Not connected, Your IP: 18.216.94.152
ronanjames
ANSWERED Ctrl+C doesn't disconnect when using eddie-ui -cli
Hi
I am using eddie-ui 2.14.5 on ubuntu 18.04.
I was used to start eddie from the terminal using the command:  eddie-ui -cli -netlock -connect
Then when i wanted to disconnect, I used to do Ctrl+c and it would shutdown the connection and then kill the process.
But now using ctrl+c doesn't  work anymore. It just get me back to the terminal but the process is still running in the background. I need to use "pkill -f eddie" to kill the process.
Is this normal or is this a bug?
I tried on Kali and i have the same issue.
thanks
I have the same problem on ubuntu 18.04.1 running eddie-ui 2.15.2.
Tried to run it with --batch=false, but it made no difference.
Bug confirmed. It affects version 2.16.1 as well. It's a regression because it did not affect Eddie 2.13.6. We have informed the devs to have it patched asap.
