gorix 0 Posted ... hi, guys need your help here. mind doesnt work i got this problem when i tried to connect. it says connection refused to the server.. heres the attachment. Quote Share this post Link to post
Staff 9762 Posted ... @gorixHello!As you can see, your OpenVPN client tries to connect to localhost (127.0.0.1). Make sure you have copied all files inside air.zip into OpenVPN configuration directory.Instructions for Windows to connect with AirVPN client or directly with OpenVPN client can be found here:https://airvpn.org/index.php?option=com_content&view=article&id=69&Itemid=123Kind regardsAirVPN admins Quote Share this post Link to post
gorix 0 Posted ... thnks for the reply. i will try it if it works.. Quote Share this post Link to post
nikhil1994 0 Posted ... mine too same problem.tcp connection is not working while udp works with limited speed.admin please solve this problem. Quote Share this post Link to post
gorix 0 Posted ... hi guys, the problem remains the same. i have already used all the updated file here but failed to make the connection. is there something wrong with my desktop? i have turned off the firewall, disable the antivirus, installed the apps but to no avail. if you have suggestions, please drop it here... thanks! Quote Share this post Link to post
Staff 9762 Posted ... @gorix Hello! Yes, there must be a problem on your system. You should investigate why OpenVPN tries to connect to 127.0.0.1. Make sure you have followed our previous suggestions. Kind regards AirVPN admins Quote Share this post Link to post
