Not connected, Your IP: 216.73.217.142
ChrisHoot
How to prevent IPv6 leaks under Linux, using OpenVPN?
say yer drive is incrypted your grub would look like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX="cryptdevice=/dev/sda3:cryptroot ipv6.disable=1 video=1360x768"
then recheck/build...
# grub-install --recheck /dev/sda
# grub-mkconfig -o /boot/grub/grub.cfg
if you do an ip link command or ifconfig and don't see ipv6 addr good sign
here's another link for debian ubuntu etc:
http://www.binarytides.com/disable-ipv6-ubuntu/
arch basically above but more info:
https://wiki.archlinux.org/index.php/IPv6
same info but mohr detail as above:
https://askubuntu.com/questions/440302/how-to-disable-ipv6-when-connecting-to-an-openvpn-server-using-network-manager-o
iptables stuff:
https://unix.stackexchange.com/questions/108029/is-it-better-to-set-rules-in-ip6tables-or-disable-ipv6
https://superuser.com/questions/488341/block-ipv6-traffic-using-iptables-on-linux-using-layer-2-info
disabling IPv6 might be too problematic in some circumstances, and in general it's an overkill solution.
Setting two or three ip6tables rules is a much more practical approach, and of course it is faster, you just need a second. Network Lock feature does that, in case you run Eddie for GNU/Linux.
Activating the AirVPN "network lock" does stop my ISP IPv6 address from showing up on ipleak.net ... but I can't use Thunderbird to fetch email with the network lock activated.
So I tried disabling IPv6 in Firefox (1. "about:config" in url address box; 2. "network.dns.disableIPv6" in search box; 3. double tapping (or clicking) to change default of "false" to "true").  That seems to work fine, as ipleak.net shows "IPv6 test not reachable."
But does this mean that:  -A. my IPv6 address is still leaking, and I'm just not seeing it in Firefox because IPv6 is disabled; or -B. that Firefox is actually stopping my IPv6 address from being shown on the web?
Hi friends
Excuse me, I'll get a VPN server that has the ipv6
Does not anyone know?
Please
Very necessary 🙏🏼🙏🏼
On 7/23/2019 at 3:14 PM, 3017 said:
Hi friends
Please
Very necessary 🙏🏼🙏🏼
AirVPN now handles IPv6.
This is an old thread.
See here.
