Not connected, Your IP: 3.138.122.195
acid192
ANSWERED AirVPN Config Not Connecting
I'm using Arch Linux with i3 window manager. I generated an America config file and cd the directory. I did
sudo openvpn thenameofthefile.ovpn and a bunch of text goes across my screen then it says "Sequence Complete" I go to the internet and it cannot connect. I downloaded another config file and it did the same thing. I have openvpn installed aswell.
It could be a DNS problem. Maybe the nameservers you have in /etc/resolv.conf can't be accessed through the VPN servers. If so, this is a very minor problem: your traffic is tunneled but your system can't resolve names. Check for names resolution and connectivity to discern the case, for example (from a command line interface):
ping -c 4 8.8.8.8
ping -c 4 10.4.0.1
ping -c 4 google.com
(if in doubt copy and paste the output of those commands).
resolvconf is available for Arch Linux, right? If so, please see here:
https://airvpn.org/topic/9608-how-to-accept-dns-push-on-linux-systems-with-resolvconf
For a quick test, please edit (as root) the /etc/resolv.conf file while the system is connected to a VPN server, and add the following line:
nameserver 10.4.0.1
then check whether names are resolved.
ping -c 4 8.8.8.8
ping -c 4 10.4.0.1
nameserver 10.4.0.1
It seems to be working (as I'm making this post using the VPN) after setting up another config in Canada but sometimes stops connecting. I was wondering if I do a whole country like Canada and one of the servers stops working will it switch to another server or do I need to set up a new config for Canada again? One more question, if I use the vpn server with tor (set up for arch, not tor browser just using 127.0.0.1 in proxy firefox) will my connection go to the vpn server then through tor or will one of them not work?
APPROVE THIS POST FORGET THE OTHERS
I made the update-resolv-conf.sh file in /usr/share/openvpn and put
script-security 2
up /usr/share/openvpn/update-resolv-conf
down /usr/share/openvpn/update-resolv-conf
ran sudo openvpn nameoffile.ovnp
and nothing worked
I then went in /etc/resolv.conf and added nameserver 10.4.0.1 (like ou said) ran openvpn and it worked!
good that the main problem is solved. Probably OpenVPN logs can explain what goes wrong when trying to execute update-resolv-conf script.
