Not connected, Your IP: 3.138.102.178
I'm using Eddie on macOS Sierra which is running behind Sophos UTM 9.4 firewall.  I'm not seeing any values for score or latency, I've already allowed ICMP on the firewall. I believe the firewall is blocking something which is preventing me from getting the latency and score values. I've tried bypassing the firewall and everything worked fine. Anyone have any experience with Sophos UTM?
The Experimental Eddie client may work better with such software that you mention, in case you're not using it already
Welcome to AirVPN!
Yep, i'm using the experimental version of Eddie. Everything works without the firewall, so it's a firewall configuration thats blocking something, can't seem to find anything in the logs.
I see everything on that link you just posted, however, I still don't see the latency or the scores on the software.
If I use my phone or another VPN to bypass the firewall then the scores and latency show up immediately.
Thanks for everyones help. I've managed sort out the problem. It was dhcp option 15 - domain-name (Sophos UTM), I had to turn that off for everything to work properly.
