03/2013 - 19:35 UDPv4 link local: [undef]
13/03/2013 - 19:35 UDPv4 link remote: [AF_INET]94.242.205.234:443
13/03/2013 - 19:35 TLS: Initial packet from [AF_INET]94.242.205.234:443, sid=dbf7cf69 ed1e5a0f
13/03/2013 - 19:36 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
13/03/2013 - 19:36 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
13/03/2013 - 19:36 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
13/03/2013 - 19:36 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
13/03/2013 - 19:36 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
13/03/2013 - 19:36 [server] Peer Connection Initiated with [AF_INET]94.242.205.234:443
13/03/2013 - 19:36 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
13/03/2013 - 19:36 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.30.58 10.4.30.57'
13/03/2013 - 19:36 OPTIONS IMPORT: timers and/or timeouts modified
13/03/2013 - 19:36 OPTIONS IMPORT: LZO parms modified
13/03/2013 - 19:36 OPTIONS IMPORT: --ifconfig/up options modified
13/03/2013 - 19:36 OPTIONS IMPORT: route options modified
13/03/2013 - 19:36 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
13/03/2013 - 19:36 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
13/03/2013 - 19:36 open_tun, tt->ipv6=0
13/03/2013 - 19:36 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{CEFA63B2-CEFF-4272-9E59-8A21CC90D50A}.tap
13/03/2013 - 19:36 TAP-Windows Driver Version 9.9
13/03/2013 - 19:36 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.30.58/255.255.255.252 on interface {CEFA63B2-CEFF-4272-9E59-8A21CC90D50A} [DHCP-serv: 10.4.30.57, lease-time: 31536000]
13/03/2013 - 19:36 Successful ARP Flush on interface [21] {CEFA63B2-CEFF-4272-9E59-8A21CC90D50A}
13/03/2013 - 19:36 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
13/03/2013 - 19:36 C:\windows\system32\route.exe ADD 94.242.205.234 MASK 255.255.255.255 192.168.0.1
13/03/2013 - 19:36 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
13/03/2013 - 19:36 Route addition via IPAPI succeeded [adaptive]
13/03/2013 - 19:36 C:\windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.30.57
13/03/2013 - 19:36 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
13/03/2013 - 19:36 C:\windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.30.57
13/03/2013 - 19:36 C:\windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.30.57
13/03/2013 - 19:36 Initialization Sequence Completed
13/03/2013 - 19:36 Starting Management Interface...
13/03/2013 - 19:36 Checking...
13/03/2013 - 19:37 Retrieve statistics...
13/03/2013 - 19:37 Connected.
In the first part of the logs apparently something was blocking UDP packets, but after that the logs show no problems at all.
Let's see if it's a DNS problem. Please open a command prompt or the PowerShell, issue the following commands and send us the output:
ping 10.4.0.1
ping airvpn.org
ping 8.8.8.8
ping 10.4.0.1 > with 32bit data sent = 4 received = 0 ( loss 100% )
ping airvpn.org > Ping statistics for 85.17.207.151:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 43ms, Maximum = 46ms, Average = 44ms
ping 8.8.8.8 > Ping statistics for 8.8.8.8:
Minimum = 41ms, Maximum = 44ms, Average = 42ms
Microsoft Windows [Version 6.1.7601]
Copyright © 2009 Microsoft Corporation. All rights reserve
C:\Users\Samsung>ping 10.4.0.1
Pinging 10.4.0.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.4.0.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Samsung>ping airvpn.org
Pinging airvpn.org [85.17.207.151] with 32 bytes of data:
Reply from 85.17.207.151: bytes=32 time=44ms TTL=48
Reply from 85.17.207.151: bytes=32 time=43ms TTL=48
Minimum = 43ms, Maximum = 44ms, Average = 43ms
C:\Users\Samsung>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=43ms TTL=45
Reply from 8.8.8.8: bytes=32 time=42ms TTL=45
Minimum = 42ms, Maximum = 43ms, Average = 42ms
@drewwheelerosman
From the second post you published everything seems fine. Can you also send us the output of
ping google.com
as usual while you are connected to the VPN.
