boom 0 Posted ... Hello! My English is very poor... I have buy 1 month through Paypal. AriVPN not connection. Work only "Access without our client". 27.11.2011 - 16:51 AirVPN client version: 1,4 27.11.2011 - 16:51 OpenVPN bundle version: OpenVPN 2.2.1 27.11.2011 - 16:51 OpenVPN current version: OpenVPN 2.2.1 27.11.2011 - 16:51 Ready. 27.11.2011 - 16:51 Login... 27.11.2011 - 16:51 Login success. 27.11.2011 - 16:51 Contacting service... 27.11.2011 - 16:51 Connecting... 27.11.2011 - 16:51 OpenVPN 2.2.1 Win32-MSVC++ [sSL] [LZO2] built on Jul 1 2011 27.11.2011 - 16:51 MANAGEMENT: TCP Socket listening on 127.0.0.1:3100 27.11.2011 - 16:51 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 27.11.2011 - 16:51 Cannot load certificate file C:\Users\???????????????‚???°?‚????\AppData\Local\Temp\tmpBE92.tmp: error:02001003:system library:fopen:No such process: error:20074002:BIO routines:FILE_CTRL:system lib: error:140AD002:SSL routines:SSL_CTX_use_certificate_file:system lib 27.11.2011 - 16:51 Exiting 27.11.2011 - 16:51 Failed to start. With respect, Thank you in advance. Quote Share this post Link to post
Staff 9763 Posted ... @boom Hello! Can you tell us which version of Windows and .NET framework you're using? If you can connect through the OpenVPN client, the OpenVPN installation is ok. Can you confirm that you're able to connect to the servers with OpenVPN (we are unsure from your message)? Feel free to give as many information as possible, so that the client programmers can support you with more accuracy. Kind regards AirVPN admins Quote Share this post Link to post
boom 0 Posted ... I am using Windows 7 ultimate and .NET framework 4. I am good connect OpenVPN to yours severs. I was at work trying to connect through a proxy server. And made ??a mistake. I now home. Quote Share this post Link to post
boom 0 Posted ... Sorry! The problem was in the wrong version NET. Framework. Worked version Framework 4. On the Windows 7 was turned off NET.Framework 3.5.1. It should be included in "Control panel"-"Programs and Features"-"Turn Windows features on or off"... Now everthing is working! With respect... Quote Share this post Link to post
Staff 9763 Posted ... Hello and thank you! We're glad to hear that the problem has been solved. Please do not hesitate to contact us for any further information. Kind regards AirVPN admins Quote Share this post Link to post
