Not connected, Your IP: 18.119.126.80
Swain
Connection timeout with OpenVPN on iPad
Trying to connect from iPad to UK (area) proxy servers per instructions here
https://airvpn.org/ios/
Connection not established, throws "Connection timeout", I've tried "Advanced Options",  "Resolved hosts in .ovpn file" and  "All servers for area or region" as per here
https://airvpn.org/topic/10000-connection-timeout/
OpenVPN log attached (openvpn.txt).
Any suggestions most appreciated.
Thanks!
Swain
openvpn.txt
I have the same issue with OpenVPN Connect via iOS iPod.
The issue is related to TCP: UDP profiles work correctly.
Does anyone here use OpenVPN Connect in iOS with TCP profiles?
Thanks for any feedback.
I just tested it on my iOS8 iphone.  openvpn connect with TCP 443 profile.  connected right up, no problem, on both home internet (wifi) and cellular data.
I also tried same profile in guizmovpn and it worked as well.
