Not connected, Your IP: 3.14.246.254
Lg3540
ServeToMe Please help
I am trying to use ServeToMe thru AirVPN outside my network (3G Ipad), and for some reason is not working for me. It does work within my network. I use airport extreme.
Please help.
Please help.
Please make sure that ServeToMe listens to the same port you have remotely forwarded. After that, you can reach a service behind a VPN server at the following address:
For example, if the device where ServeToMe runs is connected to Leonis and ServeToMe listens to port 12345, you can point to:
85.17.20.219:12345
See also:
http://www.ehow.com/how_8683578_streamtome-enabled-over-3g.html
