cjalas 0 Posted ... Hello, I signed up Premium service and installed the client on Windows 7 machine successfully along with OpenVPN. Everything connects fine to servers and the client says I am routed to server's IP, but when I check the site or any IP checking site it still shows my original IP and not the VPN forwarded IP? I am using Verizon Router which is a Westell Ultraline Series3 Model # A90-9100EM15-10 Connecting through the router's wifi, with SSID broadcasting off using WEP encryption. In my Windows 7 network settings it shows I am connected to "Multiple Networks": the WiFi network and another "Unidentified Network" which says No Network Access. Under the Adapter Settings, I have a TAP-Win32 Adapter V9 Local Area Network and my WiFi connection. Please help! I did not have this problem when I tried out HideIpVpn.com or HideMyAss.com's client software that worked fine in hiding my IP, but have slow connections or do not allow p2p via US servers. Quote Share this post Link to post
cjalas 0 Posted ... Nevermind, restarting seemed to fix the issue? LOL :woohoo: Quote Share this post Link to post
cjalas 0 Posted ... OK, It's doing the same thing again. Someone help Quote Share this post Link to post
Staff 9762 Posted ... OK, It's doing the same thing again. Someone help Hello!Can you please send us the connection logs?Kind regards Quote Share this post Link to post
jmish 0 Posted ... Hi, I'm having the same problem. The client says I'm connected but my real IP is still visible and I get the same thing with "Unidentified Network" and No Network Access. Thanks. Quote Share this post Link to post
Staff 9762 Posted ... Hello! Please publish (or send us privately) the connection logs. They can be very useful for troubleshooting. We're looking forward to hearing from you. Kind regards Quote Share this post Link to post
jmish 0 Posted ... Thanks for the quick reply. I restarted my computer and it's working now. Though, I had to restart a couple days ago to get it working too. I shouldn't have to keep restarting should I? Next time it doesn't connect properly, I'll send the log. Quote Share this post Link to post
jmish 0 Posted ... I just disconnected from the Draconis server and tried to connect to the Sirius server and had a connection problem again. My connection log is pasted below. Thanks. 5/3/2012 - 11:12 AM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 11:12 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 5/3/2012 - 11:12 AM C:\WINDOWS\system32\route.exe ADD 178.248.29.132 MASK 255.255.255.255 192.168.3.250 5/3/2012 - 11:12 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 5/3/2012 - 11:12 AM Route addition via IPAPI succeeded [adaptive] 5/3/2012 - 11:12 AM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.9.145 5/3/2012 - 11:12 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 5/3/2012 - 11:12 AM Route addition via IPAPI succeeded [adaptive] 5/3/2012 - 11:12 AM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.9.145 5/3/2012 - 11:12 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 5/3/2012 - 11:12 AM Route addition via IPAPI succeeded [adaptive] 5/3/2012 - 11:12 AM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.9.145 5/3/2012 - 11:12 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 5/3/2012 - 11:12 AM Route addition via IPAPI succeeded [adaptive] 5/3/2012 - 11:12 AM Initialization Sequence Completed 5/3/2012 - 11:12 AM Starting Management Interface... 5/3/2012 - 11:12 AM Checking... 5/3/2012 - 11:12 AM Retrieve statistics... 5/3/2012 - 11:12 AM Connected. 5/3/2012 - 12:12 PM TLS: soft reset sec=0 bytes=282605808/0 pkts=325169/0 5/3/2012 - 12:12 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 5/3/2012 - 12:12 PM VERIFY OK: nsCertType=SERVER 5/3/2012 - 12:12 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 5/3/2012 - 12:12 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/3/2012 - 12:12 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/3/2012 - 12:12 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/3/2012 - 12:12 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/3/2012 - 12:12 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 5/3/2012 - 12:22 PM Disconnecting... 5/3/2012 - 12:22 PM SIGTERM received, sending exit notification to peer 5/3/2012 - 12:22 PM TCP/UDP: Closing socket 5/3/2012 - 12:22 PM Disconnected. 5/3/2012 - 12:22 PM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.9.145 5/3/2012 - 12:22 PM Route deletion via IPAPI succeeded [adaptive] 5/3/2012 - 12:22 PM C:\WINDOWS\system32\route.exe DELETE 178.248.29.132 MASK 255.255.255.255 192.168.3.250 5/3/2012 - 12:22 PM Route deletion via IPAPI succeeded [adaptive] 5/3/2012 - 12:22 PM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.9.145 5/3/2012 - 12:22 PM Route deletion via IPAPI succeeded [adaptive] 5/3/2012 - 12:22 PM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.9.145 5/3/2012 - 12:22 PM Route deletion via IPAPI succeeded [adaptive] 5/3/2012 - 12:22 PM Closing TUN/TAP interface 5/3/2012 - 12:22 PM SIGTERM[hard,] received, process exiting 5/3/2012 - 12:22 PM Login... 5/3/2012 - 12:23 PM Login success. 5/3/2012 - 12:23 PM Contacting service... 5/3/2012 - 12:23 PM Connecting... 5/3/2012 - 12:23 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 5/3/2012 - 12:23 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 5/3/2012 - 12:23 PM LZO compression initialized 5/3/2012 - 12:23 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 5/3/2012 - 12:23 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 5/3/2012 - 12:23 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 5/3/2012 - 12:23 PM Local Options hash (VER=V4): '22188c5b' 5/3/2012 - 12:23 PM Expected Remote Options hash (VER=V4): 'a8f55717' 5/3/2012 - 12:23 PM UDPv4 link local: [undef] 5/3/2012 - 12:23 PM UDPv4 link remote: 108.59.8.147:443 5/3/2012 - 12:23 PM TLS: Initial packet from 108.59.8.147:443, sid=29e1195e 59ca43f6 5/3/2012 - 12:23 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 5/3/2012 - 12:23 PM VERIFY OK: nsCertType=SERVER 5/3/2012 - 12:23 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 5/3/2012 - 12:23 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/3/2012 - 12:23 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/3/2012 - 12:23 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/3/2012 - 12:23 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/3/2012 - 12:23 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 5/3/2012 - 12:23 PM [server] Peer Connection Initiated with 108.59.8.147:443 5/3/2012 - 12:23 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 5/3/2012 - 12:23 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.12.130 10.4.12.129' 5/3/2012 - 12:23 PM OPTIONS IMPORT: timers and/or timeouts modified 5/3/2012 - 12:23 PM OPTIONS IMPORT: LZO parms modified 5/3/2012 - 12:23 PM OPTIONS IMPORT: --ifconfig/up options modified 5/3/2012 - 12:23 PM OPTIONS IMPORT: route options modified 5/3/2012 - 12:23 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 5/3/2012 - 12:23 PM ROUTE default_gateway=192.168.3.250 5/3/2012 - 12:23 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{584BF7D6-C6A0-4541-A263-6065725A7A93}.tap 5/3/2012 - 12:23 PM TAP-Win32 Driver Version 9.9 5/3/2012 - 12:23 PM TAP-Win32 MTU=1500 5/3/2012 - 12:23 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.12.130/255.255.255.252 on interface {584BF7D6-C6A0-4541-A263-6065725A7A93} [DHCP-serv: 10.4.12.129, lease-time: 31536000] 5/3/2012 - 12:23 PM Successful ARP Flush on interface [20] {584BF7D6-C6A0-4541-A263-6065725A7A93} 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM Route: Waiting for TUN/TAP interface to come up... 5/3/2012 - 12:23 PM TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down 5/3/2012 - 12:23 PM C:\WINDOWS\system32\route.exe ADD 108.59.8.147 MASK 255.255.255.255 192.168.3.250 5/3/2012 - 12:23 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 5/3/2012 - 12:23 PM Route addition via IPAPI succeeded [adaptive] 5/3/2012 - 12:23 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.12.129 5/3/2012 - 12:23 PM Warning: route gateway is not reachable on any active network adapters: 10.4.12.129 5/3/2012 - 12:23 PM Route addition via IPAPI failed [adaptive] 5/3/2012 - 12:23 PM Route addition fallback to route.exe 5/3/2012 - 12:23 PM OK! 5/3/2012 - 12:23 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.12.129 5/3/2012 - 12:23 PM Warning: route gateway is not reachable on any active network adapters: 10.4.12.129 5/3/2012 - 12:23 PM Route addition via IPAPI failed [adaptive] 5/3/2012 - 12:23 PM Route addition fallback to route.exe 5/3/2012 - 12:23 PM OK! 5/3/2012 - 12:23 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.12.129 5/3/2012 - 12:23 PM Warning: route gateway is not reachable on any active network adapters: 10.4.12.129 5/3/2012 - 12:23 PM Route addition via IPAPI failed [adaptive] 5/3/2012 - 12:23 PM Route addition fallback to route.exe 5/3/2012 - 12:23 PM OK! 5/3/2012 - 12:23 PM SYSTEM ROUTING TABLE 5/3/2012 - 12:23 PM .250 p=0 i=10 t=4 pr=3 a=4991 h=0 m=20/0/0/0/0 5/3/2012 - 12:23 PM .129 p=0 i=10 t=4 pr=3 a=0 h=0 m=21/0/0/0/0 5/3/2012 - 12:23 PM 10.4.12.129 p=0 i=10 t=4 pr=3 a=0 h=0 m=21/0/0/0/0 5/3/2012 - 12:23 PM 2 10.4.9.146 p=0 i=20 t=3 pr=3 a=4291 h=0 m=286/0/0/0/0 5/3/2012 - 12:23 PM 5 10.4.9.146 p=0 i=20 t=3 pr=3 a=4291 h=0 m=286/0/0/0/0 5/3/2012 - 12:23 PM 5 10.4.9.146 p=0 i=20 t=3 pr=3 a=4291 h=0 m=286/0/0/0/0 5/3/2012 - 12:23 PM 255 192.168.3.250 p=0 i=10 t=4 pr=3 a=0 h=0 m=20/0/0/0/0 5/3/2012 - 12:23 PM .0.1 p=0 i=1 t=3 pr=3 a=5030 h=0 m=306/0/0/0/0 5/3/2012 - 12:23 PM 127.0.0.1 p=0 i=1 t=3 pr=3 a=5030 h=0 m=306/0/0/0/0 5/3/2012 - 12:23 PM 55.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=5030 h=0 m=306/0/0/0/0 5/3/2012 - 12:23 PM 12.129 p=0 i=10 t=4 pr=3 a=0 h=0 m=21/0/0/0/0 5/3/2012 - 12:23 PM 192.168.3.71 p=0 i=10 t=3 pr=3 a=4991 h=0 m=276/0/0/0/0 5/3/2012 - 12:23 PM 255 192.168.3.71 p=0 i=10 t=3 pr=3 a=4991 h=0 m=276/0/0/0/0 5/3/2012 - 12:23 PM .255 192.168.3.71 p=0 i=10 t=3 pr=3 a=4991 h=0 m=276/0/0/0/0 5/3/2012 - 12:23 PM .0.1 p=0 i=1 t=3 pr=3 a=5030 h=0 m=306/0/0/0/0 5/3/2012 - 12:23 PM 68.3.71 p=0 i=10 t=3 pr=3 a=5015 h=0 m=276/0/0/0/0 5/3/2012 - 12:23 PM 9.146 p=0 i=20 t=3 pr=3 a=4352 h=0 m=286/0/0/0/0 5/3/2012 - 12:23 PM 55.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=5030 h=0 m=306/0/0/0/0 5/3/2012 - 12:23 PM 55.255 192.168.3.71 p=0 i=10 t=3 pr=3 a=5015 h=0 m=276/0/0/0/0 5/3/2012 - 12:23 PM 55.255 10.4.9.146 p=0 i=20 t=3 pr=3 a=4352 h=0 m=286/0/0/0/0 5/3/2012 - 12:23 PM SYSTEM ADAPTER LIST 5/3/2012 - 12:23 PM TAP-Win32 Adapter V9 5/3/2012 - 12:23 PM Index = 20 5/3/2012 - 12:23 PM 541-A263-6065725A7A93} 5/3/2012 - 12:23 PM .255.252 5/3/2012 - 12:23 PM MAC = 00:ff:58:4b:f7:d6 5/3/2012 - 12:23 PM 55.255.255 5/3/2012 - 12:23 PM 255.255.255.255 5/3/2012 - 12:23 PM hu May 03 11:12:21 2012 5/3/2012 - 12:23 PM un Oct 25 10:42:12 1970 5/3/2012 - 12:23 PM .255.255.255 5/3/2012 - 12:23 PM l Area Network) 5/3/2012 - 12:23 PM Index = 12 5/3/2012 - 12:23 PM FC2-9863-4F55FC3D8C5C} 5/3/2012 - 12:23 PM IP = 0.0.0.0/0.0.0.0 5/3/2012 - 12:23 PM MAC = 00:1e:4c:cc:cc:64 5/3/2012 - 12:23 PM 55.255.255 5/3/2012 - 12:23 PM DHCP SERV = 5/3/2012 - 12:23 PM hu May 03 12:23:53 2012 5/3/2012 - 12:23 PM hu Jan 01 01:00:00 1970 5/3/2012 - 12:23 PM DNS SERV = 5/3/2012 - 12:23 PM Controller 5/3/2012 - 12:23 PM Index = 10 5/3/2012 - 12:23 PM 5E1-A265-2B7168E44E41} 5/3/2012 - 12:23 PM 55.255.0 5/3/2012 - 12:23 PM MAC = 00:1e:c9:5d:3a:f6 5/3/2012 - 12:23 PM /255.255.255.255 5/3/2012 - 12:23 PM 50/255.255.255.255 5/3/2012 - 12:23 PM hu May 03 11:00:41 2012 5/3/2012 - 12:23 PM hu Jan 01 01:00:00 1970 5/3/2012 - 12:23 PM 0/255.255.255.255 5/3/2012 - 12:23 PM Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) 5/3/2012 - 12:23 PM Starting Management Interface... 5/3/2012 - 12:23 PM Checking... 5/3/2012 - 12:24 PM Retrieve statistics... 5/3/2012 - 12:24 PM Connected. Quote Share this post Link to post
Staff 9762 Posted ... Hello!It appears there are problems with the TUN/TAP interface (TAP-Win32), that is the virtual network adapter used by OpenVPN. Assuming that OpenVPN has sufficient privileges to access the interface, it might be a Windows problem in properly resetting the default gateway after an OpenVPN disconnection. This would also explain why you sometimes need to reboot the system to regain connectivity.Try the following command (with administrator privileges) after a disconnection to check whether it solves the problem without a reboot:ipconfig /renewFor additional information about various TUN/TAP issues:http://my.anuson.com/knowledgebase/1/VPN---All-platformsKind regards Quote Share this post Link to post
jmish 0 Posted ... One of the suggestions from the link you sent worked. Thanks. You guys are awesome. Quote Share this post Link to post
