Guest Posted ... After every connect to VPN server through Eddie client my system is leaking DNS (tested with ipleak.net and doileak.com) for the short period of time. After literally couple of minutes leak stops and connection seems to be rock solid until reconnect. It doesn't matter if it's first connection after startup, or I manually disconnected or it's automatic reconnect. I use arch linux and latest 2.11 client. Network lock is always on. I didn't manipulate anything with firewall or iptables myself. WebRTC and ipv6 support completely disabled. Have no idea if it happened before I just spotted it accidentally yesterday. Quote Share this post Link to post
Staff 10697 Posted ... Hello!There are no DNS leaks on Linux. What Eddie version are you running ("AirVPN" > "About") and which ArchLinux version? In Eddie 2.11.1 Mono caused in some Fedora systems to cache the resolv.conf file for a couple of minutes, so new DNS were queried only after that time. However, this issue had been fixed. Probably the best course of action is that you open a ticket so that we put in you touch directly with the developers. In the ticket, please include a system report taken WHILE the problem is occurring, and a system report after the problem has ceased. To send us a system report click "Logs" tab, click the safe belt icon and paste into your message. Kind regards Quote Share this post Link to post
Guest Posted ... How can I check to be shure if network lock and resolv.conf thing work properly? Quote Share this post Link to post
Guest Posted ... I definitely have a leak at the moment of replacing resolv.conf file. My original resolv.conf looks like that: # Generated by resolvconfsearch homenameserver 192.168.1.1 Might it be cause of the problem and should I change this address? Quote Share this post Link to post
Guest Posted ... I found topic with better explanation of the issue: https://airvpn.org/topic/17932-network-lock-dns-leaks-with-default-settings/ Now I theoretically know solution but still not sure how to apply it. What server should I use instead of my home network? I tried google public ones (8.8.8.8 8.8.4.4) for tests but then Eddie is unable to connect to any server. Quote Share this post Link to post
