Not connected, Your IP: 216.73.217.142
Soval7
Constant trying to connect, disconnect, retry
I noticed it saying in the log I have windows NT, but I have windows 7 home premium sp1.
I 2015.02.02 11:13:21 - AirVPN client version: 2.8.8, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Architecture: x64
. 2015.02.02 11:13:21 - Reading options from C:\Users\Jonny\AppData\Local\AirVPN\AirVPN.xml
. 2015.02.02 11:13:25 - Data Path: C:\Users\Jonny\AppData\Local\AirVPN
. 2015.02.02 11:13:25 - App Path: C:\Program Files\AirVPN
. 2015.02.02 11:13:25 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.02.02 11:13:25 - Command line arguments (1): path="home"
. 2015.02.02 11:13:26 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2015.02.02 11:13:26 - Updating systems & servers data ...
I 2015.02.02 11:13:34 - OpenVPN Driver - TAP-Windows Adapter V9
I 2015.02.02 11:13:34 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.02.02 11:13:34 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.02.02 11:13:34 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stunnel.exe)
I 2015.02.02 11:13:34 - IPV6: Available
! 2015.02.02 11:13:34 - Ready
. 2015.02.02 11:13:36 - Systems & servers data update completed
I 2015.02.02 11:13:37 - Session starting.
I 2015.02.02 11:13:37 - Installing tunnel driver
I 2015.02.02 11:13:38 - Checking authorization ...
! 2015.02.02 11:13:39 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:13:39 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:13:39 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:13:45 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:13:45 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:13:45 - Disconnecting
. 2015.02.02 11:13:45 - Connection terminated.
I 2015.02.02 11:13:48 - Checking authorization ...
! 2015.02.02 11:13:53 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:13:53 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:13:53 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:13:53 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:13:53 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:13:54 - Disconnecting
. 2015.02.02 11:13:54 - Connection terminated.
I 2015.02.02 11:13:57 - Checking authorization ...
! 2015.02.02 11:13:57 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:13:57 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:13:57 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:13:57 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:13:57 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:13:58 - Disconnecting
. 2015.02.02 11:13:58 - Connection terminated.
I 2015.02.02 11:14:01 - Checking authorization ...
! 2015.02.02 11:14:01 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:14:01 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:14:01 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:14:01 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:14:01 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:14:01 - Disconnecting
. 2015.02.02 11:14:01 - Connection terminated.
I 2015.02.02 11:14:04 - Checking authorization ...
! 2015.02.02 11:14:05 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:14:05 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:14:05 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:14:05 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:14:05 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:14:05 - Disconnecting
. 2015.02.02 11:14:05 - Connection terminated.
I 2015.02.02 11:14:08 - Checking authorization ...
! 2015.02.02 11:14:09 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:14:09 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:14:09 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:14:09 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:14:09 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:14:09 - Disconnecting
. 2015.02.02 11:14:09 - Connection terminated.
I 2015.02.02 11:14:12 - Checking authorization ...
! 2015.02.02 11:14:13 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:14:13 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:14:13 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:14:13 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:14:13 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:14:13 - Disconnecting
. 2015.02.02 11:14:13 - Connection terminated.
I 2015.02.02 11:14:16 - Checking authorization ...
! 2015.02.02 11:14:17 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:14:17 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:14:17 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:14:17 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:14:17 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:14:17 - Disconnecting
. 2015.02.02 11:14:17 - Connection terminated.
I 2015.02.02 11:14:20 - Checking authorization ...
! 2015.02.02 11:14:21 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:14:21 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:14:21 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:14:21 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:14:21 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:14:21 - Disconnecting
. 2015.02.02 11:14:21 - Connection terminated.
I 2015.02.02 11:14:24 - Checking authorization ...
! 2015.02.02 11:14:24 - Connecting to Rana (Canada, Toronto, Ontario)
. 2015.02.02 11:14:25 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.02.02 11:14:25 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.02.02 11:14:25 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: The requested name is valid, but no data of the requested type was found.
. 2015.02.02 11:14:25 - OpenVPN > Exiting due to fatal error
! 2015.02.02 11:14:25 - Disconnecting
. 2015.02.02 11:14:25 - Connection terminated.
Windows NT 6.1 has been assigned various marketing names, including "Windows 7" in seven different "flavors". https://en.wikipedia.org/wiki/Windows_NT#Releases
About the logs, we see this issue:
Can you please make sure that in your hosts file you have this entry:
127.0.0.1 localhost
If it's not there, please add it. If you need support to edit the hosts file please see here: http://www.howtogeek.com/howto/27350/beginner-geek-how-to-edit-your-hosts-file
Yep, that was it. Connecting fine now... not sure why I didn't think of that. lol
