CriticalRabbit 6 Posted ... Hi, I need a better walkthrough for setting up Airvpn in Debian. I’m relatively new to Linux, although I did manage to easily set up Airvpn in Ubuntu. However, I’m just not getting anywhere with Debian, and I can’t seem to find a solution. Any help welcome, Cheers Quote Share this post Link to post
yaiyaiyai7 0 Posted ... (edited) same problem I installed AirVPN in Kali Linux, but can not connected with any servers. Hi from 2023 Edited ... by yaiyaiyai7 Quote Share this post Link to post
Staff 9762 Posted ... Hello! For your Kali and Debian distributions we offer two software: the AirVPN Suite and Eddie. If you have picked the Suite, its user's manual is available here:https://airvpn.org/suite/readme/ It will guide you step by step from the basic installation to the advanced usage. For any issue please do not hesitate to open a ticket and include log. If you picked Eddie, see below.@yaiyaiyai7 Please post an Eddie's system report, or the log of the software you run (for example WireGuard and OpenVPN) to connect. Also feel free to open a ticket. How to generate and send a report via Eddie: https://airvpn.org/forums/topic/50663-youve-been-asked-for-a-support-filesystem-report-–-heres-what-to-do/@CriticalRabbit Assuming that you could not manage to install Eddie in Debian (if you did, please see above to send us a system report), please follow these steps: Download the deb package If you work in a Desktop Environment, right-click the icon of the downloaded deb package and select "Open with" > "Package installer" You will find Eddie in the "Internet" section of your app launcher If you don't run a DE or anyway you prefer to install via terminal, you can install the deb package via gdebi. Open a terminal and enter the commands: sudo apt install gdebi sudo gdebi "path and name of the deb package you downloaded" You will find Eddie in the "Internet" section of your app launcher. Also feel free to open a ticket. Kind regards Quote Share this post Link to post
