Not connected, Your IP: 3.138.174.95
Hello All,
I've been with AirVPN a while now. I think they're the best.
My ISP plan was 10 Mbps down and 1 Mbps up. Initially, I had some speed issues. Staff were wonderful and solved my issue. Great speed all around.
I recently upgraded my line to 50 Mbps up and 10 Mbps down. When not connected to the VPN I get speeds around 45 to 47 Mbps down and 7 to 8 Mpbs up. Connected with AirVPN, I get about 25 to 27 Mbps and 7 Mpbs up. Strange that the upload is not affected. I have tried so many things; different protocols with different servers and so forth and yet no resolution.
I have contacted Staff and they suggested a few things but nothing has worked. I think they may be stumped as well.
My modem is a TP-Link TD-W9970. I believe it's properly configured. I do NOT want to try another VPN service. I've been reading online to find a solution. Someone mentioned changing the MTU settings from the computer (not the router). Could not quite get it to work. I don't know if my CPU is responsible as it is about ten years old. I plan to upgrade my system soon. If it is the CPU, I don't understand why the speed is fine without the VPN.
Any ideas would be so greatly appreciated.
Thank you all,
DL
