Not connected, Your IP: 3.139.238.76
I have a problem with network lock :
- When i don't use the network lock using eddie :
  • I get using the same vpn server around 35 ms ping to 8.8.8.8
  • My download speed is normal
- But when I activate it
  • the ping drop and it shows 338 ms
  • My download speed is around 10-30 kb/s lower
I have Windows 10 Pro and Kaspersky Internet Security 2017
I 2017.06.19 01:01:03 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.15063.0, Mono/.Net Framework: v4.0.30319
. 2017.06.19 01:01:03 - Reading options from C:\Users\Phoenix\AppData\Local\AirVPN\AirVPN.xml
. 2017.06.19 01:01:03 - Profile options not found, using defaults.
. 2017.06.19 01:01:04 - Data path: C:\Users\Phoenix\AppData\Local\AirVPN
. 2017.06.19 01:01:04 - Application path: C:\Program Files\AirVPN
. 2017.06.19 01:01:04 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.06.19 01:01:04 - Command line arguments (1): path="home"
. 2017.06.19 01:01:04 - Operating System: Microsoft Windows NT 10.0.15063.0
. 2017.06.19 01:01:04 - Cannot find tunnel adapter.
E 2017.06.19 01:01:05 - OpenVPN Driver - Not available - Will be installed at next connection.
I 2017.06.19 01:01:05 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.06.19 01:01:05 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.06.19 01:01:05 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2017.06.19 01:01:05 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2017.06.19 01:01:05 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
! 2017.06.19 01:01:06 - Ready
. 2017.06.19 01:01:06 - Updating systems & servers data ...
. 2017.06.19 01:01:07 - Systems & servers data update completed
I 2017.06.19 01:01:47 - Checking login ...
! 2017.06.19 01:01:47 - Logged in.
! 2017.06.19 01:02:03 - Activation of Network Lock - Windows Filtering Platform
I 2017.06.19 01:02:38 - Session starting.
. 2017.06.19 01:02:38 - Cannot find tunnel adapter.
! 2017.06.19 01:02:38 - Installing tunnel driver
. 2017.06.19 01:02:47 - IPv6 disabled with packet filtering.
I 2017.06.19 01:02:47 - Checking authorization ...
! 2017.06.19 01:02:47 - Connecting to Alcor (Ukraine, Kiev)
. 2017.06.19 01:02:48 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 01:02:48 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 01:02:48 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 01:02:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 01:02:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:02:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:02:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]91.231.84.39:443
. 2017.06.19 01:02:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 01:02:48 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 01:02:48 - OpenVPN > UDP link remote: [AF_INET]91.231.84.39:443
. 2017.06.19 01:02:48 - OpenVPN > TLS: Initial packet from [AF_INET]91.231.84.39:443, sid=f5dffacd b875ad5e
. 2017.06.19 01:02:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 01:02:48 - OpenVPN > Validating certificate key usage
. 2017.06.19 01:02:48 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 01:02:48 - OpenVPN > VERIFY KU OK
. 2017.06.19 01:02:48 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 01:02:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 01:02:48 - OpenVPN > VERIFY EKU OK
. 2017.06.19 01:02:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.19 01:02:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 01:02:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]91.231.84.39:443
. 2017.06.19 01:02:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 01:02:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.20.145 255.255.0.0'
. 2017.06.19 01:02:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 01:02:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 01:02:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 01:02:49 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 01:02:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 01:02:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 01:02:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:02:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:02:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:02:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:02:49 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 01:02:49 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 01:02:49 - OpenVPN > open_tun
. 2017.06.19 01:02:49 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 01:02:49 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 01:02:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.20.145/255.255.0.0 [sUCCEEDED]
. 2017.06.19 01:02:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.20.145/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 01:02:49 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 01:02:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 01:02:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 01:02:54 - OpenVPN > C:\Windows\system32\route.exe ADD 91.231.84.39 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 01:02:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 01:02:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 01:02:54 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:02:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 01:02:54 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:02:54 - Starting Management Interface
. 2017.06.19 01:02:54 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 01:02:54 - DNS leak protection with packet filtering enabled.
. 2017.06.19 01:02:54 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 01:02:54 - Flushing DNS
I 2017.06.19 01:02:58 - Checking route
I 2017.06.19 01:02:59 - Checking DNS
! 2017.06.19 01:03:10 - Connected.
. 2017.06.19 01:03:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 01:03:10 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.19 01:11:09 - Updating systems & servers data ...
. 2017.06.19 01:11:10 - Systems & servers data update completed
. 2017.06.19 01:21:13 - Updating systems & servers data ...
. 2017.06.19 01:21:14 - Systems & servers data update completed
! 2017.06.19 01:24:32 - Disconnecting
. 2017.06.19 01:24:32 - Management - Send 'signal SIGTERM'
. 2017.06.19 01:24:32 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 01:24:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.19 01:24:37 - OpenVPN > C:\Windows\system32\route.exe DELETE 91.231.84.39 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 01:24:37 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 01:24:37 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:24:37 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:24:37 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 01:24:37 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.19 01:24:37 - Connection terminated.
. 2017.06.19 01:24:37 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 01:24:37 - DNS leak protection with packet filtering disabled.
I 2017.06.19 01:24:37 - Checking authorization ...
! 2017.06.19 01:24:38 - Connecting to Gomeisa (Sweden, Uppsala)
. 2017.06.19 01:24:38 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 01:24:38 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 01:24:38 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 01:24:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 01:24:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:24:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:24:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.132:443
. 2017.06.19 01:24:38 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 01:24:38 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 01:24:38 - OpenVPN > UDP link remote: [AF_INET]62.102.148.132:443
. 2017.06.19 01:24:38 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.132:443, sid=709b80a1 527c7531
. 2017.06.19 01:24:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 01:24:38 - OpenVPN > Validating certificate key usage
. 2017.06.19 01:24:38 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 01:24:38 - OpenVPN > VERIFY KU OK
. 2017.06.19 01:24:38 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 01:24:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 01:24:38 - OpenVPN > VERIFY EKU OK
. 2017.06.19 01:24:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Gomeisa, emailAddress=info@airvpn.org
. 2017.06.19 01:24:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 01:24:38 - OpenVPN > [Gomeisa] Peer Connection Initiated with [AF_INET]62.102.148.132:443
. 2017.06.19 01:24:39 - OpenVPN > SENT CONTROL [Gomeisa]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 01:24:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.12.21 255.255.0.0,peer-id 11,cipher AES-256-GCM'
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.06.19 01:24:39 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.06.19 01:24:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 01:24:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 01:24:39 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 01:24:39 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 01:24:39 - OpenVPN > open_tun
. 2017.06.19 01:24:40 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 01:24:40 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 01:24:40 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.12.21/255.255.0.0 [sUCCEEDED]
. 2017.06.19 01:24:40 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.12.21/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 01:24:40 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 01:24:40 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 01:24:44 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 01:24:44 - OpenVPN > C:\Windows\system32\route.exe ADD 62.102.148.132 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 01:24:44 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 01:24:44 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 01:24:44 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:24:44 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 01:24:44 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:24:44 - Starting Management Interface
. 2017.06.19 01:24:44 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 01:24:44 - DNS leak protection with packet filtering enabled.
. 2017.06.19 01:24:44 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 01:24:44 - Flushing DNS
I 2017.06.19 01:24:47 - Checking route
I 2017.06.19 01:24:50 - Checking DNS
! 2017.06.19 01:25:02 - Connected.
. 2017.06.19 01:25:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 01:25:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.19 01:26:11 - OpenVPN > write UDP: No Route to Host (WSAEHOSTUNREACH) (code=10065)
. 2017.06.19 01:27:00 - Above log line repeated 26 times more
! 2017.06.19 01:27:00 - Disconnecting
. 2017.06.19 01:27:00 - Management - Send 'signal SIGTERM'
. 2017.06.19 01:27:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 01:27:00 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.19 01:27:05 - OpenVPN > C:\Windows\system32\route.exe DELETE 62.102.148.132 MASK 255.255.255.255 192.168.1.1
W 2017.06.19 01:27:05 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.1.1
. 2017.06.19 01:27:05 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2017.06.19 01:27:05 - OpenVPN > Route deletion fallback to route.exe
. 2017.06.19 01:27:05 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2017.06.19 01:27:05 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:27:05 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 01:27:05 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:27:05 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 01:27:05 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.19 01:27:05 - Connection terminated.
. 2017.06.19 01:27:05 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 01:27:05 - DNS leak protection with packet filtering disabled.
. 2017.06.19 01:27:05 - IPv6 restored with packet filtering.
. 2017.06.19 01:27:05 - Flushing DNS
! 2017.06.19 01:27:08 - Session terminated.
I 2017.06.19 01:27:09 - Session starting.
. 2017.06.19 01:27:09 - IPv6 disabled with packet filtering.
I 2017.06.19 01:27:24 - Checking authorization ...
! 2017.06.19 01:27:24 - Connecting to Alchiba (Netherlands, Alblasserdam)
. 2017.06.19 01:27:27 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 01:27:27 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 01:27:27 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 01:27:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 01:27:27 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:27:27 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:27:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.180:443
. 2017.06.19 01:27:27 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 01:27:27 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 01:27:27 - OpenVPN > UDP link remote: [AF_INET]213.152.161.180:443
. 2017.06.19 01:27:27 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.180:443, sid=9ef08779 1093a45a
. 2017.06.19 01:27:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 01:27:27 - OpenVPN > Validating certificate key usage
. 2017.06.19 01:27:27 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 01:27:27 - OpenVPN > VERIFY KU OK
. 2017.06.19 01:27:27 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 01:27:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 01:27:27 - OpenVPN > VERIFY EKU OK
. 2017.06.19 01:27:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.19 01:27:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 01:27:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.180:443
. 2017.06.19 01:27:27 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 01:27:27 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.113.161 255.255.0.0'
. 2017.06.19 01:27:27 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 01:27:27 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 01:27:27 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 01:27:27 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 01:27:27 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 01:27:27 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 01:27:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:27:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:27:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:27:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:27:27 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 01:27:27 - OpenVPN > ROUTE_GATEWAY 192.168.43.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 01:27:27 - OpenVPN > open_tun
. 2017.06.19 01:27:27 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 01:27:27 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 01:27:27 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.113.161/255.255.0.0 [sUCCEEDED]
. 2017.06.19 01:27:27 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.113.161/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 01:27:27 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 01:27:27 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 01:27:31 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 01:27:31 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.180 MASK 255.255.255.255 192.168.43.1
. 2017.06.19 01:27:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 01:27:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 01:27:31 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:27:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 01:27:31 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:27:31 - Starting Management Interface
. 2017.06.19 01:27:31 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 01:27:31 - DNS leak protection with packet filtering enabled.
. 2017.06.19 01:27:31 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 01:27:31 - Flushing DNS
I 2017.06.19 01:27:35 - Checking route
I 2017.06.19 01:27:35 - Checking DNS
! 2017.06.19 01:27:48 - Connected.
. 2017.06.19 01:27:48 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 01:27:48 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2017.06.19 01:29:04 - Disconnecting
. 2017.06.19 01:29:04 - Management - Send 'signal SIGTERM'
. 2017.06.19 01:29:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 01:29:04 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.19 01:29:09 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.180 MASK 255.255.255.255 192.168.43.1
W 2017.06.19 01:29:09 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.43.1
. 2017.06.19 01:29:09 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2017.06.19 01:29:09 - OpenVPN > Route deletion fallback to route.exe
. 2017.06.19 01:29:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2017.06.19 01:29:09 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:29:09 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 01:29:09 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:29:09 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 01:29:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.19 01:29:09 - Connection terminated.
. 2017.06.19 01:29:09 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 01:29:09 - DNS leak protection with packet filtering disabled.
. 2017.06.19 01:29:09 - IPv6 restored with packet filtering.
. 2017.06.19 01:29:09 - Flushing DNS
! 2017.06.19 01:29:12 - Session terminated.
! 2017.06.19 01:29:16 - Deactivation of Network Lock
! 2017.06.19 01:30:06 - Activation of Network Lock - Windows Filtering Platform
I 2017.06.19 01:30:08 - Session starting.
. 2017.06.19 01:30:08 - IPv6 disabled with packet filtering.
I 2017.06.19 01:30:08 - Checking authorization ...
! 2017.06.19 01:30:08 - Connecting to Muscida (Netherlands, Alblasserdam)
. 2017.06.19 01:30:11 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 01:30:11 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 01:30:11 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 01:30:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 01:30:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:30:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:30:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.153:443
. 2017.06.19 01:30:11 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 01:30:11 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 01:30:11 - OpenVPN > UDP link remote: [AF_INET]213.152.162.153:443
. 2017.06.19 01:30:11 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.153:443, sid=ac0b5f83 28fed3da
. 2017.06.19 01:30:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 01:30:11 - OpenVPN > Validating certificate key usage
. 2017.06.19 01:30:11 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 01:30:11 - OpenVPN > VERIFY KU OK
. 2017.06.19 01:30:11 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 01:30:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 01:30:11 - OpenVPN > VERIFY EKU OK
. 2017.06.19 01:30:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.19 01:30:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 01:30:11 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.153:443
. 2017.06.19 01:30:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 01:30:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.112.39 255.255.0.0'
. 2017.06.19 01:30:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 01:30:11 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 01:30:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 01:30:11 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 01:30:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 01:30:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 01:30:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:30:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:30:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:30:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:30:11 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 01:30:11 - OpenVPN > ROUTE_GATEWAY 192.168.43.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 01:30:11 - OpenVPN > open_tun
. 2017.06.19 01:30:11 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 01:30:11 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 01:30:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.112.39/255.255.0.0 [sUCCEEDED]
. 2017.06.19 01:30:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.112.39/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 01:30:11 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 01:30:11 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 01:30:15 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 01:30:15 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.153 MASK 255.255.255.255 192.168.43.1
. 2017.06.19 01:30:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 01:30:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 01:30:15 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:30:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 01:30:15 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:30:15 - Starting Management Interface
. 2017.06.19 01:30:15 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 01:30:15 - DNS leak protection with packet filtering enabled.
. 2017.06.19 01:30:15 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 01:30:15 - Flushing DNS
I 2017.06.19 01:30:18 - Checking route
I 2017.06.19 01:30:19 - Checking DNS
! 2017.06.19 01:30:31 - Connected.
. 2017.06.19 01:30:31 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 01:30:31 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.19 01:30:38 - OpenVPN > write UDP: No Route to Host (WSAEHOSTUNREACH) (code=10065)
. 2017.06.19 01:31:17 - Updating systems & servers data ...
. 2017.06.19 01:31:31 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2017.06.19 01:31:31 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2017.06.19 01:31:31 - OpenVPN > Restart pause, 5 second(s)
! 2017.06.19 01:31:31 - Disconnecting
. 2017.06.19 01:31:31 - Management - Send 'signal SIGTERM'
. 2017.06.19 01:31:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 01:31:31 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.153 MASK 255.255.255.255 192.168.43.1
W 2017.06.19 01:31:31 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.43.1
. 2017.06.19 01:31:31 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2017.06.19 01:31:31 - OpenVPN > Route deletion fallback to route.exe
. 2017.06.19 01:31:31 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2017.06.19 01:31:31 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:31:31 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 01:31:31 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:31:31 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 01:31:31 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2017.06.19 01:31:31 - Connection terminated.
. 2017.06.19 01:31:31 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 01:31:31 - DNS leak protection with packet filtering disabled.
I 2017.06.19 01:31:34 - Checking authorization ...
! 2017.06.19 01:31:34 - Connecting to Salm (Netherlands, Alblasserdam)
. 2017.06.19 01:31:34 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 01:31:34 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 01:31:34 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 01:31:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 01:31:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:31:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:31:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.19:443
. 2017.06.19 01:31:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 01:31:34 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 01:31:34 - OpenVPN > UDP link remote: [AF_INET]213.152.161.19:443
. 2017.06.19 01:31:34 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.19:443, sid=da8f8bd9 1d0fc6fd
. 2017.06.19 01:31:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 01:31:34 - OpenVPN > Validating certificate key usage
. 2017.06.19 01:31:34 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 01:31:34 - OpenVPN > VERIFY KU OK
. 2017.06.19 01:31:34 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 01:31:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 01:31:34 - OpenVPN > VERIFY EKU OK
. 2017.06.19 01:31:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.19 01:31:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 01:31:35 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.19:443
. 2017.06.19 01:31:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 01:31:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.112.242 255.255.0.0'
. 2017.06.19 01:31:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 01:31:36 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 01:31:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 01:31:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 01:31:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 01:31:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 01:31:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:31:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:31:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 01:31:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:31:36 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 01:31:36 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 01:31:36 - OpenVPN > open_tun
. 2017.06.19 01:31:36 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 01:31:36 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 01:31:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.112.242/255.255.0.0 [sUCCEEDED]
. 2017.06.19 01:31:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.112.242/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 01:31:36 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 01:31:36 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 01:31:37 - Systems & servers data update completed
. 2017.06.19 01:31:41 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 01:31:41 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.19 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 01:31:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 01:31:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 01:31:41 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:31:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 01:31:41 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:31:41 - Starting Management Interface
. 2017.06.19 01:31:41 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 01:31:41 - DNS leak protection with packet filtering enabled.
. 2017.06.19 01:31:41 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 01:31:41 - Flushing DNS
I 2017.06.19 01:31:44 - Checking route
I 2017.06.19 01:31:47 - Checking DNS
! 2017.06.19 01:32:01 - Connected.
. 2017.06.19 01:32:01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 01:32:01 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.19 01:41:39 - Updating systems & servers data ...
. 2017.06.19 01:41:42 - Systems & servers data update completed
. 2017.06.19 01:51:45 - Updating systems & servers data ...
. 2017.06.19 01:51:47 - Systems & servers data update completed
! 2017.06.19 01:54:13 - Disconnecting
. 2017.06.19 01:54:13 - Management - Send 'signal SIGTERM'
. 2017.06.19 01:54:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 01:54:13 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.19 01:54:18 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.19 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 01:54:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 01:54:18 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:54:18 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:54:18 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 01:54:18 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.19 01:54:18 - Connection terminated.
. 2017.06.19 01:54:18 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 01:54:18 - DNS leak protection with packet filtering disabled.
I 2017.06.19 01:54:18 - Checking authorization ...
! 2017.06.19 01:54:18 - Connecting to Cervantes (Germany, Frankfurt)
. 2017.06.19 01:54:18 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 01:54:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 01:54:18 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 01:54:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 01:54:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:54:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 01:54:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.189.112.26:443
. 2017.06.19 01:54:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 01:54:18 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 01:54:18 - OpenVPN > UDP link remote: [AF_INET]185.189.112.26:443
. 2017.06.19 01:54:18 - OpenVPN > TLS: Initial packet from [AF_INET]185.189.112.26:443, sid=bb525f22 c266d0f5
. 2017.06.19 01:54:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 01:54:18 - OpenVPN > Validating certificate key usage
. 2017.06.19 01:54:18 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 01:54:18 - OpenVPN > VERIFY KU OK
. 2017.06.19 01:54:18 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 01:54:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 01:54:18 - OpenVPN > VERIFY EKU OK
. 2017.06.19 01:54:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cervantes, emailAddress=info@airvpn.org
. 2017.06.19 01:54:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 01:54:19 - OpenVPN > [Cervantes] Peer Connection Initiated with [AF_INET]185.189.112.26:443
. 2017.06.19 01:54:20 - OpenVPN > SENT CONTROL [Cervantes]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 01:54:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.177 255.255.0.0,peer-id 3,cipher AES-256-GCM'
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.06.19 01:54:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.06.19 01:54:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 01:54:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 01:54:20 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 01:54:20 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 01:54:20 - OpenVPN > open_tun
. 2017.06.19 01:54:20 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 01:54:20 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 01:54:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.177/255.255.0.0 [sUCCEEDED]
. 2017.06.19 01:54:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.177/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 01:54:20 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 01:54:20 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 01:54:25 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 01:54:25 - OpenVPN > C:\Windows\system32\route.exe ADD 185.189.112.26 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 01:54:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 01:54:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 01:54:25 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:54:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 01:54:25 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 01:54:25 - Starting Management Interface
. 2017.06.19 01:54:25 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 01:54:25 - DNS leak protection with packet filtering enabled.
. 2017.06.19 01:54:25 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 01:54:25 - Flushing DNS
I 2017.06.19 01:54:28 - Checking route
I 2017.06.19 01:54:28 - Checking DNS
! 2017.06.19 01:54:41 - Connected.
. 2017.06.19 01:54:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 01:54:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.19 02:01:50 - Updating systems & servers data ...
. 2017.06.19 02:01:52 - Systems & servers data update completed
! 2017.06.19 02:04:40 - Disconnecting
. 2017.06.19 02:04:40 - Management - Send 'signal SIGTERM'
. 2017.06.19 02:04:40 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 02:04:40 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.19 02:04:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.189.112.26 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 02:04:45 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 02:04:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:04:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:04:45 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 02:04:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.19 02:04:45 - Connection terminated.
. 2017.06.19 02:04:45 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 02:04:45 - DNS leak protection with packet filtering disabled.
. 2017.06.19 02:04:45 - IPv6 restored with packet filtering.
. 2017.06.19 02:04:45 - Flushing DNS
! 2017.06.19 02:04:48 - Session terminated.
! 2017.06.19 02:04:48 - Deactivation of Network Lock
I 2017.06.19 02:04:50 - Session starting.
. 2017.06.19 02:04:50 - IPv6 disabled with packet filtering.
I 2017.06.19 02:04:50 - Checking authorization ...
! 2017.06.19 02:04:50 - Connecting to Capricornus (Belgium, Brussels)
. 2017.06.19 02:04:50 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 02:04:50 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 02:04:50 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 02:04:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 02:04:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:04:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:04:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.90:443
. 2017.06.19 02:04:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 02:04:50 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 02:04:50 - OpenVPN > UDP link remote: [AF_INET]194.187.251.90:443
. 2017.06.19 02:04:50 - OpenVPN > TLS: Initial packet from [AF_INET]194.187.251.90:443, sid=8ab7c700 158c263d
. 2017.06.19 02:04:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 02:04:50 - OpenVPN > Validating certificate key usage
. 2017.06.19 02:04:50 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 02:04:50 - OpenVPN > VERIFY KU OK
. 2017.06.19 02:04:50 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 02:04:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 02:04:50 - OpenVPN > VERIFY EKU OK
. 2017.06.19 02:04:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Capricornus, emailAddress=info@airvpn.org
. 2017.06.19 02:04:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 02:04:51 - OpenVPN > [Capricornus] Peer Connection Initiated with [AF_INET]194.187.251.90:443
. 2017.06.19 02:04:52 - OpenVPN > SENT CONTROL [Capricornus]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 02:04:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.15.185 255.255.0.0'
. 2017.06.19 02:04:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 02:04:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 02:04:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 02:04:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 02:04:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 02:04:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 02:04:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 02:04:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:04:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 02:04:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:04:52 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 02:04:52 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 02:04:52 - OpenVPN > open_tun
. 2017.06.19 02:04:52 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 02:04:52 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 02:04:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.15.185/255.255.0.0 [sUCCEEDED]
. 2017.06.19 02:04:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.15.185/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 02:04:52 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 02:04:52 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 02:04:57 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 02:04:57 - OpenVPN > C:\Windows\system32\route.exe ADD 194.187.251.90 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 02:04:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 02:04:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 02:04:57 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:04:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 02:04:57 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:04:57 - Starting Management Interface
. 2017.06.19 02:04:57 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 02:04:57 - DNS leak protection with packet filtering enabled.
. 2017.06.19 02:04:57 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 02:04:57 - Flushing DNS
I 2017.06.19 02:05:00 - Checking route
I 2017.06.19 02:05:00 - Checking DNS
! 2017.06.19 02:05:13 - Connected.
. 2017.06.19 02:05:13 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.19 02:05:13 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.19 02:11:54 - Disconnecting
. 2017.06.19 02:11:54 - Management - Send 'signal SIGTERM'
. 2017.06.19 02:11:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 02:11:54 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.19 02:11:55 - Updating systems & servers data ...
. 2017.06.19 02:11:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 194.187.251.90 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 02:11:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 02:11:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:11:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:11:59 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 02:11:59 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.19 02:11:59 - Connection terminated.
. 2017.06.19 02:11:59 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 02:11:59 - DNS leak protection with packet filtering disabled.
. 2017.06.19 02:11:59 - IPv6 restored with packet filtering.
. 2017.06.19 02:11:59 - Flushing DNS
! 2017.06.19 02:12:02 - Session terminated.
. 2017.06.19 02:12:06 - Systems & servers data update completed
! 2017.06.19 02:12:07 - Activation of Network Lock - Windows Filtering Platform
I 2017.06.19 02:12:08 - Session starting.
. 2017.06.19 02:12:08 - IPv6 disabled with packet filtering.
I 2017.06.19 02:12:08 - Checking authorization ...
! 2017.06.19 02:12:08 - Connecting to Errai (Germany, Frankfurt)
. 2017.06.19 02:12:09 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 02:12:09 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 02:12:09 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 02:12:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 02:12:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:12:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:12:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.189.112.10:443
. 2017.06.19 02:12:09 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 02:12:09 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 02:12:09 - OpenVPN > UDP link remote: [AF_INET]185.189.112.10:443
. 2017.06.19 02:12:09 - OpenVPN > TLS: Initial packet from [AF_INET]185.189.112.10:443, sid=dc088575 49b8b3cc
. 2017.06.19 02:12:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 02:12:09 - OpenVPN > Validating certificate key usage
. 2017.06.19 02:12:09 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 02:12:09 - OpenVPN > VERIFY KU OK
. 2017.06.19 02:12:09 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 02:12:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 02:12:09 - OpenVPN > VERIFY EKU OK
. 2017.06.19 02:12:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Errai, emailAddress=info@airvpn.org
. 2017.06.19 02:12:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 02:12:09 - OpenVPN > [Errai] Peer Connection Initiated with [AF_INET]185.189.112.10:443
. 2017.06.19 02:12:10 - OpenVPN > SENT CONTROL [Errai]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 02:12:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.196 255.255.0.0,peer-id 9,cipher AES-256-GCM'
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.06.19 02:12:10 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.06.19 02:12:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 02:12:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 02:12:10 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 02:12:10 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 02:12:10 - OpenVPN > open_tun
. 2017.06.19 02:12:10 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 02:12:10 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 02:12:10 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.196/255.255.0.0 [sUCCEEDED]
. 2017.06.19 02:12:10 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.196/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 02:12:10 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 02:12:10 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
! 2017.06.19 02:12:11 - Disconnecting
. 2017.06.19 02:12:11 - Connection terminated.
I 2017.06.19 02:12:11 - Cancel requested.
. 2017.06.19 02:12:11 - IPv6 restored with packet filtering.
. 2017.06.19 02:12:11 - Flushing DNS
! 2017.06.19 02:12:15 - Session terminated.
I 2017.06.19 02:12:18 - Session starting.
. 2017.06.19 02:12:18 - IPv6 disabled with packet filtering.
I 2017.06.19 02:12:18 - Checking authorization ...
! 2017.06.19 02:12:18 - Connecting to Capricornus (Belgium, Brussels)
. 2017.06.19 02:12:18 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 02:12:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.19 02:12:18 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.19 02:12:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 02:12:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:12:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:12:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.90:443
. 2017.06.19 02:12:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.19 02:12:18 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 02:12:18 - OpenVPN > UDP link remote: [AF_INET]194.187.251.90:443
. 2017.06.19 02:12:18 - OpenVPN > TLS: Initial packet from [AF_INET]194.187.251.90:443, sid=bfbedb9f 3db46e37
. 2017.06.19 02:12:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 02:12:18 - OpenVPN > Validating certificate key usage
. 2017.06.19 02:12:18 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.19 02:12:18 - OpenVPN > VERIFY KU OK
. 2017.06.19 02:12:18 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 02:12:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 02:12:18 - OpenVPN > VERIFY EKU OK
. 2017.06.19 02:12:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Capricornus, emailAddress=info@airvpn.org
. 2017.06.19 02:12:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 02:12:18 - OpenVPN > [Capricornus] Peer Connection Initiated with [AF_INET]194.187.251.90:443
. 2017.06.19 02:12:19 - OpenVPN > SENT CONTROL [Capricornus]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 02:12:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.15.185 255.255.0.0'
. 2017.06.19 02:12:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 02:12:19 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 02:12:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 02:12:19 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 02:12:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 02:12:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 02:12:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 02:12:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:12:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.19 02:12:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 02:12:19 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 02:12:19 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=30:e3:7a:ea:a2:22
. 2017.06.19 02:12:19 - OpenVPN > open_tun
. 2017.06.19 02:12:20 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{5AB39F01-15E6-4AA7-9421-C022484C9D5A}.tap
. 2017.06.19 02:12:20 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 02:12:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.15.185/255.255.0.0 [sUCCEEDED]
. 2017.06.19 02:12:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.15.185/255.255.0.0 on interface {5AB39F01-15E6-4AA7-9421-C022484C9D5A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 02:12:20 - OpenVPN > Successful ARP Flush on interface [46] {5AB39F01-15E6-4AA7-9421-C022484C9D5A}
. 2017.06.19 02:12:20 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 02:12:24 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 02:12:24 - OpenVPN > C:\Windows\system32\route.exe ADD 194.187.251.90 MASK 255.255.255.255 192.168.1.1
. 2017.06.19 02:12:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2017.06.19 02:12:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 02:12:24 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:12:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.19 02:12:24 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 02:12:24 - Starting Management Interface
. 2017.06.19 02:12:24 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 02:12:24 - DNS leak protection with packet filtering enabled.
. 2017.06.19 02:12:24 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 02:12:24 - Flushing DNS
I 2017.06.19 02:12:28 - Checking route
I 2017.06.19 02:12:28 - Checking DNS
! 2017.06.19 02:12:42 - Connected.
. 2017.06.19 02:12:42 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 02:12:42 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
Thank you for your help
Looks like 9 connections to servers in Europe, 3 with network lock active, 2 on the same subnet as the non-netlock connections.
While your testing, try connecting to the same server with KIS 2017 disabled.
If the issue remains, try using different ports: AirVPN > Preferences > Protocols > uncheck Automatic > select a protocol.
Try (Primary) ports like: UDP 53 or 2018, TCP 443 or 80.
In addition to the above, you may also benefit from trying without Kaspersky installed or active.
