r2d28u7y 0 Posted ... HI win 7. comodo , antivir, beta i just installed the application try connect to a recommended server and it only does what is in the title... what to do? also is my login password for eddie the same as for the forum? Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... The full logs, from line 1, please. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
r2d28u7y 0 Posted ... ". 2016.11.02 20:11:17 - DNS of a network adapter forced (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, from automatic (192.168.1.1) to 10.4.0.1). 2016.11.02 20:11:17 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)I 2016.11.02 20:11:17 - Flushing DNSI 2016.11.02 20:11:17 - Checking routeW 2016.11.02 20:12:08 - The operation has timed out! 2016.11.02 20:12:08 - Disconnecting. 2016.11.02 20:12:08 - Management - Send 'signal SIGTERM'. 2016.11.02 20:12:08 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.02 20:12:08 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.02 20:12:08 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.02 20:12:13 - OpenVPN > C:\Windows\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.1.1. 2016.11.02 20:12:13 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:12:13 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:12:13 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:12:13 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:12:13 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:12:13 - OpenVPN > Closing TUN/TAP interface. 2016.11.02 20:12:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.02 20:12:13 - Connection terminated.. 2016.11.02 20:12:13 - DNS of a network adapter restored to original settings (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, to automatic). 2016.11.02 20:12:13 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2016.11.02 20:12:13 - DNS leak protection with packet filtering disabled.I 2016.11.02 20:12:16 - Checking authorization ...! 2016.11.02 20:12:17 - Connecting to Dheneb (Canada, Toronto, Ontario). 2016.11.02 20:12:17 - OpenVPN > OpenVPN 2.3.12 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Sep 5 2016. 2016.11.02 20:12:17 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.11.02 20:12:17 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.11.02 20:12:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.02 20:12:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.02 20:12:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:12:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:12:17 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.11.02 20:12:17 - OpenVPN > UDPv4 link local: [undef]. 2016.11.02 20:12:17 - OpenVPN > UDPv4 link remote: [AF_INET]199.21.149.44:443. 2016.11.02 20:12:17 - OpenVPN > TLS: Initial packet from [AF_INET]199.21.149.44:443, sid=e44591fe 0e55ccbf. 2016.11.02 20:12:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.02 20:12:17 - OpenVPN > Validating certificate key usage. 2016.11.02 20:12:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.02 20:12:17 - OpenVPN > VERIFY KU OK. 2016.11.02 20:12:17 - OpenVPN > Validating certificate extended key usage. 2016.11.02 20:12:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.02 20:12:17 - OpenVPN > VERIFY EKU OK. 2016.11.02 20:12:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.02 20:12:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.02 20:12:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:12:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.02 20:12:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:12:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.02 20:12:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.21.149.44:443. 2016.11.02 20:12:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.02 20:12:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.76.197 255.255.0.0'. 2016.11.02 20:12:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.02 20:12:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.02 20:12:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.02 20:12:20 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.02 20:12:20 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.02 20:12:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.02 20:12:20 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=12 HWADDR=90:e6:ba:10:02:3e. 2016.11.02 20:12:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.02 20:12:20 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.02 20:12:20 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}.tap. 2016.11.02 20:12:20 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.02 20:12:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.76.197/255.255.0.0 [sUCCEEDED]. 2016.11.02 20:12:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.76.197/255.255.0.0 on interface {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.02 20:12:20 - OpenVPN > Successful ARP Flush on interface [39] {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}. 2016.11.02 20:12:25 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.02 20:12:25 - OpenVPN > C:\Windows\system32\route.exe ADD 199.21.149.44 MASK 255.255.255.255 192.168.1.1. 2016.11.02 20:12:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:12:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:12:25 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:12:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:12:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:12:25 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:12:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:12:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:12:25 - Starting Management Interface. 2016.11.02 20:12:25 - OpenVPN > Initialization Sequence Completed. 2016.11.02 20:12:25 - DNS leak protection with packet filtering enabled.. 2016.11.02 20:12:25 - DNS of a network adapter forced (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, from automatic (192.168.1.1) to 10.4.0.1). 2016.11.02 20:12:25 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)I 2016.11.02 20:12:25 - Flushing DNSI 2016.11.02 20:12:26 - Checking routeW 2016.11.02 20:13:16 - The operation has timed out! 2016.11.02 20:13:16 - Disconnecting. 2016.11.02 20:13:16 - Management - Send 'signal SIGTERM'. 2016.11.02 20:13:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.02 20:13:16 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.02 20:13:16 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.02 20:13:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.21.149.44 MASK 255.255.255.255 192.168.1.1. 2016.11.02 20:13:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:13:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:13:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:13:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:13:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:13:21 - OpenVPN > Closing TUN/TAP interface. 2016.11.02 20:13:21 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.02 20:13:21 - Connection terminated.. 2016.11.02 20:13:21 - DNS of a network adapter restored to original settings (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, to automatic). 2016.11.02 20:13:21 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2016.11.02 20:13:21 - DNS leak protection with packet filtering disabled.I 2016.11.02 20:13:24 - Checking authorization ...! 2016.11.02 20:13:25 - Connecting to Alkurhah (Canada, Toronto, Ontario). 2016.11.02 20:13:25 - OpenVPN > OpenVPN 2.3.12 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Sep 5 2016. 2016.11.02 20:13:25 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.11.02 20:13:25 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.11.02 20:13:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.02 20:13:25 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.02 20:13:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:13:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:13:25 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.11.02 20:13:25 - OpenVPN > UDPv4 link local: [undef]. 2016.11.02 20:13:25 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.202:443. 2016.11.02 20:13:25 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.202:443, sid=eecb2a56 436f1eef. 2016.11.02 20:13:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.02 20:13:25 - OpenVPN > Validating certificate key usage. 2016.11.02 20:13:25 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.02 20:13:25 - OpenVPN > VERIFY KU OK. 2016.11.02 20:13:25 - OpenVPN > Validating certificate extended key usage. 2016.11.02 20:13:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.02 20:13:25 - OpenVPN > VERIFY EKU OK. 2016.11.02 20:13:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.02 20:13:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.02 20:13:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:13:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.02 20:13:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:13:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.02 20:13:26 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.202:443. 2016.11.02 20:13:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.02 20:13:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.43.95 255.255.0.0'. 2016.11.02 20:13:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.02 20:13:28 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.02 20:13:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.02 20:13:28 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.02 20:13:28 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.02 20:13:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.02 20:13:28 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=12 HWADDR=90:e6:ba:10:02:3e. 2016.11.02 20:13:28 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.02 20:13:28 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.02 20:13:28 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}.tap. 2016.11.02 20:13:28 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.02 20:13:28 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.43.95/255.255.0.0 [sUCCEEDED]. 2016.11.02 20:13:28 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.43.95/255.255.0.0 on interface {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.02 20:13:28 - OpenVPN > Successful ARP Flush on interface [39] {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}. 2016.11.02 20:13:33 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.02 20:13:33 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.221.202 MASK 255.255.255.255 192.168.1.1. 2016.11.02 20:13:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:13:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:13:33 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:13:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:13:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:13:33 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:13:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:13:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:13:33 - Starting Management Interface. 2016.11.02 20:13:33 - OpenVPN > Initialization Sequence Completed. 2016.11.02 20:13:33 - DNS leak protection with packet filtering enabled.. 2016.11.02 20:13:33 - DNS of a network adapter forced (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, from automatic (192.168.1.1) to 10.4.0.1). 2016.11.02 20:13:33 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)I 2016.11.02 20:13:33 - Flushing DNSI 2016.11.02 20:13:33 - Checking routeW 2016.11.02 20:14:23 - The operation has timed out! 2016.11.02 20:14:24 - Disconnecting. 2016.11.02 20:14:24 - Management - Send 'signal SIGTERM'. 2016.11.02 20:14:24 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.02 20:14:24 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.02 20:14:24 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.02 20:14:29 - OpenVPN > C:\Windows\system32\route.exe DELETE 184.75.221.202 MASK 255.255.255.255 192.168.1.1. 2016.11.02 20:14:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:14:29 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:14:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:14:29 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:14:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:14:29 - OpenVPN > Closing TUN/TAP interface. 2016.11.02 20:14:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.02 20:14:29 - Connection terminated.. 2016.11.02 20:14:29 - DNS of a network adapter restored to original settings (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, to automatic). 2016.11.02 20:14:29 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2016.11.02 20:14:29 - DNS leak protection with packet filtering disabled.I 2016.11.02 20:14:32 - Checking authorization ...! 2016.11.02 20:14:32 - Connecting to Regulus (Canada, Toronto, Ontario). 2016.11.02 20:14:33 - OpenVPN > OpenVPN 2.3.12 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Sep 5 2016. 2016.11.02 20:14:33 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.11.02 20:14:33 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.11.02 20:14:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.02 20:14:33 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.02 20:14:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:14:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:14:33 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.11.02 20:14:33 - OpenVPN > UDPv4 link local: [undef]. 2016.11.02 20:14:33 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.34:443. 2016.11.02 20:14:33 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.34:443, sid=7b528389 a5041fee. 2016.11.02 20:14:33 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.02 20:14:33 - OpenVPN > Validating certificate key usage. 2016.11.02 20:14:33 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.02 20:14:33 - OpenVPN > VERIFY KU OK. 2016.11.02 20:14:33 - OpenVPN > Validating certificate extended key usage. 2016.11.02 20:14:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.02 20:14:33 - OpenVPN > VERIFY EKU OK. 2016.11.02 20:14:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.02 20:14:33 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.02 20:14:33 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:14:33 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.02 20:14:33 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.02 20:14:33 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.02 20:14:33 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.34:443. 2016.11.02 20:14:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.02 20:14:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.42.190 255.255.0.0'. 2016.11.02 20:14:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.02 20:14:36 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.02 20:14:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.02 20:14:36 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.02 20:14:36 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.02 20:14:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.02 20:14:36 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=12 HWADDR=90:e6:ba:10:02:3e. 2016.11.02 20:14:36 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.02 20:14:36 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.02 20:14:36 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}.tap. 2016.11.02 20:14:36 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.02 20:14:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.42.190/255.255.0.0 [sUCCEEDED]. 2016.11.02 20:14:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.42.190/255.255.0.0 on interface {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.02 20:14:36 - OpenVPN > Successful ARP Flush on interface [39] {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}. 2016.11.02 20:14:41 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.02 20:14:41 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.221.34 MASK 255.255.255.255 192.168.1.1. 2016.11.02 20:14:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:14:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:14:41 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:14:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:14:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:14:41 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:14:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.02 20:14:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.02 20:14:41 - Starting Management Interface. 2016.11.02 20:14:41 - OpenVPN > Initialization Sequence Completed. 2016.11.02 20:14:41 - DNS leak protection with packet filtering enabled.. 2016.11.02 20:14:41 - DNS of a network adapter forced (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, from automatic (192.168.1.1) to 10.4.0.1). 2016.11.02 20:14:41 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)I 2016.11.02 20:14:41 - Flushing DNSI 2016.11.02 20:14:41 - Checking routeW 2016.11.02 20:15:31 - The operation has timed out! 2016.11.02 20:15:31 - Disconnecting. 2016.11.02 20:15:31 - Management - Send 'signal SIGTERM'. 2016.11.02 20:15:31 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.02 20:15:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.02 20:15:31 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.02 20:15:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 184.75.221.34 MASK 255.255.255.255 192.168.1.1. 2016.11.02 20:15:36 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:15:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:15:36 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:15:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.02 20:15:36 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.02 20:15:36 - OpenVPN > Closing TUN/TAP interface. 2016.11.02 20:15:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.02 20:15:36 - Connection terminated.. 2016.11.02 20:15:36 - DNS of a network adapter restored to original settings (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, to automatic). 2016.11.02 20:15:36 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2016.11.02 20:15:36 - DNS leak protection with packet filtering disabled.I 2016.11.02 20:15:36 - Cancel requested.. 2016.11.02 20:15:36 - IPv6 restored with packet filtering.! 2016.11.02 20:15:37 - Session terminated.. 2016.11.02 20:21:16 - Updating systems & servers data .... 2016.11.02 20:21:17 - Systems & servers data update completed. 2016.11.02 20:31:17 - Updating systems & servers data .... 2016.11.02 20:31:18 - Systems & servers data update completed. 2016.11.02 20:41:18 - Updating systems & servers data .... 2016.11.02 20:41:19 - Systems & servers data update completed. 2016.11.02 20:51:19 - Updating systems & servers data .... 2016.11.02 20:51:20 - Systems & servers data update completed. 2016.11.02 21:01:20 - Updating systems & servers data .... 2016.11.02 21:01:21 - Systems & servers data update completed. 2016.11.02 21:11:21 - Updating systems & servers data .... 2016.11.02 21:11:22 - Systems & servers data update completed. 2016.11.02 21:21:22 - Updating systems & servers data .... 2016.11.02 21:21:23 - Systems & servers data update completed. 2016.11.02 21:31:23 - Updating systems & servers data .... 2016.11.02 21:31:24 - Systems & servers data update completed. 2016.11.02 21:41:24 - Updating systems & servers data .... 2016.11.02 21:41:25 - Systems & servers data update completed. 2016.11.02 21:51:25 - Updating systems & servers data .... 2016.11.02 21:51:26 - Systems & servers data update completed. 2016.11.02 22:01:26 - Updating systems & servers data .... 2016.11.02 22:01:27 - Systems & servers data update completed. 2016.11.02 22:11:27 - Updating systems & servers data .... 2016.11.02 22:11:28 - Systems & servers data update completed. 2016.11.02 22:21:28 - Updating systems & servers data .... 2016.11.02 22:21:29 - Systems & servers data update completed. 2016.11.02 22:31:29 - Updating systems & servers data .... 2016.11.02 22:31:31 - Systems & servers data update completed. 2016.11.02 22:41:31 - Updating systems & servers data .... 2016.11.02 22:41:32 - Systems & servers data update completed. 2016.11.02 22:52:32 - Updating systems & servers data .... 2016.11.02 22:52:33 - Systems & servers data update completed. 2016.11.02 23:02:33 - Updating systems & servers data .... 2016.11.02 23:02:34 - Systems & servers data update completed. 2016.11.02 23:12:34 - Updating systems & servers data .... 2016.11.02 23:12:35 - Systems & servers data update completed. 2016.11.02 23:22:35 - Updating systems & servers data .... 2016.11.02 23:22:36 - Systems & servers data update completed. 2016.11.02 23:32:36 - Updating systems & servers data .... 2016.11.02 23:32:37 - Systems & servers data update completed. 2016.11.02 23:42:37 - Updating systems & servers data .... 2016.11.02 23:42:37 - Systems & servers data update completed. 2016.11.02 23:52:37 - Updating systems & servers data .... 2016.11.02 23:52:38 - Systems & servers data update completed. 2016.11.03 00:02:38 - Updating systems & servers data .... 2016.11.03 00:02:39 - Systems & servers data update completed. 2016.11.03 00:12:39 - Updating systems & servers data .... 2016.11.03 00:12:40 - Systems & servers data update completed. 2016.11.03 00:22:40 - Updating systems & servers data .... 2016.11.03 00:22:41 - Systems & servers data update completed. 2016.11.03 00:32:41 - Updating systems & servers data .... 2016.11.03 00:32:42 - Systems & servers data update completed. 2016.11.03 00:42:42 - Updating systems & servers data .... 2016.11.03 00:42:43 - Systems & servers data update completed. 2016.11.03 00:53:43 - Updating systems & servers data .... 2016.11.03 00:53:44 - Systems & servers data update completed. 2016.11.03 01:03:44 - Updating systems & servers data .... 2016.11.03 01:03:45 - Systems & servers data update completed. 2016.11.03 01:13:45 - Updating systems & servers data .... 2016.11.03 01:13:45 - Systems & servers data update completed. 2016.11.03 01:23:46 - Updating systems & servers data .... 2016.11.03 01:23:46 - Systems & servers data update completed. 2016.11.03 01:33:46 - Updating systems & servers data .... 2016.11.03 01:33:47 - Systems & servers data update completed. 2016.11.03 01:43:47 - Updating systems & servers data .... 2016.11.03 01:43:48 - Systems & servers data update completed. 2016.11.03 01:53:48 - Updating systems & servers data .... 2016.11.03 01:53:49 - Systems & servers data update completed. 2016.11.03 02:03:49 - Updating systems & servers data .... 2016.11.03 02:03:50 - Systems & servers data update completed. 2016.11.03 02:14:50 - Updating systems & servers data .... 2016.11.03 02:14:51 - Systems & servers data update completed. 2016.11.03 02:24:51 - Updating systems & servers data .... 2016.11.03 02:24:52 - Systems & servers data update completed. 2016.11.03 02:34:52 - Updating systems & servers data .... 2016.11.03 02:34:52 - Systems & servers data update completed. 2016.11.03 02:44:52 - Updating systems & servers data .... 2016.11.03 02:44:53 - Systems & servers data update completed. 2016.11.03 02:54:53 - Updating systems & servers data .... 2016.11.03 02:54:54 - Systems & servers data update completed. 2016.11.03 03:04:54 - Updating systems & servers data .... 2016.11.03 03:04:55 - Systems & servers data update completed. 2016.11.03 03:14:55 - Updating systems & servers data .... 2016.11.03 03:14:56 - Systems & servers data update completed. 2016.11.03 03:25:56 - Updating systems & servers data .... 2016.11.03 03:25:57 - Systems & servers data update completed. 2016.11.03 03:35:57 - Updating systems & servers data .... 2016.11.03 03:35:58 - Systems & servers data update completed. 2016.11.03 03:45:58 - Updating systems & servers data .... 2016.11.03 03:45:58 - Systems & servers data update completed. 2016.11.03 03:55:59 - Updating systems & servers data .... 2016.11.03 03:55:59 - Systems & servers data update completed. 2016.11.03 04:05:59 - Updating systems & servers data .... 2016.11.03 04:06:00 - Systems & servers data update completed. 2016.11.03 04:16:00 - Updating systems & servers data .... 2016.11.03 04:16:01 - Systems & servers data update completed. 2016.11.03 04:26:01 - Updating systems & servers data .... 2016.11.03 04:26:02 - Systems & servers data update completed. 2016.11.03 04:37:02 - Updating systems & servers data .... 2016.11.03 04:37:03 - Systems & servers data update completed. 2016.11.03 04:47:03 - Updating systems & servers data .... 2016.11.03 04:47:04 - Systems & servers data update completed. 2016.11.03 04:57:04 - Updating systems & servers data .... 2016.11.03 04:57:04 - Systems & servers data update completed. 2016.11.03 05:07:05 - Updating systems & servers data .... 2016.11.03 05:07:05 - Systems & servers data update completed. 2016.11.03 05:17:05 - Updating systems & servers data .... 2016.11.03 05:17:06 - Systems & servers data update completed. 2016.11.03 05:27:06 - Updating systems & servers data .... 2016.11.03 05:27:07 - Systems & servers data update completed. 2016.11.03 05:37:07 - Updating systems & servers data .... 2016.11.03 05:37:08 - Systems & servers data update completed. 2016.11.03 05:48:08 - Updating systems & servers data .... 2016.11.03 05:48:09 - Systems & servers data update completed. 2016.11.03 05:58:09 - Updating systems & servers data .... 2016.11.03 05:58:10 - Systems & servers data update completed. 2016.11.03 06:08:10 - Updating systems & servers data .... 2016.11.03 06:08:11 - Systems & servers data update completed. 2016.11.03 06:18:11 - Updating systems & servers data .... 2016.11.03 06:18:11 - Systems & servers data update completed. 2016.11.03 06:28:11 - Updating systems & servers data .... 2016.11.03 06:28:12 - Systems & servers data update completed. 2016.11.03 06:38:12 - Updating systems & servers data .... 2016.11.03 06:38:13 - Systems & servers data update completed. 2016.11.03 06:48:13 - Updating systems & servers data .... 2016.11.03 06:48:14 - Systems & servers data update completed. 2016.11.03 06:58:14 - Updating systems & servers data .... 2016.11.03 06:58:15 - Systems & servers data update completed. 2016.11.03 07:09:15 - Updating systems & servers data .... 2016.11.03 07:09:16 - Systems & servers data update completed. 2016.11.03 07:19:16 - Updating systems & servers data .... 2016.11.03 07:19:17 - Systems & servers data update completed. 2016.11.03 07:29:17 - Updating systems & servers data .... 2016.11.03 07:29:17 - Systems & servers data update completed. 2016.11.03 07:39:17 - Updating systems & servers data .... 2016.11.03 07:39:18 - Systems & servers data update completed. 2016.11.03 07:49:18 - Updating systems & servers data .... 2016.11.03 07:49:19 - Systems & servers data update completed. 2016.11.03 07:59:19 - Updating systems & servers data .... 2016.11.03 07:59:20 - Systems & servers data update completed. 2016.11.03 08:09:20 - Updating systems & servers data .... 2016.11.03 08:09:21 - Systems & servers data update completed. 2016.11.03 08:20:21 - Updating systems & servers data .... 2016.11.03 08:20:22 - Systems & servers data update completed. 2016.11.03 08:30:22 - Updating systems & servers data .... 2016.11.03 08:30:24 - Systems & servers data update completed. 2016.11.03 08:40:24 - Updating systems & servers data .... 2016.11.03 08:40:24 - Systems & servers data update completed. 2016.11.03 08:50:24 - Updating systems & servers data .... 2016.11.03 08:50:25 - Systems & servers data update completed. 2016.11.03 09:00:25 - Updating systems & servers data .... 2016.11.03 09:00:26 - Systems & servers data update completed. 2016.11.03 09:10:26 - Updating systems & servers data .... 2016.11.03 09:10:27 - Systems & servers data update completed. 2016.11.03 09:20:27 - Updating systems & servers data .... 2016.11.03 09:20:28 - Systems & servers data update completed. 2016.11.03 09:31:28 - Updating systems & servers data .... 2016.11.03 09:31:29 - Systems & servers data update completed. 2016.11.03 09:41:29 - Updating systems & servers data .... 2016.11.03 09:41:30 - Systems & servers data update completed. 2016.11.03 09:51:30 - Updating systems & servers data .... 2016.11.03 09:51:30 - Systems & servers data update completed. 2016.11.03 10:01:31 - Updating systems & servers data .... 2016.11.03 10:01:31 - Systems & servers data update completed. 2016.11.03 10:11:31 - Updating systems & servers data .... 2016.11.03 10:11:32 - Systems & servers data update completed. 2016.11.03 10:21:32 - Updating systems & servers data .... 2016.11.03 10:21:33 - Systems & servers data update completed. 2016.11.03 10:31:33 - Updating systems & servers data .... 2016.11.03 10:31:34 - Systems & servers data update completed. 2016.11.03 10:41:34 - Updating systems & servers data .... 2016.11.03 10:41:35 - Systems & servers data update completed. 2016.11.03 10:52:35 - Updating systems & servers data .... 2016.11.03 10:52:36 - Systems & servers data update completed. 2016.11.03 11:02:36 - Updating systems & servers data .... 2016.11.03 11:02:37 - Systems & servers data update completed. 2016.11.03 11:12:37 - Updating systems & servers data .... 2016.11.03 11:12:37 - Systems & servers data update completed. 2016.11.03 11:22:37 - Updating systems & servers data .... 2016.11.03 11:22:38 - Systems & servers data update completed. 2016.11.03 11:32:38 - Updating systems & servers data .... 2016.11.03 11:32:39 - Systems & servers data update completed. 2016.11.03 11:42:39 - Updating systems & servers data .... 2016.11.03 11:42:40 - Systems & servers data update completed. 2016.11.03 11:52:40 - Updating systems & servers data .... 2016.11.03 11:52:41 - Systems & servers data update completed. 2016.11.03 12:03:41 - Updating systems & servers data .... 2016.11.03 12:03:42 - Systems & servers data update completed. 2016.11.03 12:13:42 - Updating systems & servers data .... 2016.11.03 12:13:43 - Systems & servers data update completed. 2016.11.03 12:23:43 - Updating systems & servers data .... 2016.11.03 12:23:43 - Systems & servers data update completed. 2016.11.03 12:33:43 - Updating systems & servers data .... 2016.11.03 12:33:44 - Systems & servers data update completed. 2016.11.03 12:43:44 - Updating systems & servers data .... 2016.11.03 12:43:45 - Systems & servers data update completed. 2016.11.03 12:53:45 - Updating systems & servers data .... 2016.11.03 12:53:46 - Systems & servers data update completed. 2016.11.03 13:03:46 - Updating systems & servers data .... 2016.11.03 13:03:47 - Systems & servers data update completed. 2016.11.03 13:14:47 - Updating systems & servers data .... 2016.11.03 13:14:48 - Systems & servers data update completed. 2016.11.03 13:24:48 - Updating systems & servers data .... 2016.11.03 13:24:49 - Systems & servers data update completed. 2016.11.03 13:34:49 - Updating systems & servers data .... 2016.11.03 13:34:50 - Systems & servers data update completed. 2016.11.03 13:44:50 - Updating systems & servers data .... 2016.11.03 13:44:51 - Systems & servers data update completed. 2016.11.03 13:54:51 - Updating systems & servers data .... 2016.11.03 13:54:51 - Systems & servers data update completed. 2016.11.03 14:04:51 - Updating systems & servers data .... 2016.11.03 14:04:52 - Systems & servers data update completed. 2016.11.03 14:14:52 - Updating systems & servers data .... 2016.11.03 14:14:53 - Systems & servers data update completed. 2016.11.03 14:24:53 - Updating systems & servers data .... 2016.11.03 14:24:54 - Systems & servers data update completed. 2016.11.03 14:35:54 - Updating systems & servers data .... 2016.11.03 14:35:55 - Systems & servers data update completed. 2016.11.03 14:45:55 - Updating systems & servers data .... 2016.11.03 14:45:56 - Systems & servers data update completed. 2016.11.03 14:55:56 - Updating systems & servers data .... 2016.11.03 14:55:57 - Systems & servers data update completed. 2016.11.03 15:05:57 - Updating systems & servers data .... 2016.11.03 15:05:57 - Systems & servers data update completed. 2016.11.03 15:15:57 - Updating systems & servers data .... 2016.11.03 15:15:58 - Systems & servers data update completed. 2016.11.03 15:25:58 - Updating systems & servers data .... 2016.11.03 15:25:59 - Systems & servers data update completed. 2016.11.03 15:35:59 - Updating systems & servers data .... 2016.11.03 15:36:00 - Systems & servers data update completed. 2016.11.03 15:46:00 - Updating systems & servers data .... 2016.11.03 15:46:01 - Systems & servers data update completed. 2016.11.03 15:56:01 - Updating systems & servers data .... 2016.11.03 15:56:02 - Systems & servers data update completed. 2016.11.03 16:07:02 - Updating systems & servers data .... 2016.11.03 16:07:03 - Systems & servers data update completed. 2016.11.03 16:17:03 - Updating systems & servers data .... 2016.11.03 16:17:04 - Systems & servers data update completed. 2016.11.03 16:27:04 - Updating systems & servers data .... 2016.11.03 16:27:04 - Systems & servers data update completed. 2016.11.03 16:37:04 - Updating systems & servers data .... 2016.11.03 16:37:05 - Systems & servers data update completed. 2016.11.03 16:47:05 - Updating systems & servers data .... 2016.11.03 16:47:06 - Systems & servers data update completed. 2016.11.03 16:57:06 - Updating systems & servers data .... 2016.11.03 16:57:07 - Systems & servers data update completed. 2016.11.03 17:07:07 - Updating systems & servers data .... 2016.11.03 17:07:08 - Systems & servers data update completed. 2016.11.03 17:18:08 - Updating systems & servers data .... 2016.11.03 17:18:09 - Systems & servers data update completed. 2016.11.03 17:28:09 - Updating systems & servers data .... 2016.11.03 17:28:10 - Systems & servers data update completed. 2016.11.03 17:38:10 - Updating systems & servers data .... 2016.11.03 17:38:11 - Systems & servers data update completed. 2016.11.03 17:48:11 - Updating systems & servers data .... 2016.11.03 17:48:12 - Systems & servers data update completed. 2016.11.03 17:58:12 - Updating systems & servers data .... 2016.11.03 17:58:12 - Systems & servers data update completed. 2016.11.03 18:08:12 - Updating systems & servers data .... 2016.11.03 18:08:13 - Systems & servers data update completed. 2016.11.03 18:18:13 - Updating systems & servers data .... 2016.11.03 18:18:14 - Systems & servers data update completed. 2016.11.03 18:28:14 - Updating systems & servers data .... 2016.11.03 18:28:15 - Systems & servers data update completed. 2016.11.03 18:38:15 - Updating systems & servers data .... 2016.11.03 18:38:16 - Systems & servers data update completed. 2016.11.03 18:48:16 - Updating systems & servers data .... 2016.11.03 18:48:17 - Systems & servers data update completed. 2016.11.03 18:59:17 - Updating systems & servers data .... 2016.11.03 18:59:18 - Systems & servers data update completed. 2016.11.03 19:09:18 - Updating systems & servers data .... 2016.11.03 19:09:19 - Systems & servers data update completed. 2016.11.03 19:19:19 - Updating systems & servers data .... 2016.11.03 19:19:20 - Systems & servers data update completed. 2016.11.03 19:29:20 - Updating systems & servers data .... 2016.11.03 19:29:21 - Systems & servers data update completed. 2016.11.03 19:39:21 - Updating systems & servers data .... 2016.11.03 19:39:21 - Systems & servers data update completed. 2016.11.03 19:49:22 - Updating systems & servers data .... 2016.11.03 19:49:22 - Systems & servers data update completed. 2016.11.03 19:59:22 - Updating systems & servers data .... 2016.11.03 19:59:23 - Systems & servers data update completed. 2016.11.03 20:09:23 - Updating systems & servers data .... 2016.11.03 20:09:24 - Systems & servers data update completed. 2016.11.03 20:19:24 - Updating systems & servers data .... 2016.11.03 20:19:25 - Systems & servers data update completed. 2016.11.03 20:29:25 - Updating systems & servers data .... 2016.11.03 20:29:26 - Systems & servers data update completed. 2016.11.03 20:39:26 - Updating systems & servers data .... 2016.11.03 20:39:27 - Systems & servers data update completed. 2016.11.03 20:49:27 - Updating systems & servers data .... 2016.11.03 20:49:28 - Systems & servers data update completed. 2016.11.03 21:00:28 - Updating systems & servers data .... 2016.11.03 21:00:30 - Systems & servers data update completed. 2016.11.03 21:10:30 - Updating systems & servers data .... 2016.11.03 21:10:32 - Systems & servers data update completed. 2016.11.03 21:20:32 - Updating systems & servers data .... 2016.11.03 21:20:33 - Systems & servers data update completed. 2016.11.03 21:30:33 - Updating systems & servers data .... 2016.11.03 21:30:34 - Systems & servers data update completed. 2016.11.03 21:40:34 - Updating systems & servers data .... 2016.11.03 21:40:34 - Systems & servers data update completed. 2016.11.03 21:50:34 - Updating systems & servers data .... 2016.11.03 21:50:35 - Systems & servers data update completed. 2016.11.03 22:00:35 - Updating systems & servers data .... 2016.11.03 22:00:36 - Systems & servers data update completed. 2016.11.03 22:10:36 - Updating systems & servers data .... 2016.11.03 22:10:38 - Systems & servers data update completed. 2016.11.03 22:20:38 - Updating systems & servers data .... 2016.11.03 22:20:39 - Systems & servers data update completed. 2016.11.03 22:30:39 - Updating systems & servers data .... 2016.11.03 22:30:39 - Systems & servers data update completed. 2016.11.03 22:40:40 - Updating systems & servers data .... 2016.11.03 22:40:40 - Systems & servers data update completed. 2016.11.03 22:50:40 - Updating systems & servers data .... 2016.11.03 22:50:41 - Systems & servers data update completed. 2016.11.03 23:00:41 - Updating systems & servers data .... 2016.11.03 23:00:42 - Systems & servers data update completed. 2016.11.03 23:10:42 - Updating systems & servers data .... 2016.11.03 23:10:43 - Systems & servers data update completed. 2016.11.03 23:20:43 - Updating systems & servers data .... 2016.11.03 23:20:44 - Systems & servers data update completed. 2016.11.03 23:30:44 - Updating systems & servers data .... 2016.11.03 23:30:45 - Systems & servers data update completed. 2016.11.03 23:40:45 - Updating systems & servers data .... 2016.11.03 23:40:46 - Systems & servers data update completed. 2016.11.03 23:51:46 - Updating systems & servers data .... 2016.11.03 23:51:47 - Systems & servers data update completed. 2016.11.04 00:01:47 - Updating systems & servers data .... 2016.11.04 00:01:48 - Systems & servers data update completed. 2016.11.04 00:11:48 - Updating systems & servers data .... 2016.11.04 00:11:49 - Systems & servers data update completed. 2016.11.04 00:21:49 - Updating systems & servers data .... 2016.11.04 00:21:49 - Systems & servers data update completed. 2016.11.04 00:31:49 - Updating systems & servers data .... 2016.11.04 00:31:50 - Systems & servers data update completed. 2016.11.04 00:41:50 - Updating systems & servers data .... 2016.11.04 00:41:51 - Systems & servers data update completed. 2016.11.04 00:51:51 - Updating systems & servers data .... 2016.11.04 00:51:52 - Systems & servers data update completed. 2016.11.04 01:02:52 - Updating systems & servers data .... 2016.11.04 01:02:53 - Systems & servers data update completed. 2016.11.04 01:12:53 - Updating systems & servers data .... 2016.11.04 01:12:54 - Systems & servers data update completed. 2016.11.04 01:22:54 - Updating systems & servers data .... 2016.11.04 01:22:54 - Systems & servers data update completed. 2016.11.04 01:32:55 - Updating systems & servers data .... 2016.11.04 01:32:55 - Systems & servers data update completed. 2016.11.04 01:42:55 - Updating systems & servers data .... 2016.11.04 01:42:56 - Systems & servers data update completed. 2016.11.04 01:52:56 - Updating systems & servers data .... 2016.11.04 01:52:57 - Systems & servers data update completed. 2016.11.04 02:02:57 - Updating systems & servers data .... 2016.11.04 02:02:58 - Systems & servers data update completed. 2016.11.04 02:12:58 - Updating systems & servers data .... 2016.11.04 02:12:59 - Systems & servers data update completed. 2016.11.04 02:23:59 - Updating systems & servers data .... 2016.11.04 02:24:00 - Systems & servers data update completed. 2016.11.04 02:34:00 - Updating systems & servers data .... 2016.11.04 02:34:01 - Systems & servers data update completed. 2016.11.04 02:44:01 - Updating systems & servers data .... 2016.11.04 02:44:01 - Systems & servers data update completed. 2016.11.04 02:54:02 - Updating systems & servers data .... 2016.11.04 02:54:02 - Systems & servers data update completed. 2016.11.04 03:04:02 - Updating systems & servers data .... 2016.11.04 03:04:03 - Systems & servers data update completed. 2016.11.04 03:14:03 - Updating systems & servers data .... 2016.11.04 03:14:04 - Systems & servers data update completed. 2016.11.04 03:24:04 - Updating systems & servers data .... 2016.11.04 03:24:05 - Systems & servers data update completed. 2016.11.04 03:35:05 - Updating systems & servers data .... 2016.11.04 03:35:06 - Systems & servers data update completed. 2016.11.04 03:45:06 - Updating systems & servers data .... 2016.11.04 03:45:07 - Systems & servers data update completed. 2016.11.04 03:55:07 - Updating systems & servers data .... 2016.11.04 03:55:07 - Systems & servers data update completed. 2016.11.04 04:05:08 - Updating systems & servers data .... 2016.11.04 04:05:08 - Systems & servers data update completed. 2016.11.04 04:15:08 - Updating systems & servers data .... 2016.11.04 04:15:09 - Systems & servers data update completed. 2016.11.04 04:25:09 - Updating systems & servers data .... 2016.11.04 04:25:10 - Systems & servers data update completed. 2016.11.04 04:35:10 - Updating systems & servers data .... 2016.11.04 04:35:11 - Systems & servers data update completed. 2016.11.04 04:45:11 - Updating systems & servers data .... 2016.11.04 04:45:12 - Systems & servers data update completed. 2016.11.04 04:56:12 - Updating systems & servers data .... 2016.11.04 04:56:13 - Systems & servers data update completed. 2016.11.04 05:06:13 - Updating systems & servers data .... 2016.11.04 05:06:14 - Systems & servers data update completed. 2016.11.04 05:16:14 - Updating systems & servers data .... 2016.11.04 05:16:14 - Systems & servers data update completed. 2016.11.04 05:26:15 - Updating systems & servers data .... 2016.11.04 05:26:15 - Systems & servers data update completed. 2016.11.04 05:36:15 - Updating systems & servers data .... 2016.11.04 05:36:16 - Systems & servers data update completed. 2016.11.04 05:46:16 - Updating systems & servers data .... 2016.11.04 05:46:17 - Systems & servers data update completed. 2016.11.04 05:56:17 - Updating systems & servers data .... 2016.11.04 05:56:18 - Systems & servers data update completed. 2016.11.04 06:06:18 - Updating systems & servers data .... 2016.11.04 06:06:19 - Systems & servers data update completed. 2016.11.04 06:17:19 - Updating systems & servers data .... 2016.11.04 06:17:20 - Systems & servers data update completed. 2016.11.04 06:27:20 - Updating systems & servers data .... 2016.11.04 06:27:21 - Systems & servers data update completed. 2016.11.04 06:37:21 - Updating systems & servers data .... 2016.11.04 06:37:21 - Systems & servers data update completed. 2016.11.04 06:47:22 - Updating systems & servers data .... 2016.11.04 06:47:22 - Systems & servers data update completed. 2016.11.04 06:57:22 - Updating systems & servers data .... 2016.11.04 06:57:23 - Systems & servers data update completed. 2016.11.04 07:07:23 - Updating systems & servers data .... 2016.11.04 07:07:24 - Systems & servers data update completed. 2016.11.04 07:17:24 - Updating systems & servers data .... 2016.11.04 07:17:25 - Systems & servers data update completed. 2016.11.04 07:28:25 - Updating systems & servers data .... 2016.11.04 07:28:26 - Systems & servers data update completed. 2016.11.04 07:38:26 - Updating systems & servers data .... 2016.11.04 07:38:27 - Systems & servers data update completed. 2016.11.04 07:48:27 - Updating systems & servers data .... 2016.11.04 07:48:27 - Systems & servers data update completed. 2016.11.04 07:58:28 - Updating systems & servers data .... 2016.11.04 07:58:28 - Systems & servers data update completed. 2016.11.04 08:08:28 - Updating systems & servers data .... 2016.11.04 08:08:29 - Systems & servers data update completed. 2016.11.04 08:18:29 - Updating systems & servers data .... 2016.11.04 08:18:30 - Systems & servers data update completed. 2016.11.04 08:28:30 - Updating systems & servers data .... 2016.11.04 08:28:31 - Systems & servers data update completed. 2016.11.04 08:39:31 - Updating systems & servers data .... 2016.11.04 08:39:32 - Systems & servers data update completed. 2016.11.04 08:49:32 - Updating systems & servers data .... 2016.11.04 08:49:33 - Systems & servers data update completed. 2016.11.04 08:59:33 - Updating systems & servers data .... 2016.11.04 08:59:34 - Systems & servers data update completed. 2016.11.04 09:09:34 - Updating systems & servers data .... 2016.11.04 09:09:35 - Systems & servers data update completed. 2016.11.04 09:19:35 - Updating systems & servers data .... 2016.11.04 09:19:36 - Systems & servers data update completed. 2016.11.04 09:29:36 - Updating systems & servers data .... 2016.11.04 09:29:36 - Systems & servers data update completed. 2016.11.04 09:39:36 - Updating systems & servers data .... 2016.11.04 09:39:37 - Systems & servers data update completed. 2016.11.04 09:49:37 - Updating systems & servers data .... 2016.11.04 09:49:38 - Systems & servers data update completed. 2016.11.04 09:59:38 - Updating systems & servers data .... 2016.11.04 09:59:39 - Systems & servers data update completed. 2016.11.04 10:09:39 - Updating systems & servers data .... 2016.11.04 10:09:40 - Systems & servers data update completed. 2016.11.04 10:20:40 - Updating systems & servers data .... 2016.11.04 10:20:42 - Systems & servers data update completed. 2016.11.04 10:30:42 - Updating systems & servers data .... 2016.11.04 10:30:43 - Systems & servers data update completed. 2016.11.04 10:40:43 - Updating systems & servers data .... 2016.11.04 10:40:44 - Systems & servers data update completed. 2016.11.04 10:50:44 - Updating systems & servers data .... 2016.11.04 10:50:45 - Systems & servers data update completed. 2016.11.04 11:00:45 - Updating systems & servers data .... 2016.11.04 11:00:45 - Systems & servers data update completed. 2016.11.04 11:10:45 - Updating systems & servers data .... 2016.11.04 11:10:46 - Systems & servers data update completed. 2016.11.04 11:20:46 - Updating systems & servers data .... 2016.11.04 11:20:47 - Systems & servers data update completed. 2016.11.04 11:30:47 - Updating systems & servers data .... 2016.11.04 11:30:48 - Systems & servers data update completed. 2016.11.04 11:40:48 - Updating systems & servers data .... 2016.11.04 11:40:49 - Systems & servers data update completed. 2016.11.04 11:50:49 - Updating systems & servers data .... 2016.11.04 11:50:50 - Systems & servers data update completed. 2016.11.04 12:01:50 - Updating systems & servers data .... 2016.11.04 12:01:51 - Systems & servers data update completed. 2016.11.04 12:11:51 - Updating systems & servers data .... 2016.11.04 12:11:52 - Systems & servers data update completed. 2016.11.04 12:21:52 - Updating systems & servers data .... 2016.11.04 12:21:52 - Systems & servers data update completed. 2016.11.04 12:31:52 - Updating systems & servers data .... 2016.11.04 12:31:53 - Systems & servers data update completed. 2016.11.04 12:41:53 - Updating systems & servers data .... 2016.11.04 12:41:54 - Systems & servers data update completed. 2016.11.04 12:51:54 - Updating systems & servers data .... 2016.11.04 12:51:55 - Systems & servers data update completed. 2016.11.04 13:01:55 - Updating systems & servers data .... 2016.11.04 13:01:56 - Systems & servers data update completed. 2016.11.04 13:12:56 - Updating systems & servers data .... 2016.11.04 13:12:57 - Systems & servers data update completed. 2016.11.04 13:22:57 - Updating systems & servers data .... 2016.11.04 13:22:58 - Systems & servers data update completed. 2016.11.04 13:32:58 - Updating systems & servers data .... 2016.11.04 13:32:58 - Systems & servers data update completed. 2016.11.04 13:42:58 - Updating systems & servers data .... 2016.11.04 13:42:59 - Systems & servers data update completed. 2016.11.04 13:52:59 - Updating systems & servers data .... 2016.11.04 13:53:00 - Systems & servers data update completed. 2016.11.04 14:03:00 - Updating systems & servers data .... 2016.11.04 14:03:01 - Systems & servers data update completed. 2016.11.04 14:13:01 - Updating systems & servers data .... 2016.11.04 14:13:02 - Systems & servers data update completed. 2016.11.04 14:23:02 - Updating systems & servers data .... 2016.11.04 14:23:03 - Systems & servers data update completed. 2016.11.04 14:34:03 - Updating systems & servers data .... 2016.11.04 14:34:04 - Systems & servers data update completed. 2016.11.04 14:44:04 - Updating systems & servers data .... 2016.11.04 14:44:05 - Systems & servers data update completed. 2016.11.04 14:54:05 - Updating systems & servers data .... 2016.11.04 14:54:05 - Systems & servers data update completed. 2016.11.04 15:04:05 - Updating systems & servers data .... 2016.11.04 15:04:06 - Systems & servers data update completed. 2016.11.04 15:14:06 - Updating systems & servers data .... 2016.11.04 15:14:07 - Systems & servers data update completed. 2016.11.04 15:24:07 - Updating systems & servers data .... 2016.11.04 15:24:08 - Systems & servers data update completed. 2016.11.04 15:34:08 - Updating systems & servers data .... 2016.11.04 15:34:09 - Systems & servers data update completed. 2016.11.04 15:45:09 - Updating systems & servers data .... 2016.11.04 15:45:10 - Systems & servers data update completed. 2016.11.04 15:55:10 - Updating systems & servers data .... 2016.11.04 15:55:11 - Systems & servers data update completed. 2016.11.04 16:05:11 - Updating systems & servers data .... 2016.11.04 16:05:11 - Systems & servers data update completed. 2016.11.04 16:15:11 - Updating systems & servers data .... 2016.11.04 16:15:12 - Systems & servers data update completed. 2016.11.04 16:25:12 - Updating systems & servers data .... 2016.11.04 16:25:13 - Systems & servers data update completed. 2016.11.04 16:35:13 - Updating systems & servers data .... 2016.11.04 16:35:14 - Systems & servers data update completed. 2016.11.04 16:45:14 - Updating systems & servers data .... 2016.11.04 16:45:15 - Systems & servers data update completed. 2016.11.04 16:55:15 - Updating systems & servers data .... 2016.11.04 16:55:16 - Systems & servers data update completed. 2016.11.04 17:06:16 - Updating systems & servers data .... 2016.11.04 17:06:17 - Systems & servers data update completed. 2016.11.04 17:16:17 - Updating systems & servers data .... 2016.11.04 17:16:18 - Systems & servers data update completed. 2016.11.04 17:26:18 - Updating systems & servers data .... 2016.11.04 17:26:18 - Systems & servers data update completed. 2016.11.04 17:36:18 - Updating systems & servers data .... 2016.11.04 17:36:19 - Systems & servers data update completed. 2016.11.04 17:46:19 - Updating systems & servers data .... 2016.11.04 17:46:20 - Systems & servers data update completed. 2016.11.04 17:56:20 - Updating systems & servers data .... 2016.11.04 17:56:21 - Systems & servers data update completed. 2016.11.04 18:06:21 - Updating systems & servers data .... 2016.11.04 18:06:22 - Systems & servers data update completed. 2016.11.04 18:17:22 - Updating systems & servers data .... 2016.11.04 18:17:23 - Systems & servers data update completed. 2016.11.04 18:27:23 - Updating systems & servers data .... 2016.11.04 18:27:24 - Systems & servers data update completed. 2016.11.04 18:37:24 - Updating systems & servers data .... 2016.11.04 18:37:25 - Systems & servers data update completed. 2016.11.04 18:47:25 - Updating systems & servers data .... 2016.11.04 18:47:26 - Systems & servers data update completed. 2016.11.04 18:57:26 - Updating systems & servers data .... 2016.11.04 18:57:27 - Systems & servers data update completed. 2016.11.04 19:07:27 - Updating systems & servers data .... 2016.11.04 19:07:27 - Systems & servers data update completed. 2016.11.04 19:17:27 - Updating systems & servers data .... 2016.11.04 19:17:28 - Systems & servers data update completed. 2016.11.04 19:27:28 - Updating systems & servers data .... 2016.11.04 19:27:29 - Systems & servers data update completed. 2016.11.04 19:37:29 - Updating systems & servers data .... 2016.11.04 19:37:30 - Systems & servers data update completed. 2016.11.04 19:48:30 - Updating systems & servers data .... 2016.11.04 19:48:31 - Systems & servers data update completed. 2016.11.04 19:58:31 - Updating systems & servers data .... 2016.11.04 19:58:32 - Systems & servers data update completed. 2016.11.04 20:08:32 - Updating systems & servers data .... 2016.11.04 20:08:33 - Systems & servers data update completed. 2016.11.04 20:18:33 - Updating systems & servers data .... 2016.11.04 20:18:35 - Systems & servers data update completed. 2016.11.04 20:28:35 - Updating systems & servers data .... 2016.11.04 20:28:36 - Systems & servers data update completed. 2016.11.04 20:38:36 - Updating systems & servers data .... 2016.11.04 20:38:37 - Systems & servers data update completed. 2016.11.04 20:49:37 - Updating systems & servers data .... 2016.11.04 20:49:38 - Systems & servers data update completed. 2016.11.04 20:59:38 - Updating systems & servers data .... 2016.11.04 20:59:39 - Systems & servers data update completed. 2016.11.04 21:09:39 - Updating systems & servers data .... 2016.11.04 21:09:40 - Systems & servers data update completed. 2016.11.04 21:19:40 - Updating systems & servers data .... 2016.11.04 21:19:41 - Systems & servers data update completed. 2016.11.04 21:29:41 - Updating systems & servers data .... 2016.11.04 21:29:42 - Systems & servers data update completed. 2016.11.04 21:39:42 - Updating systems & servers data .... 2016.11.04 21:39:43 - Systems & servers data update completed. 2016.11.04 21:49:43 - Updating systems & servers data .... 2016.11.04 21:49:44 - Systems & servers data update completed. 2016.11.04 21:59:44 - Updating systems & servers data .... 2016.11.04 21:59:45 - Systems & servers data update completed. 2016.11.04 22:09:45 - Updating systems & servers data .... 2016.11.04 22:09:46 - Systems & servers data update completed. 2016.11.04 22:19:46 - Updating systems & servers data .... 2016.11.04 22:19:47 - Systems & servers data update completed. 2016.11.04 22:29:47 - Updating systems & servers data .... 2016.11.04 22:29:48 - Systems & servers data update completed. 2016.11.04 22:39:48 - Updating systems & servers data .... 2016.11.04 22:39:48 - Systems & servers data update completed. 2016.11.04 22:49:49 - Updating systems & servers data .... 2016.11.04 22:49:49 - Systems & servers data update completedI 2016.11.04 22:52:26 - Session starting.. 2016.11.04 22:52:26 - IPv6 disabled with packet filtering.I 2016.11.04 22:52:26 - Checking authorization ...! 2016.11.04 22:52:27 - Connecting to Gorgonea (Canada, Toronto, Ontario). 2016.11.04 22:52:27 - OpenVPN > OpenVPN 2.3.12 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Sep 5 2016. 2016.11.04 22:52:27 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.11.04 22:52:27 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.11.04 22:52:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.04 22:52:27 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.04 22:52:27 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:52:27 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:52:27 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.11.04 22:52:27 - OpenVPN > UDPv4 link local: [undef]. 2016.11.04 22:52:27 - OpenVPN > UDPv4 link remote: [AF_INET]104.254.90.250:443. 2016.11.04 22:52:27 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.250:443, sid=565a0fcc 6e983d9d. 2016.11.04 22:52:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.04 22:52:27 - OpenVPN > Validating certificate key usage. 2016.11.04 22:52:27 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.04 22:52:27 - OpenVPN > VERIFY KU OK. 2016.11.04 22:52:27 - OpenVPN > Validating certificate extended key usage. 2016.11.04 22:52:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.04 22:52:27 - OpenVPN > VERIFY EKU OK. 2016.11.04 22:52:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.04 22:52:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.04 22:52:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:52:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.04 22:52:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:52:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.04 22:52:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.250:443. 2016.11.04 22:52:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.04 22:52:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.78.175 255.255.0.0'. 2016.11.04 22:52:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.04 22:52:30 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.04 22:52:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.04 22:52:30 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.04 22:52:30 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.04 22:52:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.04 22:52:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=12 HWADDR=90:e6:ba:10:02:3e. 2016.11.04 22:52:30 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.04 22:52:30 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.04 22:52:30 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}.tap. 2016.11.04 22:52:30 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.04 22:52:30 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.78.175/255.255.0.0 [sUCCEEDED]. 2016.11.04 22:52:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.78.175/255.255.0.0 on interface {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.04 22:52:30 - OpenVPN > Successful ARP Flush on interface [39] {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}. 2016.11.04 22:52:35 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.04 22:52:35 - OpenVPN > C:\Windows\system32\route.exe ADD 104.254.90.250 MASK 255.255.255.255 192.168.1.1. 2016.11.04 22:52:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.04 22:52:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.04 22:52:35 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.04 22:52:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.04 22:52:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.04 22:52:35 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.04 22:52:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.04 22:52:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.04 22:52:35 - Starting Management Interface. 2016.11.04 22:52:35 - OpenVPN > Initialization Sequence Completed. 2016.11.04 22:52:35 - DNS leak protection with packet filtering enabled.. 2016.11.04 22:52:35 - DNS of a network adapter forced (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, from automatic (192.168.1.1) to 10.4.0.1). 2016.11.04 22:52:35 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)I 2016.11.04 22:52:35 - Flushing DNSI 2016.11.04 22:52:35 - Checking routeW 2016.11.04 22:53:25 - The operation has timed out! 2016.11.04 22:53:25 - Disconnecting. 2016.11.04 22:53:25 - Management - Send 'signal SIGTERM'. 2016.11.04 22:53:25 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.04 22:53:25 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.04 22:53:25 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.04 22:53:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 104.254.90.250 MASK 255.255.255.255 192.168.1.1. 2016.11.04 22:53:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.04 22:53:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.04 22:53:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.04 22:53:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.04 22:53:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.04 22:53:30 - OpenVPN > Closing TUN/TAP interface. 2016.11.04 22:53:30 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.04 22:53:30 - Connection terminated.. 2016.11.04 22:53:30 - DNS of a network adapter restored to original settings (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, to automatic). 2016.11.04 22:53:30 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2016.11.04 22:53:30 - DNS leak protection with packet filtering disabled.I 2016.11.04 22:53:33 - Checking authorization ...! 2016.11.04 22:53:33 - Connecting to Alwaid (Canada, Toronto, Ontario). 2016.11.04 22:53:33 - OpenVPN > OpenVPN 2.3.12 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Sep 5 2016. 2016.11.04 22:53:33 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.11.04 22:53:33 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.11.04 22:53:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.04 22:53:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.04 22:53:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:53:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:53:34 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.11.04 22:53:34 - OpenVPN > UDPv4 link local: [undef]. 2016.11.04 22:53:34 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.114:443. 2016.11.04 22:53:34 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.114:443, sid=8a95a32d f7dc4f54. 2016.11.04 22:53:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.04 22:53:36 - OpenVPN > Validating certificate key usage. 2016.11.04 22:53:36 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.04 22:53:36 - OpenVPN > VERIFY KU OK. 2016.11.04 22:53:36 - OpenVPN > Validating certificate extended key usage. 2016.11.04 22:53:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.04 22:53:36 - OpenVPN > VERIFY EKU OK. 2016.11.04 22:53:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.04 22:53:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.04 22:53:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:53:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.04 22:53:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.04 22:53:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.04 22:53:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.114:443. 2016.11.04 22:53:38 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.04 22:53:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.43.63 255.255.0.0'. 2016.11.04 22:53:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.04 22:53:38 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.04 22:53:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.04 22:53:38 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.04 22:53:38 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.04 22:53:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.04 22:53:38 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=12 HWADDR=90:e6:ba:10:02:3e. 2016.11.04 22:53:38 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.04 22:53:38 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.04 22:53:39 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}.tap. 2016.11.04 22:53:39 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.04 22:53:39 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.43.63/255.255.0.0 [sUCCEEDED]. 2016.11.04 22:53:39 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.43.63/255.255.0.0 on interface {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.04 22:53:39 - OpenVPN > Successful ARP Flush on interface [39] {CA5B56A3-0A1D-422B-BDC1-A700AA39F59B}. 2016.11.04 22:53:43 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.04 22:53:43 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.221.114 MASK 255.255.255.255 192.168.1.1. 2016.11.04 22:53:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.04 22:53:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.04 22:53:43 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.04 22:53:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.04 22:53:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.04 22:53:43 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.04 22:53:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.11.04 22:53:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.04 22:53:43 - Starting Management Interface. 2016.11.04 22:53:43 - OpenVPN > Initialization Sequence Completed. 2016.11.04 22:53:43 - DNS leak protection with packet filtering enabled.. 2016.11.04 22:53:43 - DNS of a network adapter forced (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2, from automatic (192.168.1.1) to 10.4.0.1). 2016.11.04 22:53:43 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)I 2016.11.04 22:53:43 - Flushing DNSI 2016.11.04 22:53:43 - Checking route" Quote Share this post Link to post
dead joe 0 Posted ... Hello, I've had the same problem for a couple of weeks now. I can't get past the "checking routes" stage, whatever server i try to connect to. Here is my log : I 2016.11.05 11:05:19 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.11.05 11:05:19 - Reading options from C:\Users\Christo\AppData\Local\AirVPN\AirVPN.xml. 2016.11.05 11:05:20 - Data Path: C:\Users\Christo\AppData\Local\AirVPN. 2016.11.05 11:05:20 - App Path: C:\Program Files\AirVPN. 2016.11.05 11:05:20 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.11.05 11:05:20 - Command line arguments (1): path="home". 2016.11.05 11:05:20 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.11.05 11:05:20 - Updating systems & servers data .... 2016.11.05 11:05:20 - Systems & servers data update completedI 2016.11.05 11:05:21 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1I 2016.11.05 11:05:21 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.11.05 11:05:21 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.11.05 11:05:21 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2016.11.05 11:05:21 - ReadyI 2016.11.05 11:05:27 - Session starting.I 2016.11.05 11:05:27 - IPv6 disabled.I 2016.11.05 11:05:27 - Checking authorization ...F 2016.11.05 11:05:27 - Wrong login/password.I 2016.11.05 11:05:27 - Cancel requested.I 2016.11.05 11:05:29 - IPv6 restored.! 2016.11.05 11:05:29 - Session terminated.! 2016.11.05 11:05:37 - Logged out.I 2016.11.05 11:05:47 - Checking login ...! 2016.11.05 11:05:47 - Logged in.I 2016.11.05 11:05:49 - Session starting.I 2016.11.05 11:05:49 - IPv6 disabled.I 2016.11.05 11:05:49 - Checking authorization ...! 2016.11.05 11:05:50 - Connecting to Matar (Netherlands, Alblasserdam). 2016.11.05 11:05:50 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.11.05 11:05:50 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.11.05 11:05:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.05 11:05:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.05 11:05:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:05:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:05:50 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.11.05 11:05:50 - OpenVPN > UDPv4 link local: [undef]. 2016.11.05 11:05:50 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.137:443. 2016.11.05 11:05:50 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.137:443, sid=c1bf10c1 a2c75170. 2016.11.05 11:05:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.05 11:05:50 - OpenVPN > Validating certificate key usage. 2016.11.05 11:05:50 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.05 11:05:50 - OpenVPN > VERIFY KU OK. 2016.11.05 11:05:50 - OpenVPN > Validating certificate extended key usage. 2016.11.05 11:05:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.05 11:05:50 - OpenVPN > VERIFY EKU OK. 2016.11.05 11:05:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.05 11:05:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:05:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:05:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:05:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:05:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.05 11:05:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.137:443. 2016.11.05 11:05:55 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.05 11:05:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.83.246 255.255.0.0'. 2016.11.05 11:05:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.05 11:05:55 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.05 11:05:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.05 11:05:55 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.05 11:05:55 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.05 11:05:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.05 11:05:55 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.05 11:05:55 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.05 11:05:55 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{2C25233A-913B-40F5-AFB4-6A0A748EA34A}.tap. 2016.11.05 11:05:55 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.05 11:05:55 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.83.246/255.255.0.0 [sUCCEEDED]. 2016.11.05 11:05:55 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.83.246/255.255.0.0 on interface {2C25233A-913B-40F5-AFB4-6A0A748EA34A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.05 11:05:55 - OpenVPN > Successful ARP Flush on interface [4] {2C25233A-913B-40F5-AFB4-6A0A748EA34A}. 2016.11.05 11:06:00 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.05 11:06:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.232.227.137 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:06:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:06:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:06:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 10. 2016.11.05 11:06:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:06:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:06:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:06:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:06:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:06:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:06:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:06:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:06:00 - Starting Management Interface. 2016.11.05 11:06:00 - OpenVPN > Initialization Sequence CompletedI 2016.11.05 11:06:00 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.11.05 11:06:00 - DNS of a network adapter forced (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:06:01 - Flushing DNSI 2016.11.05 11:06:01 - Checking routeW 2016.11.05 11:07:01 - Le délai d'attente de l'opération a expiré.! 2016.11.05 11:07:01 - Disconnecting. 2016.11.05 11:07:01 - Management - Send 'signal SIGTERM'. 2016.11.05 11:07:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.05 11:07:01 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.05 11:07:01 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.05 11:07:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.232.227.137 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:07:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:07:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:07:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:07:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:07:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:07:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:07:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:07:06 - OpenVPN > Closing TUN/TAP interface. 2016.11.05 11:07:06 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.05 11:07:06 - Connection terminated.I 2016.11.05 11:07:07 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.11.05 11:07:07 - DNS of a network adapter restored to original settings (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:07:10 - Checking authorization ...! 2016.11.05 11:07:10 - Connecting to Virginis (Switzerland, Bern). 2016.11.05 11:07:10 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.11.05 11:07:10 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.11.05 11:07:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.05 11:07:10 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.05 11:07:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:07:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:07:10 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.11.05 11:07:10 - OpenVPN > UDPv4 link local: [undef]. 2016.11.05 11:07:10 - OpenVPN > UDPv4 link remote: [AF_INET]46.19.137.114:443. 2016.11.05 11:07:10 - OpenVPN > TLS: Initial packet from [AF_INET]46.19.137.114:443, sid=47c4c811 a940922d. 2016.11.05 11:07:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.05 11:07:10 - OpenVPN > Validating certificate key usage. 2016.11.05 11:07:10 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.05 11:07:10 - OpenVPN > VERIFY KU OK. 2016.11.05 11:07:10 - OpenVPN > Validating certificate extended key usage. 2016.11.05 11:07:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.05 11:07:10 - OpenVPN > VERIFY EKU OK. 2016.11.05 11:07:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.05 11:07:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:07:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:07:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:07:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:07:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.05 11:07:11 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.19.137.114:443. 2016.11.05 11:07:13 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.05 11:07:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.36.41 255.255.0.0'. 2016.11.05 11:07:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.05 11:07:13 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.05 11:07:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.05 11:07:13 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.05 11:07:13 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.05 11:07:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.05 11:07:13 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.05 11:07:13 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.05 11:07:13 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{2C25233A-913B-40F5-AFB4-6A0A748EA34A}.tap. 2016.11.05 11:07:13 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.05 11:07:13 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.36.41/255.255.0.0 [sUCCEEDED]. 2016.11.05 11:07:13 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.36.41/255.255.0.0 on interface {2C25233A-913B-40F5-AFB4-6A0A748EA34A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.05 11:07:13 - OpenVPN > Successful ARP Flush on interface [4] {2C25233A-913B-40F5-AFB4-6A0A748EA34A}. 2016.11.05 11:07:18 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.05 11:07:18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.19.137.114 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:07:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:07:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:07:18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 10. 2016.11.05 11:07:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:07:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:07:18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:07:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:07:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:07:18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:07:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:07:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:07:18 - Starting Management Interface. 2016.11.05 11:07:18 - OpenVPN > Initialization Sequence CompletedI 2016.11.05 11:07:18 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.11.05 11:07:18 - DNS of a network adapter forced (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:07:18 - Flushing DNSI 2016.11.05 11:07:18 - Checking routeW 2016.11.05 11:08:18 - Le délai d'attente de l'opération a expiré.! 2016.11.05 11:08:19 - Disconnecting. 2016.11.05 11:08:19 - Management - Send 'signal SIGTERM'. 2016.11.05 11:08:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.05 11:08:19 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.05 11:08:19 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.05 11:08:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.19.137.114 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:08:24 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:08:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:08:24 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:08:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:08:24 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:08:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:08:24 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:08:24 - OpenVPN > Closing TUN/TAP interface. 2016.11.05 11:08:24 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.05 11:08:24 - Connection terminated.I 2016.11.05 11:08:25 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.11.05 11:08:25 - DNS of a network adapter restored to original settings (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:08:25 - Cancel requested.I 2016.11.05 11:08:25 - IPv6 restored.! 2016.11.05 11:08:25 - Session terminated.I 2016.11.05 11:14:05 - Session starting.I 2016.11.05 11:14:05 - IPv6 disabled.I 2016.11.05 11:14:05 - Checking authorization ...! 2016.11.05 11:14:05 - Connecting to Virginis (Switzerland, Bern). 2016.11.05 11:14:05 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.11.05 11:14:05 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.11.05 11:14:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.05 11:14:06 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.05 11:14:06 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:14:06 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:14:06 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.11.05 11:14:06 - OpenVPN > UDPv4 link local: [undef]. 2016.11.05 11:14:06 - OpenVPN > UDPv4 link remote: [AF_INET]46.19.137.114:443. 2016.11.05 11:14:06 - OpenVPN > TLS: Initial packet from [AF_INET]46.19.137.114:443, sid=2b4ef63c fa4bacc0. 2016.11.05 11:14:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.05 11:14:06 - OpenVPN > Validating certificate key usage. 2016.11.05 11:14:06 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.05 11:14:06 - OpenVPN > VERIFY KU OK. 2016.11.05 11:14:06 - OpenVPN > Validating certificate extended key usage. 2016.11.05 11:14:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.05 11:14:06 - OpenVPN > VERIFY EKU OK. 2016.11.05 11:14:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.05 11:14:06 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:14:06 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:14:06 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:14:06 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:14:06 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.05 11:14:06 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.19.137.114:443. 2016.11.05 11:14:08 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.05 11:14:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.36.41 255.255.0.0'. 2016.11.05 11:14:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.05 11:14:08 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.05 11:14:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.05 11:14:08 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.05 11:14:08 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.05 11:14:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.05 11:14:08 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.05 11:14:08 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.05 11:14:09 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{2C25233A-913B-40F5-AFB4-6A0A748EA34A}.tap. 2016.11.05 11:14:09 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.05 11:14:09 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.36.41/255.255.0.0 [sUCCEEDED]. 2016.11.05 11:14:09 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.36.41/255.255.0.0 on interface {2C25233A-913B-40F5-AFB4-6A0A748EA34A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.05 11:14:09 - OpenVPN > Successful ARP Flush on interface [4] {2C25233A-913B-40F5-AFB4-6A0A748EA34A}. 2016.11.05 11:14:13 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.05 11:14:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.19.137.114 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:14:13 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:14:13 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:14:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 10. 2016.11.05 11:14:13 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:14:13 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:14:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:14:13 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:14:13 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:14:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:14:13 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:14:13 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:14:13 - Starting Management Interface. 2016.11.05 11:14:13 - OpenVPN > Initialization Sequence CompletedI 2016.11.05 11:14:13 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.11.05 11:14:13 - DNS of a network adapter forced (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:14:13 - Flushing DNSI 2016.11.05 11:14:13 - Checking routeW 2016.11.05 11:15:13 - Le délai d'attente de l'opération a expiré.! 2016.11.05 11:15:13 - Disconnecting. 2016.11.05 11:15:13 - Management - Send 'signal SIGTERM'. 2016.11.05 11:15:13 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.05 11:15:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.05 11:15:13 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.05 11:15:18 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.19.137.114 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:15:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:15:18 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:15:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:15:18 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:15:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:15:18 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:15:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:15:18 - OpenVPN > Closing TUN/TAP interface. 2016.11.05 11:15:18 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.05 11:15:19 - Connection terminated.I 2016.11.05 11:15:19 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.11.05 11:15:19 - DNS of a network adapter restored to original settings (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:15:22 - Checking authorization ...! 2016.11.05 11:15:22 - Connecting to Kocab (Netherlands, Alblasserdam). 2016.11.05 11:15:22 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.11.05 11:15:22 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.11.05 11:15:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.11.05 11:15:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.11.05 11:15:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:15:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:15:22 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.11.05 11:15:22 - OpenVPN > UDPv4 link local: [undef]. 2016.11.05 11:15:22 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.180:443. 2016.11.05 11:15:22 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.180:443, sid=0f11c31e d79e7491. 2016.11.05 11:15:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.11.05 11:15:22 - OpenVPN > Validating certificate key usage. 2016.11.05 11:15:22 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.11.05 11:15:22 - OpenVPN > VERIFY KU OK. 2016.11.05 11:15:22 - OpenVPN > Validating certificate extended key usage. 2016.11.05 11:15:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.11.05 11:15:22 - OpenVPN > VERIFY EKU OK. 2016.11.05 11:15:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.11.05 11:15:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:15:28 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:15:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.11.05 11:15:28 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.11.05 11:15:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.11.05 11:15:28 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.180:443. 2016.11.05 11:15:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.11.05 11:15:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.71.151 255.255.0.0'. 2016.11.05 11:15:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.11.05 11:15:31 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.11.05 11:15:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.11.05 11:15:31 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.11.05 11:15:31 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.11.05 11:15:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.11.05 11:15:31 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.11.05 11:15:31 - OpenVPN > open_tun, tt->ipv6=0. 2016.11.05 11:15:31 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{2C25233A-913B-40F5-AFB4-6A0A748EA34A}.tap. 2016.11.05 11:15:31 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.11.05 11:15:31 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.71.151/255.255.0.0 [sUCCEEDED]. 2016.11.05 11:15:31 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.71.151/255.255.0.0 on interface {2C25233A-913B-40F5-AFB4-6A0A748EA34A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.11.05 11:15:31 - OpenVPN > Successful ARP Flush on interface [4] {2C25233A-913B-40F5-AFB4-6A0A748EA34A}. 2016.11.05 11:15:36 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.11.05 11:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:15:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:15:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 10. 2016.11.05 11:15:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4. 2016.11.05 11:15:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:15:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:15:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:15:36 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:15:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2016.11.05 11:15:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.11.05 11:15:36 - Starting Management Interface. 2016.11.05 11:15:36 - OpenVPN > Initialization Sequence CompletedI 2016.11.05 11:15:36 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.11.05 11:15:36 - DNS of a network adapter forced (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:15:36 - Flushing DNSI 2016.11.05 11:15:37 - Checking routeW 2016.11.05 11:16:37 - Le délai d'attente de l'opération a expiré.! 2016.11.05 11:16:37 - Disconnecting. 2016.11.05 11:16:37 - Management - Send 'signal SIGTERM'. 2016.11.05 11:16:37 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.11.05 11:16:37 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.11.05 11:16:37 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.11.05 11:16:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.180 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:16:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:16:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1. 2016.11.05 11:16:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:16:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:16:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:16:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.11.05 11:16:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.11.05 11:16:42 - OpenVPN > Closing TUN/TAP interface. 2016.11.05 11:16:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.11.05 11:16:43 - Connection terminated.I 2016.11.05 11:16:43 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.11.05 11:16:43 - DNS of a network adapter restored to original settings (Carte réseau sans fil Qualcomm Atheros AR9485WB-EG)I 2016.11.05 11:16:46 - Cancel requested.I 2016.11.05 11:16:46 - IPv6 restored.! 2016.11.05 11:16:46 - Session terminated. Quote Share this post Link to post
t-petja 0 Posted ... Mac OS X (10.10.5)Checking route for a long time, then disconnect, then restart Connect, again and again. I have this same problem. It's new, the AirVPN client used to work (for the few times i've been using it) just fine before. Reboot helps not. Also, there's no recent changes to system (that I know of — and I should). I 2016.12.06 14:47:19 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.10.5 / x64. 2016.12.06 14:47:19 - Reading options from /Users/XXXXXX/.airvpn/AirVPN.xml. 2016.12.06 14:47:19 - Data Path: /Users/XXXXXX/.airvpn. 2016.12.06 14:47:19 - App Path: /Applications/AirVPN.app/Contents/MacOS. 2016.12.06 14:47:19 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN. 2016.12.06 14:47:19 - Command line arguments (0):. 2016.12.06 14:47:19 - Updating systems & servers data .... 2016.12.06 14:47:19 - Operating System: Unix 14.5.0.0 - Darwin u-mac.local 14.5.0 Darwin Kernel Version 14.5.0: Sun Sep 25 22:07:15 PDT 2016; root:xnu-2782.50.9~1/RELEASE_X86_64 x86_64I 2016.12.06 14:47:19 - OpenVPN Driver - ExpectedI 2016.12.06 14:47:19 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)I 2016.12.06 14:47:19 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)I 2016.12.06 14:47:19 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)! 2016.12.06 14:47:19 - Ready. 2016.12.06 14:47:20 - Systems & servers data update completedI 2016.12.06 14:47:34 - Session starting.I 2016.12.06 14:47:34 - IPv6 disabled on network adapter (Bluetooth PAN)I 2016.12.06 14:47:34 - IPv6 disabled on network adapter (Nokia 6120 classic)I 2016.12.06 14:47:34 - IPv6 disabled on network adapter (Bluetooth DUN)I 2016.12.06 14:47:34 - IPv6 disabled on network adapter (Wi-Fi)I 2016.12.06 14:47:35 - IPv6 disabled on network adapter (*FireWire)I 2016.12.06 14:47:35 - IPv6 disabled on network adapter (iPad)I 2016.12.06 14:47:35 - IPv6 disabled on network adapter (Ethernet)I 2016.12.06 14:47:35 - Checking authorization ...! 2016.12.06 14:47:35 - Connecting to Altarf (Sweden, Uppsala). 2016.12.06 14:47:35 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 14:47:35 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 14:47:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.06 14:47:35 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 14:47:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:47:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:47:35 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 14:47:35 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 14:47:35 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.140:443. 2016.12.06 14:47:35 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.140:443, sid=50032125 410a6378. 2016.12.06 14:47:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 14:47:35 - OpenVPN > Validating certificate key usage. 2016.12.06 14:47:35 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 14:47:35 - OpenVPN > VERIFY KU OK. 2016.12.06 14:47:35 - OpenVPN > Validating certificate extended key usage. 2016.12.06 14:47:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 14:47:35 - OpenVPN > VERIFY EKU OK. 2016.12.06 14:47:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 14:47:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:47:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:47:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:47:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:47:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 14:47:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.140:443. 2016.12.06 14:47:38 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 14:47:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.157 255.255.0.0'. 2016.12.06 14:47:38 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 14:47:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 14:47:38 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 14:47:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 14:47:38 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 14:47:38 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 14:47:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 14:47:38 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 14:47:38 - OpenVPN > Opened utun device utun1. 2016.12.06 14:47:38 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 14:47:38 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 14:47:38 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 14:47:38 - OpenVPN > /sbin/ifconfig utun1 10.4.34.157 10.4.34.157 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 14:47:38 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.34.157 255.255.0.0. 2016.12.06 14:47:38 - OpenVPN > add net 10.4.0.0: gateway 10.4.34.157. 2016.12.06 14:47:38 - OpenVPN > /sbin/route add -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:47:38 - OpenVPN > add net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:47:39 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:47:39 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:47:39 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:47:39 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:47:39 - Starting Management Interface. 2016.12.06 14:47:39 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 14:47:39 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 14:47:39 - DNS of a network adapter forced (Nokia 6120 classic)I 2016.12.06 14:47:39 - DNS of a network adapter forced (Bluetooth DUN)I 2016.12.06 14:47:40 - DNS of a network adapter forced (Wi-Fi). 2016.12.06 14:47:40 - Unknown networksetup output: '*FireWire is not a recognized network service.;** Error: The parameters were not valid.' for interface '*FireWire'I 2016.12.06 14:47:40 - DNS of a network adapter forced (iPad)I 2016.12.06 14:47:40 - DNS of a network adapter forced (Ethernet)I 2016.12.06 14:47:40 - Flushing DNSI 2016.12.06 14:47:40 - Checking routeW 2016.12.06 14:48:32 - The request timed out! 2016.12.06 14:48:32 - Disconnecting. 2016.12.06 14:48:32 - Management - Send 'signal SIGTERM'. 2016.12.06 14:48:32 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.06 14:48:32 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 14:48:32 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.06 14:48:37 - OpenVPN > /sbin/route delete -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:48:37 - OpenVPN > delete net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:48:37 - Connection terminated.I 2016.12.06 14:48:37 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2016.12.06 14:48:37 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:48:37 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1I 2016.12.06 14:48:37 - DNS of a network adapter restored to original settings (Nokia 6120 classic). 2016.12.06 14:48:37 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0I 2016.12.06 14:48:37 - DNS of a network adapter restored to original settings (Bluetooth DUN). 2016.12.06 14:48:37 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:48:37 - OpenVPN > Closing TUN/TAP interfaceI 2016.12.06 14:48:37 - DNS of a network adapter restored to original settings (Wi-Fi). 2016.12.06 14:48:37 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2016.12.06 14:48:37 - DNS of a network adapter restored to original settings (iPad)I 2016.12.06 14:48:37 - DNS of a network adapter restored to original settings (Ethernet)I 2016.12.06 14:48:40 - Checking authorization ...! 2016.12.06 14:48:41 - Connecting to Altarf (Sweden, Uppsala). 2016.12.06 14:48:41 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 14:48:41 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 14:48:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.06 14:48:41 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 14:48:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:48:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:48:41 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 14:48:41 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 14:48:41 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.140:443. 2016.12.06 14:48:41 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.140:443, sid=8624e382 6b85328d. 2016.12.06 14:48:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 14:48:41 - OpenVPN > Validating certificate key usage. 2016.12.06 14:48:41 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 14:48:41 - OpenVPN > VERIFY KU OK. 2016.12.06 14:48:41 - OpenVPN > Validating certificate extended key usage. 2016.12.06 14:48:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 14:48:41 - OpenVPN > VERIFY EKU OK. 2016.12.06 14:48:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 14:48:44 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:48:44 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:48:44 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:48:44 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:48:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 14:48:44 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.140:443. 2016.12.06 14:48:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 14:48:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.157 255.255.0.0'. 2016.12.06 14:48:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 14:48:46 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 14:48:46 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 14:48:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 14:48:46 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 14:48:46 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 14:48:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 14:48:46 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 14:48:46 - OpenVPN > Opened utun device utun1. 2016.12.06 14:48:46 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 14:48:46 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 14:48:46 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 14:48:46 - OpenVPN > /sbin/ifconfig utun1 10.4.34.157 10.4.34.157 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 14:48:46 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.34.157 255.255.0.0. 2016.12.06 14:48:46 - OpenVPN > add net 10.4.0.0: gateway 10.4.34.157. 2016.12.06 14:48:46 - OpenVPN > /sbin/route add -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:48:46 - OpenVPN > add net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:48:46 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:48:46 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:48:46 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:48:46 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:48:47 - Starting Management Interface. 2016.12.06 14:48:47 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 14:48:47 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 14:48:47 - DNS of a network adapter forced (Nokia 6120 classic)I 2016.12.06 14:48:47 - DNS of a network adapter forced (Bluetooth DUN)I 2016.12.06 14:48:47 - DNS of a network adapter forced (Wi-Fi). 2016.12.06 14:48:47 - Unknown networksetup output: '*FireWire is not a recognized network service.;** Error: The parameters were not valid.' for interface '*FireWire'I 2016.12.06 14:48:47 - DNS of a network adapter forced (iPad)I 2016.12.06 14:48:47 - DNS of a network adapter forced (Ethernet)I 2016.12.06 14:48:47 - Flushing DNSI 2016.12.06 14:48:47 - Checking routeW 2016.12.06 14:49:38 - The request timed out! 2016.12.06 14:49:38 - Disconnecting. 2016.12.06 14:49:38 - Management - Send 'signal SIGTERM'. 2016.12.06 14:49:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 14:49:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.06 14:49:38 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.06 14:49:43 - OpenVPN > /sbin/route delete -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:49:43 - OpenVPN > delete net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:49:43 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:49:43 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:49:43 - Connection terminated.I 2016.12.06 14:49:43 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2016.12.06 14:49:43 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:49:43 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:49:43 - OpenVPN > Closing TUN/TAP interfaceI 2016.12.06 14:49:43 - DNS of a network adapter restored to original settings (Nokia 6120 classic). 2016.12.06 14:49:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2016.12.06 14:49:43 - DNS of a network adapter restored to original settings (Bluetooth DUN)I 2016.12.06 14:49:43 - DNS of a network adapter restored to original settings (Wi-Fi)I 2016.12.06 14:49:43 - DNS of a network adapter restored to original settings (iPad)I 2016.12.06 14:49:43 - DNS of a network adapter restored to original settings (Ethernet)I 2016.12.06 14:49:46 - Checking authorization ...! 2016.12.06 14:49:46 - Connecting to Altarf (Sweden, Uppsala). 2016.12.06 14:49:46 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 14:49:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 14:49:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.06 14:49:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 14:49:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:49:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:49:47 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 14:49:47 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 14:49:47 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.140:443. 2016.12.06 14:49:47 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.140:443, sid=7603f044 14847056. 2016.12.06 14:49:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 14:49:47 - OpenVPN > Validating certificate key usage. 2016.12.06 14:49:47 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 14:49:47 - OpenVPN > VERIFY KU OK. 2016.12.06 14:49:47 - OpenVPN > Validating certificate extended key usage. 2016.12.06 14:49:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 14:49:47 - OpenVPN > VERIFY EKU OK. 2016.12.06 14:49:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 14:49:51 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:49:51 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:49:51 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:49:51 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:49:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 14:49:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.140:443. 2016.12.06 14:49:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 14:49:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.157 255.255.0.0'. 2016.12.06 14:49:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 14:49:53 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 14:49:53 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 14:49:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 14:49:53 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 14:49:53 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 14:49:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 14:49:53 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 14:49:53 - OpenVPN > Opened utun device utun1. 2016.12.06 14:49:53 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 14:49:53 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 14:49:53 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 14:49:53 - OpenVPN > /sbin/ifconfig utun1 10.4.34.157 10.4.34.157 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 14:49:53 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.34.157 255.255.0.0. 2016.12.06 14:49:53 - OpenVPN > add net 10.4.0.0: gateway 10.4.34.157. 2016.12.06 14:49:53 - OpenVPN > /sbin/route add -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:49:53 - OpenVPN > add net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:49:53 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:49:53 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:49:53 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:49:53 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:49:53 - Starting Management Interface. 2016.12.06 14:49:53 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 14:49:53 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 14:49:53 - DNS of a network adapter forced (Nokia 6120 classic)I 2016.12.06 14:49:54 - DNS of a network adapter forced (Bluetooth DUN)I 2016.12.06 14:49:54 - DNS of a network adapter forced (Wi-Fi). 2016.12.06 14:49:54 - Unknown networksetup output: '*FireWire is not a recognized network service.;** Error: The parameters were not valid.' for interface '*FireWire'I 2016.12.06 14:49:54 - DNS of a network adapter forced (iPad)I 2016.12.06 14:49:54 - DNS of a network adapter forced (Ethernet)I 2016.12.06 14:49:54 - Flushing DNSI 2016.12.06 14:49:54 - Checking routeW 2016.12.06 14:50:44 - The request timed out! 2016.12.06 14:50:44 - Disconnecting. 2016.12.06 14:50:44 - Management - Send 'signal SIGTERM'. 2016.12.06 14:50:45 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 14:50:45 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.06 14:50:45 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.06 14:50:51 - OpenVPN > /sbin/route delete -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:50:51 - OpenVPN > delete net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:50:51 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:50:51 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:50:51 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:50:51 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:50:51 - OpenVPN > Closing TUN/TAP interface. 2016.12.06 14:50:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.06 14:50:51 - Connection terminated.I 2016.12.06 14:50:51 - DNS of a network adapter restored to original settings (Bluetooth PAN)I 2016.12.06 14:50:51 - DNS of a network adapter restored to original settings (Nokia 6120 classic)I 2016.12.06 14:50:51 - DNS of a network adapter restored to original settings (Bluetooth DUN)I 2016.12.06 14:50:51 - DNS of a network adapter restored to original settings (Wi-Fi)I 2016.12.06 14:50:51 - DNS of a network adapter restored to original settings (iPad)I 2016.12.06 14:50:51 - DNS of a network adapter restored to original settings (Ethernet)I 2016.12.06 14:50:54 - Checking authorization ...! 2016.12.06 14:50:54 - Connecting to Altarf (Sweden, Uppsala). 2016.12.06 14:50:54 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 14:50:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 14:50:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.06 14:50:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 14:50:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:50:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:50:55 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 14:50:55 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 14:50:55 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.140:443. 2016.12.06 14:50:55 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.140:443, sid=10af5232 95563068. 2016.12.06 14:50:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 14:50:55 - OpenVPN > Validating certificate key usage. 2016.12.06 14:50:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 14:50:55 - OpenVPN > VERIFY KU OK. 2016.12.06 14:50:55 - OpenVPN > Validating certificate extended key usage. 2016.12.06 14:50:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 14:50:55 - OpenVPN > VERIFY EKU OK. 2016.12.06 14:50:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 14:50:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:50:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:50:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:50:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:50:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 14:50:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.140:443. 2016.12.06 14:51:01 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 14:51:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.157 255.255.0.0'. 2016.12.06 14:51:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 14:51:03 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 14:51:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 14:51:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 14:51:03 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 14:51:03 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 14:51:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 14:51:03 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 14:51:03 - OpenVPN > Opened utun device utun1. 2016.12.06 14:51:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 14:51:03 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 14:51:03 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 14:51:03 - OpenVPN > /sbin/ifconfig utun1 10.4.34.157 10.4.34.157 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 14:51:03 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.34.157 255.255.0.0. 2016.12.06 14:51:03 - OpenVPN > add net 10.4.0.0: gateway 10.4.34.157. 2016.12.06 14:51:03 - OpenVPN > /sbin/route add -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:51:03 - OpenVPN > add net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:51:03 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:51:03 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:51:03 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:51:03 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:51:03 - Starting Management Interface. 2016.12.06 14:51:03 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 14:51:03 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 14:51:03 - DNS of a network adapter forced (Nokia 6120 classic)I 2016.12.06 14:51:03 - DNS of a network adapter forced (Bluetooth DUN)I 2016.12.06 14:51:04 - DNS of a network adapter forced (Wi-Fi). 2016.12.06 14:51:04 - Unknown networksetup output: '*FireWire is not a recognized network service.;** Error: The parameters were not valid.' for interface '*FireWire'I 2016.12.06 14:51:04 - DNS of a network adapter forced (iPad)I 2016.12.06 14:51:04 - DNS of a network adapter forced (Ethernet)I 2016.12.06 14:51:04 - Flushing DNSI 2016.12.06 14:51:04 - Checking routeW 2016.12.06 14:51:54 - The request timed out! 2016.12.06 14:51:54 - Disconnecting. 2016.12.06 14:51:54 - Management - Send 'signal SIGTERM'. 2016.12.06 14:51:54 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 14:51:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.06 14:51:54 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.06 14:51:59 - OpenVPN > /sbin/route delete -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:51:59 - OpenVPN > delete net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:51:59 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:51:59 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:51:59 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:51:59 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:51:59 - OpenVPN > Closing TUN/TAP interface. 2016.12.06 14:51:59 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.06 14:52:00 - Connection terminated.I 2016.12.06 14:52:00 - DNS of a network adapter restored to original settings (Bluetooth PAN)I 2016.12.06 14:52:00 - DNS of a network adapter restored to original settings (Nokia 6120 classic)I 2016.12.06 14:52:00 - DNS of a network adapter restored to original settings (Bluetooth DUN)I 2016.12.06 14:52:00 - DNS of a network adapter restored to original settings (Wi-Fi)I 2016.12.06 14:52:00 - DNS of a network adapter restored to original settings (iPad)I 2016.12.06 14:52:00 - DNS of a network adapter restored to original settings (Ethernet)I 2016.12.06 14:52:02 - Cancel requested.I 2016.12.06 14:52:02 - IPv6 restored on network adapter (Bluetooth PAN)I 2016.12.06 14:52:02 - IPv6 restored on network adapter (Nokia 6120 classic)I 2016.12.06 14:52:02 - IPv6 restored on network adapter (Bluetooth DUN)I 2016.12.06 14:52:02 - IPv6 restored on network adapter (Wi-Fi)I 2016.12.06 14:52:02 - IPv6 restored on network adapter (*FireWire)I 2016.12.06 14:52:02 - IPv6 restored on network adapter (iPad)I 2016.12.06 14:52:02 - IPv6 restored on network adapter (Ethernet)! 2016.12.06 14:52:02 - Session terminated.I 2016.12.06 14:57:13 - Session starting.I 2016.12.06 14:57:13 - IPv6 disabled on network adapter (Bluetooth PAN)I 2016.12.06 14:57:13 - IPv6 disabled on network adapter (Nokia 6120 classic)I 2016.12.06 14:57:13 - IPv6 disabled on network adapter (Bluetooth DUN)I 2016.12.06 14:57:13 - IPv6 disabled on network adapter (Wi-Fi)I 2016.12.06 14:57:13 - IPv6 disabled on network adapter (*FireWire)I 2016.12.06 14:57:13 - IPv6 disabled on network adapter (iPad)I 2016.12.06 14:57:14 - IPv6 disabled on network adapter (Ethernet)I 2016.12.06 14:57:14 - Checking authorization ...! 2016.12.06 14:57:14 - Connecting to Asellus (Netherlands, Alblasserdam). 2016.12.06 14:57:14 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 14:57:14 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 14:57:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.06 14:57:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 14:57:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:57:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:57:14 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 14:57:14 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 14:57:14 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.19:443. 2016.12.06 14:57:14 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.19:443, sid=c0861280 5351a54e. 2016.12.06 14:57:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 14:57:14 - OpenVPN > Validating certificate key usage. 2016.12.06 14:57:14 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 14:57:14 - OpenVPN > VERIFY KU OK. 2016.12.06 14:57:14 - OpenVPN > Validating certificate extended key usage. 2016.12.06 14:57:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 14:57:14 - OpenVPN > VERIFY EKU OK. 2016.12.06 14:57:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 14:57:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:57:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:57:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:57:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:57:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 14:57:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.19:443. 2016.12.06 14:57:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 14:57:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.88 255.255.0.0'. 2016.12.06 14:57:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 14:57:21 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 14:57:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 14:57:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 14:57:21 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 14:57:21 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 14:57:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 14:57:21 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 14:57:21 - OpenVPN > Opened utun device utun1. 2016.12.06 14:57:21 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 14:57:21 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 14:57:22 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 14:57:22 - OpenVPN > /sbin/ifconfig utun1 10.4.53.88 10.4.53.88 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 14:57:22 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.88 255.255.0.0. 2016.12.06 14:57:22 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.88. 2016.12.06 14:57:22 - OpenVPN > /sbin/route add -net 109.202.107.19 192.168.1.1 255.255.255.255. 2016.12.06 14:57:22 - OpenVPN > add net 109.202.107.19: gateway 192.168.1.1. 2016.12.06 14:57:22 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:57:22 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:57:22 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:57:22 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:57:22 - Starting Management Interface. 2016.12.06 14:57:22 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 14:57:22 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 14:57:22 - DNS of a network adapter forced (Nokia 6120 classic)I 2016.12.06 14:57:22 - DNS of a network adapter forced (Bluetooth DUN)I 2016.12.06 14:57:22 - DNS of a network adapter forced (Wi-Fi). 2016.12.06 14:57:22 - Unknown networksetup output: '*FireWire is not a recognized network service.;** Error: The parameters were not valid.' for interface '*FireWire'I 2016.12.06 14:57:22 - DNS of a network adapter forced (iPad)I 2016.12.06 14:57:23 - DNS of a network adapter forced (Ethernet)I 2016.12.06 14:57:23 - Flushing DNSI 2016.12.06 14:57:23 - Checking routeW 2016.12.06 14:58:13 - The request timed out! 2016.12.06 14:58:13 - Disconnecting. 2016.12.06 14:58:13 - Management - Send 'signal SIGTERM'. 2016.12.06 14:58:13 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 14:58:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.06 14:58:13 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.06 14:58:18 - OpenVPN > /sbin/route delete -net 109.202.107.19 192.168.1.1 255.255.255.255. 2016.12.06 14:58:18 - OpenVPN > delete net 109.202.107.19: gateway 192.168.1.1. 2016.12.06 14:58:18 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:58:18 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:58:18 - Connection terminated.. 2016.12.06 14:58:18 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0I 2016.12.06 14:58:18 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2016.12.06 14:58:18 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:58:18 - OpenVPN > Closing TUN/TAP interface. 2016.12.06 14:58:18 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2016.12.06 14:58:18 - DNS of a network adapter restored to original settings (Nokia 6120 classic)I 2016.12.06 14:58:18 - DNS of a network adapter restored to original settings (Bluetooth DUN)I 2016.12.06 14:58:18 - DNS of a network adapter restored to original settings (Wi-Fi)I 2016.12.06 14:58:18 - DNS of a network adapter restored to original settings (iPad)I 2016.12.06 14:58:19 - DNS of a network adapter restored to original settings (Ethernet)I 2016.12.06 14:58:22 - Checking authorization ...! 2016.12.06 14:58:22 - Connecting to Altarf (Sweden, Uppsala). 2016.12.06 14:58:22 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 14:58:22 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 14:58:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.06 14:58:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 14:58:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:58:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:58:22 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 14:58:22 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 14:58:22 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.140:443. 2016.12.06 14:58:22 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.140:443, sid=c1a563db 836e0370. 2016.12.06 14:58:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 14:58:22 - OpenVPN > Validating certificate key usage. 2016.12.06 14:58:22 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 14:58:22 - OpenVPN > VERIFY KU OK. 2016.12.06 14:58:22 - OpenVPN > Validating certificate extended key usage. 2016.12.06 14:58:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 14:58:22 - OpenVPN > VERIFY EKU OK. 2016.12.06 14:58:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 14:58:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:58:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:58:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:58:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:58:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 14:58:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.140:443. 2016.12.06 14:58:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 14:58:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.157 255.255.0.0'. 2016.12.06 14:58:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 14:58:25 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 14:58:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 14:58:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 14:58:25 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 14:58:25 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 14:58:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 14:58:25 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 14:58:25 - OpenVPN > Opened utun device utun1. 2016.12.06 14:58:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 14:58:25 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 14:58:25 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 14:58:25 - OpenVPN > /sbin/ifconfig utun1 10.4.34.157 10.4.34.157 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 14:58:25 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.34.157 255.255.0.0. 2016.12.06 14:58:25 - OpenVPN > add net 10.4.0.0: gateway 10.4.34.157. 2016.12.06 14:58:25 - OpenVPN > /sbin/route add -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:58:25 - OpenVPN > add net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:58:25 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:58:25 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:58:25 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:58:25 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:58:25 - Starting Management Interface. 2016.12.06 14:58:25 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 14:58:25 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 14:58:25 - DNS of a network adapter forced (Nokia 6120 classic)I 2016.12.06 14:58:25 - DNS of a network adapter forced (Bluetooth DUN)I 2016.12.06 14:58:25 - DNS of a network adapter forced (Wi-Fi). 2016.12.06 14:58:26 - Unknown networksetup output: '*FireWire is not a recognized network service.;** Error: The parameters were not valid.' for interface '*FireWire'I 2016.12.06 14:58:26 - DNS of a network adapter forced (iPad)I 2016.12.06 14:58:26 - DNS of a network adapter forced (Ethernet)I 2016.12.06 14:58:26 - Flushing DNSI 2016.12.06 14:58:26 - Checking routeW 2016.12.06 14:59:16 - The request timed out! 2016.12.06 14:59:17 - Disconnecting. 2016.12.06 14:59:17 - Management - Send 'signal SIGTERM'. 2016.12.06 14:59:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 14:59:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.06 14:59:17 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.06 14:59:22 - OpenVPN > /sbin/route delete -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:59:22 - OpenVPN > delete net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:59:22 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:59:22 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:59:22 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:59:22 - Connection terminated.. 2016.12.06 14:59:22 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1I 2016.12.06 14:59:22 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2016.12.06 14:59:22 - OpenVPN > Closing TUN/TAP interface. 2016.12.06 14:59:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exitingI 2016.12.06 14:59:22 - DNS of a network adapter restored to original settings (Nokia 6120 classic)I 2016.12.06 14:59:23 - DNS of a network adapter restored to original settings (Bluetooth DUN)I 2016.12.06 14:59:23 - DNS of a network adapter restored to original settings (Wi-Fi)I 2016.12.06 14:59:23 - DNS of a network adapter restored to original settings (iPad)I 2016.12.06 14:59:23 - DNS of a network adapter restored to original settings (Ethernet)I 2016.12.06 14:59:26 - Checking authorization ...! 2016.12.06 14:59:26 - Connecting to Altarf (Sweden, Uppsala). 2016.12.06 14:59:26 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.06 14:59:26 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.06 14:59:26 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.06 14:59:26 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.06 14:59:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:59:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:59:26 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2016.12.06 14:59:26 - OpenVPN > UDPv4 link local: [undef]. 2016.12.06 14:59:26 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.140:443. 2016.12.06 14:59:26 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.140:443, sid=dab3e574 1ffa7f1b. 2016.12.06 14:59:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.06 14:59:26 - OpenVPN > Validating certificate key usage. 2016.12.06 14:59:26 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.06 14:59:26 - OpenVPN > VERIFY KU OK. 2016.12.06 14:59:26 - OpenVPN > Validating certificate extended key usage. 2016.12.06 14:59:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.06 14:59:26 - OpenVPN > VERIFY EKU OK. 2016.12.06 14:59:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.06 14:59:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:59:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:59:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.06 14:59:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.06 14:59:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.06 14:59:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.140:443. 2016.12.06 14:59:29 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.06 14:59:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.34.157 255.255.0.0'. 2016.12.06 14:59:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.06 14:59:29 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2016.12.06 14:59:29 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.06 14:59:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.06 14:59:29 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.06 14:59:29 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.06 14:59:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.06 14:59:29 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2016.12.06 14:59:29 - OpenVPN > Opened utun device utun1. 2016.12.06 14:59:29 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.06 14:59:29 - OpenVPN > /sbin/ifconfig utun1 delete. 2016.12.06 14:59:29 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2016.12.06 14:59:29 - OpenVPN > /sbin/ifconfig utun1 10.4.34.157 10.4.34.157 netmask 255.255.0.0 mtu 1500 up. 2016.12.06 14:59:29 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.34.157 255.255.0.0. 2016.12.06 14:59:29 - OpenVPN > add net 10.4.0.0: gateway 10.4.34.157. 2016.12.06 14:59:29 - OpenVPN > /sbin/route add -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 14:59:29 - OpenVPN > add net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 14:59:29 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:59:29 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 14:59:29 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 14:59:29 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 14:59:29 - Starting Management Interface. 2016.12.06 14:59:29 - OpenVPN > Initialization Sequence CompletedI 2016.12.06 14:59:29 - DNS of a network adapter forced (Bluetooth PAN)I 2016.12.06 14:59:29 - DNS of a network adapter forced (Nokia 6120 classic)I 2016.12.06 14:59:30 - DNS of a network adapter forced (Bluetooth DUN)I 2016.12.06 14:59:30 - DNS of a network adapter forced (Wi-Fi). 2016.12.06 14:59:30 - Unknown networksetup output: '*FireWire is not a recognized network service.;** Error: The parameters were not valid.' for interface '*FireWire'I 2016.12.06 14:59:30 - DNS of a network adapter forced (iPad)I 2016.12.06 14:59:30 - DNS of a network adapter forced (Ethernet)I 2016.12.06 14:59:30 - Flushing DNSI 2016.12.06 14:59:30 - Checking routeW 2016.12.06 15:00:20 - The request timed out! 2016.12.06 15:00:20 - Disconnecting. 2016.12.06 15:00:20 - Management - Send 'signal SIGTERM'. 2016.12.06 15:00:20 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.06 15:00:20 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.06 15:00:20 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.06 15:00:25 - OpenVPN > /sbin/route delete -net 62.102.148.140 192.168.1.1 255.255.255.255. 2016.12.06 15:00:25 - OpenVPN > delete net 62.102.148.140: gateway 192.168.1.1. 2016.12.06 15:00:25 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 15:00:25 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2016.12.06 15:00:25 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2016.12.06 15:00:25 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2016.12.06 15:00:25 - OpenVPN > Closing TUN/TAP interface. 2016.12.06 15:00:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.06 15:00:25 - Connection terminated.I 2016.12.06 15:00:25 - DNS of a network adapter restored to original settings (Bluetooth PAN)I 2016.12.06 15:00:25 - DNS of a network adapter restored to original settings (Nokia 6120 classic)I 2016.12.06 15:00:25 - DNS of a network adapter restored to original settings (Bluetooth DUN)I 2016.12.06 15:00:25 - DNS of a network adapter restored to original settings (Wi-Fi)I 2016.12.06 15:00:25 - DNS of a network adapter restored to original settings (iPad)I 2016.12.06 15:00:25 - DNS of a network adapter restored to original settings (Ethernet)I 2016.12.06 15:00:28 - Cancel requested.I 2016.12.06 15:00:28 - IPv6 restored on network adapter (Bluetooth PAN)I 2016.12.06 15:00:28 - IPv6 restored on network adapter (Nokia 6120 classic)I 2016.12.06 15:00:28 - IPv6 restored on network adapter (Bluetooth DUN)I 2016.12.06 15:00:28 - IPv6 restored on network adapter (Wi-Fi)I 2016.12.06 15:00:28 - IPv6 restored on network adapter (*FireWire)I 2016.12.06 15:00:29 - IPv6 restored on network adapter (iPad)I 2016.12.06 15:00:29 - IPv6 restored on network adapter (Ethernet)! 2016.12.06 15:00:29 - Session terminated. Quote Share this post Link to post
Staff 10386 Posted ... General advices to fix the problem in OS X: reboot both the router and the systemif the problem persists try to "patch" the notorious OS X bug with WiFi. You might need to periodically re-apply the "patch". Probably not relevant if you connect your Mac with Ethernet. The bug affects all OS X versions and macOS Sierra. See below.Instructions to fix in various versions:http://osxdaily.com/2015/10/16/fix-wi-fi-problems-mac-os-x-el-capitan/ El Capitanhttp://osxdaily.com/2014/10/25/fix-wi-fi-problems-os-x-yosemite/ Yosemitehttp://osxdaily.com/2016/09/22/fix-wi-fi-problems-macos-sierra/ Sierrahttp://osxdaily.com/2012/11/30/resolving-stubborn-wi-fi-connection-problems-in-mac-os-x/ Mavericks and older OS X versionsOther possible specific causes:router blocking UDPsystem packet filtering tool blocking UDPISP blocking UDP For the last aforementioned cause the only solution is connecting in TCP, or OpenVPN over SSL or SSH. Kind regards Quote Share this post Link to post
t-petja 0 Posted ... I'm on wired Ethernet and a cable modem. I've rebooted the computer and the modem. There's no changes in modem settings and AirVPN client worked fine last time. I'm in a very free country. Connection to DNS's seems ok, the problem seems to be with route checking. Quote Share this post Link to post
t-petja 0 Posted ... Thanks Khariz, it did work — once I found the preference. I'm still worried tho why the check doesn't work anymore. Quote Share this post Link to post
