aliboy 0 Posted ... hello First of all,Thanks to all developers & contributors! (airvpn.org). I am using airvpn packages but I use the tips below. here ( Briefly : To import the configuration file, open NetworkManager and go to VPN Connections > Configure VPN. Locate the file air.ovpn that you have just unzipped. Click Open. A new window will open. Leave everything as it is and click Apply. ) when I'm going to connect my vpn , any message will not be. Repeat several times in different ways, but I still did not answer. I do not know what I should do? thanks! Quote Share this post Link to post
aliboy 0 Posted ... hello Administrator Sorry I think as I've done wrong post. If possible, be transferred to AirVPN Client. Sorry Quote Share this post Link to post
Staff 9777 Posted ... aliboy wrote:hello First of all,Thanks to all developers & contributors! (airvpn.org). I am using airvpn packages but I use the tips below.here ( Briefly : To import the configuration file, open NetworkManager and go to VPN Connections > Configure VPN. Locate the file air.ovpn that you have just unzipped. Click Open. A new window will open. Leave everything as it is and click Apply. ) when I'm going to connect my vpn , any message will not be. Repeat several times in different ways, but I still did not answer.I do not know what I should do?thanks!Hello!Could you please provide us with the complete OpenVPN connection logs?Thank you.Kind regardsAirVPN admins Quote Share this post Link to post
aliboy 0 Posted ... hello terminal: tail -f /var/log/daemon.log output: 1- UDPv4 link remote: [AF_INET] 94.75.255.91:443 2- <warn> VPN connection 'air' (IP Config Get) timeout exceeded. 3- SIGTERM[hard,] received, process exiting 4- <info> Policy set 'xxxxxx' (eth1) as default for IPv4 routing and DNS. note: xxxxxx is ssid. (network wireless) thanks Quote Share this post Link to post
aliboy 0 Posted ... hello Whole logs placed here. ( tail -f /var/log/daemon.log ) This link is valid for one month. thanks! Quote Share this post Link to post
Staff 9777 Posted ... aliboy wrote:helloWhole logs placed here. ( tail -f /var/log/daemon.log )This link is valid for one month.thanks!Hello!Looking at the logs, it appears that the problem lies in missing configuration file and/or missing certificate. Can you please make sure that ALL the files inside air.zip have been copied and pasted in the proper directory?Kind regardsAirVPN admins Quote Share this post Link to post
aliboy 0 Posted ... ok: Whether the files are copied to a particular path? Import: Quote Share this post Link to post
aliboy 0 Posted ... hello Whether the files are copied to a particular path ? No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. What should I do? thanks Quote Share this post Link to post
Staff 9777 Posted ... aliboy wrote:helloWhether the files are copied to a particular path ? No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.What should I do? thanksHello!Copy all the files inside air.zip and paste them in the OpenVPN configuration directory (usually /etc/openvpn). See also https://airvpn.org/index.php?option=com_content&view=article&id=67&Itemid=124Kind regardsAirVPN admins Quote Share this post Link to post
aliboy 0 Posted ... Hello! Copy all the files inside air.zip and paste them in the OpenVPN configuration directory (usually /etc/openvpn). See also airvpn.org/index.php?option=com_content&...id=67&Itemid=124 Kind regards AirVPN admins hello I did the settings again. I read these pages. here and here A new error is shown : VPN connection failed : Quote Share this post Link to post
