Rausgelost 0 Posted ... Hi AirVPN support and users, about two weeks ago, watching rai.it live TV via AirVPN stopped working. {EDIT: resolved} I always get the message that the content I want to stream is only available for people living in Italy. Since this week, also mediaset.it stopped working. The mediaset player however is reporting the following error: "The media playback was aborted because too many consecutive download errors occurred.". The setup (Linux with OpenVPN) itself didn't changed. The nameserver is correctly set in the resolv.conf file (to 10.4.0.1). Is there are problem with the routing? Can anybody confirm this problem? Thanks in advance Quote Share this post Link to post
Staff 9764 Posted ... Hello!We do not see this problem with RAI (tested from a few random servers around the world). Can you list the server(s) you experience this problem on? Mediaset problem is confirmed and we're checking. Kind regards Quote Share this post Link to post
Rausgelost 0 Posted ... Hello!We do not see this problem with RAI (tested from a few random servers around the world). Can you list the server(s) you experience this problem on? Mediaset problem is confirmed and we're checking. Kind regards Thanks for your quick answer. I'm using all servers provided by AirVPN in Germany. With that being said, the remove entry in the OpenVPN is: remote de.vpn.airdns.org 443 Is there any ETA for a fix with Mediaset? Best regards Quote Share this post Link to post
Staff 9764 Posted ... Hello! We confirm that we can't see any problem with RAI. About Mediaset, we should have sorted the issue out, can you please try now? Kind regards Quote Share this post Link to post
Rausgelost 0 Posted ... Sadly, I still get the "The media playback was aborted because too many consecutive download errors occurred." error for Mediaset. Also rai live streams doesn't work. They still block me with a notification that I try to access the live stream as a non Italian. Maybe the following traceroute snippet gives you more information although I don't see a problem here: [...] 4 po-102.agg01.fra-10.leaseweb.net (31.31.38.146) 32.819 ms po-101.agg01.fra-12.leaseweb.net (31.31.38.100) 34.632 ms po-101.agg01.fra-10.leaseweb.net (31.31.38.144) 35.966 ms 5 et-50-1.agg02.ams-01.leaseweb.net (31.31.34.28) 43.624 ms et-51-1.agg01.ams-01.leaseweb.net (31.31.34.26) 45.969 ms et-50-1.agg02.ams-01.leaseweb.net (31.31.34.28) 46.563 ms 6 be-31.bb03.ams-01.leaseweb.net (31.31.34.115) 50.041 ms ae-42.bb04.ams-01.leaseweb.net (31.31.34.35) 26.882 ms be-31.bb03.ams-01.leaseweb.net (31.31.34.115) 28.125 ms 7 xe-7-0-14-0.ams-koo-score-2-re0.interoute.net (84.233.190.45) 29.688 ms xe-2-1-2-0.ams-koo-score-1-re0.interoute.net (84.233.190.41) 31.091 ms 32.394 ms 8 ae1-0.fra-006-score-1-re0.interoute.net (84.233.190.50) 59.685 ms 60.981 ms 62.318 ms 9 ae1-0.fra-006-score-1-re0.interoute.net (84.233.190.50) 63.399 ms ae1-0.mil-cal-score-1-re0.interoute.net (89.202.146.89) 66.590 ms 67.999 ms 10 ae1-0.mil-cal-score-1-re0.interoute.net (89.202.146.89) 69.128 ms ae0-0.mil-cal-score-2-re0.interoute.net (89.202.146.86) 44.726 ms ae1-0.mil-cal-score-1-re0.interoute.net (89.202.146.89) 54.906 ms 11 ae2-0.rom-cor-score-1-re0.interoute.net (89.202.146.162) 56.313 ms 57.818 ms 59.420 ms 12 ae2-0.rom-cor-score-1-re0.interoute.net (89.202.146.162) 53.496 ms 54.882 ms 89.202.196.122 (89.202.196.122) 57.635 ms 13 212.162.64.154 (212.162.64.154) 58.269 ms 212.162.64.146 (212.162.64.146) 60.060 ms 89.202.196.122 (89.202.196.122) 61.045 ms 14 * 212.162.64.154 (212.162.64.154) 63.955 ms 65.542 ms [...] Which VPN servers did you tried? Also the German once? Is there are a homepage where I can check my settings (network, browser, etc.) so that I'm able to see where the problem lies down with Rai? EDIT: I can confirm that both works (Mediaset and Rai), when I'm using the servers in Netherlands (the generated filename is AirVPN_Netherlands_UDP-443.ovpn). Using the AirVPN_Germany_UDP-443.ovpn file still results in the error above. Quote Share this post Link to post
Rausgelost 0 Posted ... Sorry to bother you again but RAI is blocked once more. I've tested Europe, Germany and Netherlands and with all three of them I get the information screen from RAI telling me that the content is only available within Italy. Mediaset however still works. Quote Share this post Link to post
Staff 9764 Posted ... Hello! We confirm that, unfortunately, RAI is no more accessible from our infrastructure. Kind regards Quote Share this post Link to post
Rausgelost 0 Posted ... Hello! We confirm that, unfortunately, RAI is no more accessible from our infrastructure. Kind regards Thanks as always for your quick answer. Is there an ETA when this will be fixed? Quote Share this post Link to post
Staff 9764 Posted ... Hello! We confirm that, unfortunately, RAI is no more accessible from our infrastructure. Kind regards Thanks as always for your quick answer. Is there an ETA when this will be fixed? Hello! We prefer to not promise anything because the block might be pertaining to all IP addresses which have not been assigned to Italy residential ISPs, in which case we would be unable to resolve the bloc, unfortunately. Kind regards Quote Share this post Link to post
Member 0 Posted ... Hi,any follow-up on this issue? RAI content still not accessible. Thanks for your work. Best, Quote Share this post Link to post
poppybeano 0 Posted ... RAIPLAY is not accessible out side ITALY, is this something you can fix on your end or is RAI blocking VPN access? Quote Share this post Link to post
Staff 9764 Posted ... Hello! RAI is restricting access to IP addresses that have been assigned to Italian residential ISPs, so RAI is no more accessible from our infrastructure. Kind regards Quote Share this post Link to post
Staff 9764 Posted ... Hello! Unfortunately not, we're terribly sorry. Kind regards Quote Share this post Link to post
dhopper 0 Posted ... Hello! Unfortunately not, we're terribly sorry. Kind regards Well come on folks, this is becoming more of an issue everywhere, you need to come up with creative solutions, keep us one step ahead of the enemy. If you are always going to shrug then you will soon have no business. Quote Share this post Link to post
hydrotux 3 Posted ... Hi, this is really frustrating not being able to access Italian TV from abroad. Mediaset is able to detect that I'm connecting from abroad even though all my traffic is through AIrVPN. I thought the AirVPN outing servers were suppose to avoid the destination server seeing my real country of origin? Quote Share this post Link to post
Staff 9764 Posted ... @hydrotux Yes, but some services restrict streaming to IP addresses assigned to residential ISPs. Any IP address, even geo-located in Italy, not assigned to some residential ISP is treated as a foreign address. That said, RAI programs are perfectly accessible from all of our VPN servers. Kind regards Quote Share this post Link to post
