Heya,
I was using until now HideMyAss VPN in order to watch TV via Zattoo (by connecting to Switzerland servers)
I just subscribed at AirVPN and Zattoo tells me that the view is restricted from my location. Is the .CH server from AirVPN being blocked?
Heya,
Thank you for the information, we'll investigate accordingly.
It seems to be restricted indeed. I can access Zattoo when I`m connected to a German VPN server (however this does not solve my problem because you get more channels to view when being connected to a Switzerland server )
Please let me if you can solve this.
It seems to be restricted indeed. I can access Zattoo when I`m connected to a German VPN server (however this does not solve my problem because you get more channels to view when being connected to a Switzerland server :) )
You're right. We are working on that.
any updates here? i really made the subscription for 12 months only to watch this zatoo
Still working on it, we should have found a solution. We'll keep you informed, it should take just a couple of days from now. The core problem we are facing is that Zattoo blacklists a lot of Swiss datacenters IP addresses (while in Germany there are no problems, but there are less channels available).
Still not working after more than a few days. Also, maybe it is just me, but the speed I'm getting on the swiss server is barely able to sustain streaming video (<1Mb/s)
same issue here :( any progress?
We have been unable to find any provider in Switzerland which is not blocked by Zattoo, unfortunately.
with Switzerland VPN is not blocked by Zatoo,
how?
They use the very same datacenter where Virginis is located, probably they have the luck that some IP blocks are not blocked by Zattoo.
I am on Virginis in Switzerland and get the message " Entschuldigung, Zattoo ist in Ihrem Land noch nicht verfügbar." from Zattoo
