Hello. I read that connecting to AirVPN using port UDP 53 instead of UDP 443 is a way to get better speeds, but when I tried to do it today it could not connect to that port on any server and kept giving me an error. This happened on both my phone (connected with Wi-Fi) and PC (connected with ethernet cable) . I contacted my ISP and asked them if they were blocking any ports, and they said they were only blocking ports 80 and 25. I had the ISP unblock these ports just in case that was somehow the issue, but it was not and VPN on UDP 53 continued to not work. I even tried forwarding UDP port 53 to my devices from my router, but that didn't do anything. However, when I turn off Wi-Fi on my phone and connect to my mobile network, UDP 53 works flawlessly.
Here is a log of me trying to connect to an AirVPN server on port UDP 53 on my Wi-Fi using my android phone and the Eddie for Android app
Eddie for Android 1.0 RC 2 Version Code 5
09 Aug 2018 19:23:52 UTC [debug] NativeMethods.OVPN3.Init succeeded (version=3)
09 Aug 2018 19:23:52 UTC [info] Network is connected to WIFI
09 Aug 2018 19:23:52 UTC [debug] VPNService.NetworkStatusChanged: action='RESUME'
09 Aug 2018 19:24:03 UTC [info] Network is connected to WIFI
09 Aug 2018 19:24:03 UTC [debug] VPNService.NetworkStatusChanged: action='RESUME'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'tls_version_min:tls_1_0'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'protocol:'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'ipv6:yes'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'timeout:30'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'tun_persist:true'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'compression_mode:yes'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'synchronous_dns_lookup:false'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'autologin_sessions:true'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'disable_client_cert:false'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'ssl_debug_level:0'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'default_key_direction:-1'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'force_aes_cbc_ciphersuites:false'
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: ovpn3_client_set_option '1' - 'tls_cert_profile:'
09 Aug 2018 19:24:04 UTC [info] Eddie Native Library: client '1' starting
09 Aug 2018 19:24:04 UTC [info] Eddie Native Library: loading profile
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.protoOverride:
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.connTimeout: 30
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.compressionMode: yes
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.ipv6: yes
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.tlsVersionMinOverride: tls_1_0
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.tlsCertProfileOverride:
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.disableClientCert: false
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.proxyHost:
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.proxyPort:
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.proxyAllowCleartextAuth: false
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.defaultKeyDirection: -1
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.forceAesCbcCiphersuites: false
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.sslDebugLevel: 0
09 Aug 2018 19:24:04 UTC [debug] DoUpdate - Begin
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.autologinSessions: true
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.tunPersist: true
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: config.synchronousDnsLookup: false
09 Aug 2018 19:24:04 UTC [info] Eddie Native Library: profile loaded, connecting to server
09 Aug 2018 19:24:04 UTC [info] Eddie Native Library: connect_attach
09 Aug 2018 19:24:04 UTC [debug] OnConnectAttach
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: Frame=512/2048/512 mssfix-ctrl=1250
09 Aug 2018 19:24:04 UTC [debug] OpenVPN Event: type=RESOLVE, name=RESOLVE, info=, data=0
09 Aug 2018 19:24:04 UTC [info] Eddie Native Library: connect_pre_run
09 Aug 2018 19:24:04 UTC [debug] OnConnectPreRun
09 Aug 2018 19:24:04 UTC [info] Eddie Native Library: connect_run
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: Contacting 107.150.23.66:53 via UDP
09 Aug 2018 19:24:04 UTC [debug] OpenVPN Event: type=WAIT, name=WAIT, info=, data=0
09 Aug 2018 19:24:04 UTC [info] Eddie Native Library: socket_protect(socket=81)
09 Aug 2018 19:24:04 UTC [debug] OnSocketProtect(socket=81)
09 Aug 2018 19:24:04 UTC [info] OpenVPN3: Connecting to [107.150.23.66]:53 (107.150.23.66) via UDPv4
09 Aug 2018 19:24:14 UTC [info] OpenVPN3: Server poll timeout, trying next remote entry...
09 Aug 2018 19:24:14 UTC [debug] OpenVPN Event: type=RECONNECTING, name=RECONNECTING, info=, data=0
09 Aug 2018 19:24:14 UTC [info] OpenVPN3: Contacting 107.150.23.66:53 via UDP
09 Aug 2018 19:24:14 UTC [debug] OpenVPN Event: type=WAIT, name=WAIT, info=, data=0
09 Aug 2018 19:24:14 UTC [info] Eddie Native Library: socket_protect(socket=77)
09 Aug 2018 19:24:14 UTC [debug] OnSocketProtect(socket=77)
09 Aug 2018 19:24:14 UTC [info] OpenVPN3: Connecting to [107.150.23.66]:53 (107.150.23.66) via UDPv4
09 Aug 2018 19:24:24 UTC [info] OpenVPN3: Server poll timeout, trying next remote entry...
09 Aug 2018 19:24:24 UTC [debug] OpenVPN Event: type=RECONNECTING, name=RECONNECTING, info=, data=0
09 Aug 2018 19:24:24 UTC [info] OpenVPN3: Contacting 107.150.23.66:53 via UDP
09 Aug 2018 19:24:24 UTC [debug] OpenVPN Event: type=WAIT, name=WAIT, info=, data=0
09 Aug 2018 19:24:24 UTC [info] Eddie Native Library: socket_protect(socket=77)
09 Aug 2018 19:24:24 UTC [debug] OnSocketProtect(socket=77)
09 Aug 2018 19:24:24 UTC [info] OpenVPN3: Connecting to [107.150.23.66]:53 (107.150.23.66) via UDPv4
09 Aug 2018 19:24:34 UTC [error] OpenVPN3 CONNECTION_TIMEOUT: CONNECTION_TIMEOUT
09 Aug 2018 19:24:34 UTC [info] VPN error detected. Locking VPN
09 Aug 2018 19:24:34 UTC [info] Eddie Native Library: client '1' pausing
09 Aug 2018 19:24:34 UTC [info] Eddie Native Library: client '1' paused
09 Aug 2018 19:24:34 UTC [info] VPN locked
09 Aug 2018 19:24:34 UTC [info] Eddie Native Library: tun_builder_teardown(disconnect=false)
09 Aug 2018 19:24:34 UTC [debug] OnTunBuilderTeardown(disconnect=0)
09 Aug 2018 19:24:34 UTC [warning] OpenVPN DISCONNECTED - DISCONNECTED:
09 Aug 2018 19:24:34 UTC [debug] OnConnectRun
09 Aug 2018 19:24:34 UTC [info] Eddie Native Library: OpenVPN3 client started
09 Aug 2018 19:24:34 UTC [info] Eddie Native Library: client '1' started
09 Aug 2018 19:24:34 UTC [info] Eddie Native Library: client '1' stopping
09 Aug 2018 19:24:34 UTC [info] Eddie Native Library: client '1' stopped
09 Aug 2018 19:24:34 UTC [debug] ClearContexts
09 Aug 2018 19:24:35 UTC [error] Exception: client not initialized (Eddie.NativeAndroidApp.OpenVPNDispatcher.Run)
I would highly appreciate if a fix for this issue could be found, thank you.
