flyingtigerusa
urgent help: AirVPN client doesn't work under OS X Mountain lion
Mac OS x 10.8.5 Mountain Lion
AirVPN:  ver 2.8
protocol: TCP, port 443
Here is the log:
I 2015.04.08 01:49:35 - Session starting.
I 2015.04.08 01:49:35 - Installing tunnel driver
I 2015.04.08 01:49:36 - Checking authorization ...
! 2015.04.08 01:49:37 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2015.04.08 01:49:37 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.04.08 01:49:37 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.08 01:49:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.08 01:49:37 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.08 01:49:37 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 01:49:37 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 01:49:37 - OpenVPN > Socket Buffers: R=[131072->65536] S=[131072->65536]
. 2015.04.08 01:49:37 - OpenVPN > Attempting to establish TCP connection with [AF_INET]184.75.214.162:443 [nonblock]
. 2015.04.08 01:49:38 - OpenVPN > TCP connection established with [AF_INET]184.75.214.162:443
. 2015.04.08 01:49:38 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.04.08 01:49:38 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]184.75.214.162:443
. 2015.04.08 01:49:38 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.214.162:443, sid=94476d4d e8f29f0c
. 2015.04.08 01:49:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.08 01:49:40 - OpenVPN > Validating certificate key usage
. 2015.04.08 01:49:40 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.08 01:49:40 - OpenVPN > VERIFY KU OK
. 2015.04.08 01:49:40 - OpenVPN > Validating certificate extended key usage
. 2015.04.08 01:49:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.08 01:49:40 - OpenVPN > VERIFY EKU OK
. 2015.04.08 01:49:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.08 01:49:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.08 01:49:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 01:49:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.08 01:49:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 01:49:43 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.08 01:49:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.214.162:443
. 2015.04.08 01:49:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.08 01:49:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.0.57 255.255.0.0'
. 2015.04.08 01:49:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.08 01:49:46 - OpenVPN > dyld: lazy symbol binding failed: Symbol not found: ___strlcpy_chk
. 2015.04.08 01:49:46 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.08 01:49:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.08 01:49:46 - OpenVPN >   Referenced from: /Applications/AirVPN.app/Contents/MacOS/openvpn
. 2015.04.08 01:49:46 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.08 01:49:46 - OpenVPN >   Expected in: /usr/lib/libSystem.B.dylib
. 2015.04.08 01:49:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.08 01:49:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.08 01:49:46 - OpenVPN > dyld: Symbol not found: ___strlcpy_chk
! 2015.04.08 01:49:46 - Disconnecting
. 2015.04.08 01:49:46 - Connection terminated.
I 2015.04.08 01:49:50 - Checking authorization ...
! 2015.04.08 01:49:50 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2015.04.08 01:49:50 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.04.08 01:49:50 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.08 01:49:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.08 01:49:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.08 01:49:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 01:49:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 01:49:50 - OpenVPN > Socket Buffers: R=[131072->65536] S=[131072->65536]
. 2015.04.08 01:49:50 - OpenVPN > Attempting to establish TCP connection with [AF_INET]184.75.214.162:443 [nonblock]
So what's the problem? how to fix it?
Eddie can run in Mavericks and Yosemite. Previous OS X versions should run Tunnelblick (free and open source software as well).
