U&^TUB&NI 0 Posted ... If I use the Preferences --> Routes option in Eddie (2.12.4) to specify an IP address I want to use outside the VPN, it works fine, as expected. But if I then add another IP address or range to the list, the new one I just added works fine, but the first one will no longer connect at all—I can't even ping the address. I tried reversing the two IPs, that is, changing their order in the list. The same thing happened: the one I enter first works fine until I add a second. Then the second works, but not the first. Any ideas how I can get both entries to work outside the VPN? Thanks. Quote Share this post Link to post
Staff 9762 Posted ... If I use the Preferences --> Routes option in Eddie (2.12.4) to specify an IP address I want to use outside the VPN, it works fine, as expected. But if I then add another IP address or range to the list, the new one I just added works fine, but the first one will no longer connect at all—I can't even ping the address. I tried reversing the two IPs, that is, changing their order in the list. The same thing happened: the one I enter first works fine until I add a second. Then the second works, but not the first. Any ideas how I can get both entries to work outside the VPN? Please upgrade to Eddie 2.13.6 (latest stable release). What you describe is a bug affecting Eddie 2.12.4, we're sorry. Kind regards Quote Share this post Link to post
U&^TUB&NI 0 Posted ... Sorry—I checked for a similar post before asking, but forgot to check for a new version of Eddie. Thanks! Quote Share this post Link to post
