Not connected, Your IP: 3.141.8.247
cooperz
NetworkLock does not allow local traffic on OS.X Yosemite (10.10)
Hi there,
I'm running Eddie AirVpn Client software version 2.8.
I configured airvpn with some local traffic white listed (both Outside the VPN tunnel - 192.168.0.0/16 and manually in network lock).
However, I cannot get any local traffic to pass through..
Upon inspecting the pf rules, I see the following:
sh-3.2# sudo pfctl -sr
No ALTQ support in kernel
ALTQ related functions disabled
block drop out inet all
pass out quick inet from 10.0.0.0/8 to 10.0.0.0/8 flags S/SA keep state
pass out quick on utun0 inet from 10.0.0.0/8 to any flags S/SA keep state
pass out quick inet from any to <__automatic_bb554c31_0> flags S/SA keep state
pass out quick inet from 172.16.0.0/12 to 172.16.0.0/12 flags S/SA keep state
pass quick on utun0 inet from any to 10.0.0.0/8 flags S/SA keep state
pass quick on lo0 all flags S/SA keep state
It does not look like the 192.168.0.0 rule is there...
However,
The generated temp file in ~/.airvpn/1c1d81cef74e0d65fd179c59ad525579da19fc6d5e4142dbed5a8efd55b1041d.tmp.pf.conf
correctly generates the rules:
# Private networks
pass out quick inet from 192.168.0.0/16 to 192.168.0.0/16 flags S/SA keep state
# Allow all on lo0
# Everything tunneled
Any help will be appreciated.
