Not connected, Your IP: 3.147.73.35
HurderDurder
Network lock not unlocking
Running Eddie 2.11.2 on Windows 7. I have only needed to disconnect from AirvPN rarely. One of those times was today. I deactivated the network lock and closed the client cleanly. I knew if I didn't close Eddie properly I wouldn't be able to connect to the internet, an excellent feature; however, the lock has persisted after proper shut down.
I tried rebooting, no change, can't connect. Booted to safe mode with networking and still can't connect to internet. I checked firewall, rules were set back to normal. I ran network trouble shooter and it didn't detect any problems.I sure it's something that I have set up wrong or Eddie isn't resetting properly after disabling network lock.
Let me know what else I need to provide.
Have you tried 2.11.5?
You can also try resetting your DNS, by setting it obtain it automatically, in the network adapters IPv4 area . I don't know what you mean by checking your firewall rules. Did you "reset windows firewall" ?
The problem is that the DNS address in the adaptor settings is not beign reset.  Just had this myself, resetting the firewall to default will not affect this.
Just change it back to auto manually.
