Not connected, Your IP: 3.133.141.6
piercedfreak
ANSWERED openvpn not connecting(noob to vpns)
i generated a config file,  put it in config directory, and when i try to connect i get this. after doing some searching it seems its trying to connect to a proxy on port 1413 locally, but i do not run a local proxy on any ports. did i miss something in setting up openvpn, or generating my config file?
Thu Oct 23 12:38:11 2014 OpenVPN 2.3.4 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Oct 21 2014
Thu Oct 23 12:38:11 2014 library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.05
Thu Oct 23 12:38:11 2014 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341
Thu Oct 23 12:38:11 2014 Need hold release from management interface, waiting...
Thu Oct 23 12:38:11 2014 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341
Thu Oct 23 12:38:11 2014 MANAGEMENT: CMD 'state on'
Thu Oct 23 12:38:11 2014 MANAGEMENT: CMD 'log all on'
Thu Oct 23 12:38:11 2014 MANAGEMENT: CMD 'hold off'
Thu Oct 23 12:38:11 2014 MANAGEMENT: CMD 'hold release'
Thu Oct 23 12:38:12 2014 Control Channel Authentication: tls-auth using INLINE static key file
Thu Oct 23 12:38:12 2014 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Oct 23 12:38:12 2014 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Oct 23 12:38:12 2014 Socket Buffers: R=[8192->8192] S=[8192->8192]
Thu Oct 23 12:38:12 2014 Attempting to establish TCP connection with [AF_INET]127.0.0.1:1413 [nonblock]
Thu Oct 23 12:38:12 2014 MANAGEMENT: >STATE:1414082292,TCP_CONNECT,,,
Thu Oct 23 12:38:22 2014 TCP: connect to [AF_INET]127.0.0.1:1413 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
Thu Oct 23 12:38:27 2014 MANAGEMENT: >STATE:1414082307,TCP_CONNECT,,,
Thu Oct 23 12:38:37 2014 TCP: connect to [AF_INET]127.0.0.1:1413 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
Thu Oct 23 12:38:42 2014 MANAGEMENT: >STATE:1414082322,TCP_CONNECT,,,
The Configuration Generator will generate directives to connect OpenVPN to 127.0.0.1:1413 in OpenVPN over SSL/SSH modes (EDIT: if these modes are selected, of course). In these modes, stunnel or ssh  must be running before OpenVPN is run.
You might like to run our client Eddie to make things simpler.
