Not connected, Your IP: 216.73.217.178
spitzer
ANSWERED Linux/Ubuntu Terminal help needed
I am trying to connect to AirVPN through the Terminal both in Linux Mint 16 and Ubuntu 14.04.  I followed the instructions here https://airvpn.org/topic/11431-using-airvpn-with-linux-from-terminal/?hl=linux.
It seems to connect ("Initialization Sequence Completed") however I cannot access any websites at this point.
$ sudo openvpn AirVPN_CA-Thabit_UDP-443.ovpn
Wed Apr 30 20:38:03 2014 OpenVPN 2.3.2 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [IPv6] built on Feb  4 2014
Wed Apr 30 20:38:03 2014 Control Channel Authentication: tls-auth using INLINE static key file
Wed Apr 30 20:38:03 2014 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Apr 30 20:38:03 2014 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Apr 30 20:38:03 2014 Socket Buffers: R=[212992->131072] S=[212992->131072]
Wed Apr 30 20:38:03 2014 UDPv4 link local: [undef]
Wed Apr 30 20:38:03 2014 UDPv4 link remote: [AF_INET]198.144.158.11:443
Wed Apr 30 20:38:03 2014 TLS: Initial packet from [AF_INET]198.144.158.11:443, sid=771fd979 1a95a41e
Wed Apr 30 20:38:03 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Wed Apr 30 20:38:03 2014 Validating certificate key usage
Wed Apr 30 20:38:03 2014 ++ Certificate has key usage  00a0, expects 00a0
Wed Apr 30 20:38:03 2014 VERIFY KU OK
Wed Apr 30 20:38:03 2014 Validating certificate extended key usage
Wed Apr 30 20:38:03 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Wed Apr 30 20:38:03 2014 VERIFY EKU OK
Wed Apr 30 20:38:03 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Wed Apr 30 20:38:04 2014 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Apr 30 20:38:04 2014 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Apr 30 20:38:04 2014 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Apr 30 20:38:04 2014 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Apr 30 20:38:04 2014 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Wed Apr 30 20:38:04 2014 [server] Peer Connection Initiated with [AF_INET]198.144.158.11:443
Wed Apr 30 20:38:06 2014 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Apr 30 20:38:06 2014 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.1.90 10.4.1.89'
Wed Apr 30 20:38:06 2014 OPTIONS IMPORT: timers and/or timeouts modified
Wed Apr 30 20:38:06 2014 OPTIONS IMPORT: LZO parms modified
Wed Apr 30 20:38:06 2014 OPTIONS IMPORT: --ifconfig/up options modified
Wed Apr 30 20:38:06 2014 OPTIONS IMPORT: route options modified
Wed Apr 30 20:38:06 2014 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Wed Apr 30 20:38:06 2014 ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:23:5a:d2:70:91
Wed Apr 30 20:38:06 2014 TUN/TAP device tun0 opened
Wed Apr 30 20:38:06 2014 TUN/TAP TX queue length set to 100
Wed Apr 30 20:38:06 2014 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Wed Apr 30 20:38:06 2014 /sbin/ip link set dev tun0 up mtu 1500
Wed Apr 30 20:38:06 2014 /sbin/ip addr add dev tun0 local 10.4.1.90 peer 10.4.1.89
Wed Apr 30 20:38:06 2014 /sbin/ip route add xxx.xxx.xxx.xxx/32 via 192.168.0.1
Wed Apr 30 20:38:06 2014 /sbin/ip route add 0.0.0.0/1 via 10.4.1.89
Wed Apr 30 20:38:06 2014 /sbin/ip route add 128.0.0.0/1 via 10.4.1.89
Wed Apr 30 20:38:06 2014 /sbin/ip route add 10.4.0.1/32 via 10.4.1.89
Wed Apr 30 20:38:06 2014 Initialization Sequence Completed
After the initialization sequence is completed, do not stop OpenVPN. Open a terminal, issue the following commands, copy everything and paste:
ping -c 2 google.com
ping -c 2 10.4.0.1
ping -c 2 8.8.8.8
traceroute google.com
Since the logs are perfect (note that we wiped out an IP address to preserve your privacy), the above is basically a test to determine whether the problem arises from DNS.
If it does, you might like to follow this guide (you'll need resolvconf installed): https://airvpn.org/topic/9608-how-to-accept-dns-push-on-linux-systems-with-resolvconf
Ok, seems to have been a DNS issue.  I had to add the update-resolv-conf script to the OpenVPN configuration file and everything works fine now.
Thanks.
