Staff 9763 Posted ... UPDATE: the problems have been fixed on the datacenterHello!There are currently technical problems in one of the datacenters where some of our servers are located (NOT VPN servers) which affect only the AirVPN client behavior and the data provided by the real time servers monitor. You might sporadically experience failed connections during the "Checking" phase of the Air client.We underline that the problem does not affect any VPN server.The issues should be resolved soon. In the meantime we kindly ask you to connect directly with OpenVPN if you can't connect with the Air client.Please do not hesitate to contact us for any further information or support.Kind regards Quote Share this post Link to post
