illedan2 0 Posted ... Hi Guys, I have searched this forum and been on the DD-WRT Wiki guides on how to split traffic but I haven't worked out the simplest way. When using the rules below I am not sure what do to next to split the traffic. I have tried the following highlighted in blue from what I have read on the dd-wrt wiki policy base routing and on this forum. iptables -I FORWARD -i br0 -o tun1 -j ACCEPTiptables -I FORWARD -i tun1 -o br0 -j ACCEPTiptables -I INPUT -i tun1 -j REJECTiptables -t nat -A POSTROUTING -o tun1 -j MASQUERADE Ip rule add from 192.168.1.102/24 table 200Ip route add default via XX.XX.XX.X/22 dev vlan2 table 200 note the X is Virgins gateway address and Vlan2 shows as the wan. I also tried route add -net 192.168.1.102/24 gw XX.XXX.XX.X/22 Both do not work either saving as firewall rule or startup script. If anyone has made a rule to split traffic so its not going through openvpn for a console or computer could you please share. Thanks. Quote Share this post Link to post
Staff 9764 Posted ... Hello, first check the most obvious, possible mistakes. Command "Ip" does not exist, probably you want to use "ip". Kind regards Quote Share this post Link to post
illedan2 0 Posted ... Hi I have tried lower case ip and I still can't seperate it from the VPN. I am not good with scripts and Linux although I have been trying to learn the basics. The rule above used to allow all traffic to be in the tunnel and is the rule in your dd-wrt setup guide, can this be modified to allow normal traffic as well maybe on a certain port or by setting up another vlan on a different subnet? Thanks. Quote Share this post Link to post
