bgulebian 0 Posted ... I have been using AirVPN with no issues until today. I have not changed anything on my computer or router so no reason for this to happen. I can log in to see the servers, but I cannot connect to them. Any help would be appreciated! Log report: 12/31/2012 - 9:03 PM AirVPN client version: 1.7 12/31/2012 - 9:03 PM Reading options from C:\Users\Bryan\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 12/31/2012 - 9:03 PM OpenVPN bundle version: OpenVPN 2.2.2 12/31/2012 - 9:03 PM OpenVPN current version: OpenVPN 2.2.2 12/31/2012 - 9:03 PM Ready. 12/31/2012 - 9:03 PM Login... 12/31/2012 - 9:04 PM Login success. 12/31/2012 - 9:04 PM Contacting service... 12/31/2012 - 9:04 PM Connecting... 12/31/2012 - 9:04 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 12/31/2012 - 9:04 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 12/31/2012 - 9:04 PM LZO compression initialized 12/31/2012 - 9:04 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 12/31/2012 - 9:04 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 12/31/2012 - 9:04 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 12/31/2012 - 9:04 PM Local Options hash (VER=V4): '22188c5b' 12/31/2012 - 9:04 PM Expected Remote Options hash (VER=V4): 'a8f55717' 12/31/2012 - 9:04 PM UDPv4 link local: [undef] 12/31/2012 - 9:04 PM UDPv4 link remote: 108.59.8.147:443 12/31/2012 - 9:04 PM TLS: Initial packet from 108.59.8.147:443, sid=2b2cd2d1 e89d3dfe Quote Share this post Link to post
Staff 9764 Posted ... Hello! It seems that you don't get a reply from Sirius. However we do not detect any problem with it, clients are connected and are connecting just fine on port 443 UDP and any other port. Can you please try to change connection port and also try connections to different servers? Kind regards Quote Share this post Link to post
bgulebian 0 Posted ... I change servers nd get the same issue: 12/31/2012 - 9:26 PM AirVPN client version: 1.7 12/31/2012 - 9:26 PM Reading options from C:\Users\Bryan\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 12/31/2012 - 9:26 PM OpenVPN bundle version: OpenVPN 2.2.2 12/31/2012 - 9:26 PM OpenVPN current version: OpenVPN 2.2.2 12/31/2012 - 9:26 PM Ready. 12/31/2012 - 9:26 PM Login... 12/31/2012 - 9:26 PM Login success. 12/31/2012 - 9:26 PM Contacting service... 12/31/2012 - 9:26 PM Connecting... 12/31/2012 - 9:26 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 12/31/2012 - 9:26 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 12/31/2012 - 9:26 PM LZO compression initialized 12/31/2012 - 9:26 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 12/31/2012 - 9:26 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 12/31/2012 - 9:26 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 12/31/2012 - 9:26 PM Local Options hash (VER=V4): '22188c5b' 12/31/2012 - 9:26 PM Expected Remote Options hash (VER=V4): 'a8f55717' 12/31/2012 - 9:26 PM UDPv4 link local: [undef] 12/31/2012 - 9:26 PM UDPv4 link remote: 108.59.11.194:443 12/31/2012 - 9:26 PM TLS: Initial packet from 108.59.11.194:443, sid=5594b0ac 57520682 12/31/2012 - 9:27 PM Disconnecting... 12/31/2012 - 9:27 PM Disconnected. Quote Share this post Link to post
Staff 9764 Posted ... Hello! Apparently it is a problem on your end, all the VPN servers are up and running. Might there be anything blocking outbound port 443 UDP? What happens if you try connections to port 80 TCP and 53 UDP? Kind regards Quote Share this post Link to post
bgulebian 0 Posted ... ok strange, I ran a test for the port: Port Status Protocol and Application 443 OPEN! https http protocol over TLS/SSL So according to what I can see, I can access the port no problem. Quote Share this post Link to post
Staff 9764 Posted ... ok strange, I ran a test for the port:Port Status Protocol and Application443 OPEN! httpshttp protocol over TLS/SSLSo according to what I can see, I can access the port no problem.Hello!That's 443 TCP, not 443 UDP.What happens if you try connections to different ports, for example 80 TCP and 53 UDP (and yes, also 443 TCP)?Kind regards Quote Share this post Link to post
Staff 9764 Posted ... ok, how do I change it?Hello!Pick a server and before the connection please click on the "Modes" tab and select a port. Then click "Enter".Kind regards Quote Share this post Link to post
bgulebian 0 Posted ... ok I tried this, on udp 80, udp 443 and tcp 80. Same issue exists, just hangs. I double checked my firewall and even turned it off, still same issue. Quote Share this post Link to post
Staff 9764 Posted ... ok I tried this, on udp 80, udp 443 and tcp 80. Same issue exists, just hangs. I double checked my firewall and even turned it off, still same issue.Hello!Apparently something is blocking openvpn.exe packets (but not airvpn.exe, otherwise you would not even see the servers list). Do you have any antivirus or any other program running which might interfere? Is your system able to ping the servers IP addresses you're trying to connect to?Kind regards Quote Share this post Link to post
bgulebian 0 Posted ... I can ping the IP of the servers. I do not have any antivirus on the system, and I turned the firewall off to make sure. Quote Share this post Link to post
