bubocz 1 Posted ... Hello, I have found out that MS OneNote - on my PC, iPhone and IPad - does not sync with Skydrive when I use AirVPN anymore :-(. It seems to me that port necessary for this is closed and I do not know which port I should open. Does anybody has more information? Thanks to anyone who can help! Quote Share this post Link to post
Tech Jedi Alex 1581 Posted ... Which servers did you use? Try a sync with another server. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
bubocz 1 Posted ... Which servers did you use? Try a sync with another server. I am afraid there is no settings for a servers :-( - or do you know where to set it? Quote Share this post Link to post
Tech Jedi Alex 1581 Posted ... Do you use the Air client or another VPN client? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
bubocz 1 Posted ... Do you use the Air client or another VPN client? I am using my ASUS DD-WRT router with OpenVPN client inside. But I am ready to try AirVPN client at my PC if it helps me to investigate how to continue... Quote Share this post Link to post
Staff 10693 Posted ... Do you use the Air client or another VPN client? I am using my ASUS DD-WRT router with OpenVPN client inside. But I am ready to try AirVPN client at my PC if it helps me to investigate how to continue... Hello, in this case you have to remember to properly forward packets to the appropriate device behind the router through a DNAT (for every and each port you wish to forward), because the devices connected to the router are behind the router NAT itself. Please see this guide https://airvpn.org/topic/9270-how-to-forward-ports-in-dd-wrt-tomato-with-iptables Kind regards Quote Share this post Link to post
bubocz 1 Posted ... Do you use the Air client or another VPN client? I am using my ASUS DD-WRT router with OpenVPN client inside. But I am ready to try AirVPN client at my PC if it helps me to investigate how to continue... Hello, in this case you have to remember to properly forward packets to the appropriate device behind the router through a DNAT (for every and each port you wish to forward), because the devices connected to the router are behind the router NAT itself. Please see this guide https://airvpn.org/topic/9270-how-to-forward-ports-in-dd-wrt-tomato-with-iptables Kind regardsHello, Yes I know, I have done it already for another device with P2P for Transmission client. But in that case, I was able to choose corresponing port based on settings in Transmission client and this port number was available here - but it this OneNote case, I do not know exactly port number and - moreover - I cannot define this ports by myself. Now, I made other investigations and to my surprise I cannot connect to https://skydrive.live.com even from my browser. All the other https are working :-( WHen I switch DNS from 10.4.0.1. to 8.8.8.8. it starts working and even OneNote client is working correctly. Switching back to 10.4.0.1. and the same problem as before. :-( So I apologize - problem seems to be not in the closed ports and their forwarding but in DNS 10.4.0.1. I set in my router. :-( But I would like to use this recommended AirVPN's DNS - so I expect that there is a solution of this problem na provider side... :-D Regards Quote Share this post Link to post
Staff 10693 Posted ... Hello, is the listening port reported on MS One Note manual? If not, launch the program and issue the command "netstat -a -b" from a command prompt to see it, or use TCPView by Mark Russinovich http://technet.microsoft.com/en-us/sysinternals/bb897437.aspx Kind regards Quote Share this post Link to post
bubocz 1 Posted ... Hello, is the listening port reported on MS One Note manual? If not, launch the program and issue the command "netstat -a -b" from a command prompt to see it, or use TCPView by Mark Russinovich http://technet.microsoft.com/en-us/sysinternals/bb897437.aspx Kind regards Hello, is the listening port reported on MS One Note manual? If not, launch the program and issue the command "netstat -a -b" from a command prompt to see it, or use TCPView by Mark Russinovich http://technet.microsoft.com/en-us/sysinternals/bb897437.aspx Kind regardsHello. no, none port is reported. But as I wrote above, after a change of DNS server at my DD-WRT rourer (instead 10.4.:0.1. I use 8.8.8.8.) work OneNote sync everywhere - on PC and on Ipad. I tried mentioned command "netstat -a -b" (with above mentioned DNS 8.8.8.8) and I got [ONENOTE.EXE] TCP 192.168.1.220:50331 207.46.0.174:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50332 207.46.0.174:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50333 134.170.109.152:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50334 134.170.104.232:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50335 134.170.109.152:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50336 134.170.109.152:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50337 134.170.109.224:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50340 snt-re2-10d:http NAVÁZÁNO [Dropbox.exe] TCP 192.168.1.220:50344 134.170.109.96:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50345 134.170.109.96:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50346 157.55.241.168:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50347 134.170.109.224:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50348 134.170.109.224:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50349 134.170.109.224:https NAVÁZÁNO [ONENOTE.EXE] TCP 192.168.1.220:50350 airvpn:https NAVÁZÁNO Is above mentioned information suitable for you? Regards Quote Share this post Link to post
Staff 10693 Posted ... Hello, yes, the ports are reported, as you can see. Apparently you have no need to remotely forward ports: it's onenote.exe that established the connections, it does not listen for incoming connections (and it's quite logical). We're glad to know that the problem is solved. Kind regards Quote Share this post Link to post
bubocz 1 Posted ... Hello, yes, the ports are reported, as you can see. Apparently you have no need to remotely forward ports: it's onenote.exe that established the connections, it does not listen for incoming connections (and it's quite logical). We're glad to know that the problem is solved. Kind regardsYes, you are right. But it seems to me that the problem itself is not solved yet - I cannot use you recommended DNS and have to use Google´s one (which I would of course prefer)... Regards Quote Share this post Link to post
Staff 10693 Posted ... Hello, while the router is connected to the VPN, can you ping 10.4.0.1 from a computer connected to the router? And from the router itself? Kind regards Quote Share this post Link to post
bubocz 1 Posted ... Hello, while the router is connected to the VPN, can you ping 10.4.0.1 from a computer connected to the router? And from the router itself? Kind regardsHello, yes, it works. With DNS 10.4.0.1. - when I tried - works nearly everything exept address https://skydrive.live.com (even from my browser). I am afraid it seems to be the address I need to sync MS One Note... Regards Quote Share this post Link to post
Staff 10693 Posted ... Hello, skydrive.live.com is correctly resolved by our DNS and the web site is accessible from the VPN servers we have tested (NL and IT). Therefore the problem should be something else. Kind regards Quote Share this post Link to post
bubocz 1 Posted ... Hello, skydrive.live.com is correctly resolved by our DNS and the web site is accessible from the VPN servers we have tested (NL and IT). Therefore the problem should be something else. Kind regardsHello, So do you have any recommendation what to check? At the moment, change of DNS server in Static DNS 1 field at Setup page influences mentioned functionality... Regards Quote Share this post Link to post
Staff 10693 Posted ... Hello! What happens if you set as static DNS 2 a public DNS? What is the output of the command (from the router and while the router is connected to the VPN): dig @10.4.0.1 skydrive.live.com Kind regards Quote Share this post Link to post
bubocz 1 Posted ... Hello! What happens if you set as static DNS 2 a public DNS? What is the output of the command (from the router and while the router is connected to the VPN): dig @10.4.0.1 skydrive.live.com Kind regardsHello, I am afraid I am not capable to run this dig command :-( - I tried it from a web "command" section and I got "/bin/sh: eval: line 1: dig: not found", when I used ssh client I got "not found" :-( As a static DNS2 I used OpenNIC DNS server 50.116.23.211. Regards Quote Share this post Link to post
