Not connected, Your IP: 18.223.20.57
Hi
My AirVPN is facing some issue recently. It was fine previously and this is the first time I encounter this annoying problem.
Every 1 to 4mins, my AirVPN will disconnect, and then reconnect back by itself. I cant even surf net in peace.
Additional info: I am using a school campus network which I only can connect through TCP 53. All the other mode won't work for me.
The log is as follow:
12/11/2013 - 11:19 AM write TCPv4_CLIENT: Connection reset by peer (WSAECONNRESET) (code=10054)
12/11/2013 - 11:19 AM read TCPv4_CLIENT: Connection timed out (WSAETIMEDOUT) (code=10060)
12/11/2013 - 11:19 AM Connection reset, restarting [-1]
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe DELETE 10.9.0.1 MASK 255.255.255.255 10.9.0.53
12/11/2013 - 11:19 AM Route deletion via IPAPI succeeded [adaptive]
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe DELETE 119.81.1.123 MASK 255.255.255.255 192.168.0.1
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:19 AM Closing TUN/TAP interface
12/11/2013 - 11:19 AM SIGUSR1[soft,connection-reset] received, process restarting
12/11/2013 - 11:19 AM Restart pause, 5 second(s)
12/11/2013 - 11:19 AM Socket Buffers: R=[65536->65536] S=[65536->65536]
12/11/2013 - 11:19 AM Attempting to establish TCP connection with [AF_INET]119.81.1.123:53
12/11/2013 - 11:19 AM TCP connection established with [AF_INET]119.81.1.123:53
12/11/2013 - 11:19 AM TCPv4_CLIENT link local: [undef]
12/11/2013 - 11:19 AM TCPv4_CLIENT link remote: [AF_INET]119.81.1.123:53
12/11/2013 - 11:19 AM TLS: Initial packet from [AF_INET]119.81.1.123:53, sid=fe4b2fd4 bf753905
12/11/2013 - 11:19 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
12/11/2013 - 11:19 AM VERIFY OK: nsCertType=SERVER
12/11/2013 - 11:19 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
12/11/2013 - 11:19 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/11/2013 - 11:19 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/11/2013 - 11:19 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/11/2013 - 11:19 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/11/2013 - 11:19 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
12/11/2013 - 11:19 AM [server] Peer Connection Initiated with [AF_INET]119.81.1.123:53
12/11/2013 - 11:19 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
12/11/2013 - 11:19 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.9.0.1,comp-lzo no,route 10.9.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.9.0.54 10.9.0.53'
12/11/2013 - 11:19 AM OPTIONS IMPORT: timers and/or timeouts modified
12/11/2013 - 11:19 AM OPTIONS IMPORT: LZO parms modified
12/11/2013 - 11:19 AM OPTIONS IMPORT: --ifconfig/up options modified
12/11/2013 - 11:19 AM OPTIONS IMPORT: route options modified
12/11/2013 - 11:19 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
12/11/2013 - 11:19 AM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
12/11/2013 - 11:19 AM open_tun, tt->ipv6=0
12/11/2013 - 11:19 AM TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{7EA32832-7421-4607-BA5F-31A9843A6188}.tap
12/11/2013 - 11:19 AM TAP-Windows Driver Version 9.9
12/11/2013 - 11:19 AM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.0.54/255.255.255.252 on interface {7EA32832-7421-4607-BA5F-31A9843A6188} [DHCP-serv: 10.9.0.53, lease-time: 31536000]
12/11/2013 - 11:19 AM Successful ARP Flush on interface [16] {7EA32832-7421-4607-BA5F-31A9843A6188}
12/11/2013 - 11:19 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe ADD 119.81.1.123 MASK 255.255.255.255 192.168.0.1
12/11/2013 - 11:19 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
12/11/2013 - 11:19 AM Route addition via IPAPI succeeded [adaptive]
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:19 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:19 AM C:\Windows\system32\route.exe ADD 10.9.0.1 MASK 255.255.255.255 10.9.0.53
12/11/2013 - 11:19 AM Initialization Sequence Completed
12/11/2013 - 11:19 AM Starting Management Interface...
12/11/2013 - 11:19 AM Checking...
12/11/2013 - 11:19 AM Retrieve statistics...
12/11/2013 - 11:19 AM Connected.
12/11/2013 - 11:21 AM read TCPv4_CLIENT: Connection timed out (WSAETIMEDOUT) (code=10060)
12/11/2013 - 11:21 AM Connection reset, restarting [-1]
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe DELETE 10.9.0.1 MASK 255.255.255.255 10.9.0.53
12/11/2013 - 11:21 AM Route deletion via IPAPI succeeded [adaptive]
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe DELETE 119.81.1.123 MASK 255.255.255.255 192.168.0.1
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:21 AM Closing TUN/TAP interface
12/11/2013 - 11:21 AM SIGUSR1[soft,connection-reset] received, process restarting
12/11/2013 - 11:21 AM Restart pause, 5 second(s)
12/11/2013 - 11:21 AM Socket Buffers: R=[65536->65536] S=[65536->65536]
12/11/2013 - 11:21 AM Attempting to establish TCP connection with [AF_INET]119.81.1.123:53
12/11/2013 - 11:21 AM TCP connection established with [AF_INET]119.81.1.123:53
12/11/2013 - 11:21 AM TCPv4_CLIENT link local: [undef]
12/11/2013 - 11:21 AM TCPv4_CLIENT link remote: [AF_INET]119.81.1.123:53
12/11/2013 - 11:21 AM TLS: Initial packet from [AF_INET]119.81.1.123:53, sid=8f06ab13 9f9772a7
12/11/2013 - 11:21 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
12/11/2013 - 11:21 AM VERIFY OK: nsCertType=SERVER
12/11/2013 - 11:21 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
12/11/2013 - 11:21 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/11/2013 - 11:21 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/11/2013 - 11:21 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/11/2013 - 11:21 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/11/2013 - 11:21 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
12/11/2013 - 11:21 AM [server] Peer Connection Initiated with [AF_INET]119.81.1.123:53
12/11/2013 - 11:21 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
12/11/2013 - 11:21 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.9.0.1,comp-lzo no,route 10.9.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.9.0.54 10.9.0.53'
12/11/2013 - 11:21 AM OPTIONS IMPORT: timers and/or timeouts modified
12/11/2013 - 11:21 AM OPTIONS IMPORT: LZO parms modified
12/11/2013 - 11:21 AM OPTIONS IMPORT: --ifconfig/up options modified
12/11/2013 - 11:21 AM OPTIONS IMPORT: route options modified
12/11/2013 - 11:21 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
12/11/2013 - 11:21 AM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
12/11/2013 - 11:21 AM open_tun, tt->ipv6=0
12/11/2013 - 11:21 AM TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{7EA32832-7421-4607-BA5F-31A9843A6188}.tap
12/11/2013 - 11:21 AM TAP-Windows Driver Version 9.9
12/11/2013 - 11:21 AM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.0.54/255.255.255.252 on interface {7EA32832-7421-4607-BA5F-31A9843A6188} [DHCP-serv: 10.9.0.53, lease-time: 31536000]
12/11/2013 - 11:21 AM Successful ARP Flush on interface [16] {7EA32832-7421-4607-BA5F-31A9843A6188}
12/11/2013 - 11:21 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe ADD 119.81.1.123 MASK 255.255.255.255 192.168.0.1
12/11/2013 - 11:21 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
12/11/2013 - 11:21 AM Route addition via IPAPI succeeded [adaptive]
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:21 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:21 AM C:\Windows\system32\route.exe ADD 10.9.0.1 MASK 255.255.255.255 10.9.0.53
12/11/2013 - 11:21 AM Initialization Sequence Completed
12/11/2013 - 11:21 AM Starting Management Interface...
12/11/2013 - 11:21 AM Checking...
12/11/2013 - 11:21 AM Retrieve statistics...
12/11/2013 - 11:21 AM Connected.
12/11/2013 - 11:23 AM read TCPv4_CLIENT: Connection timed out (WSAETIMEDOUT) (code=10060)
12/11/2013 - 11:23 AM Connection reset, restarting [-1]
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe DELETE 10.9.0.1 MASK 255.255.255.255 10.9.0.53
12/11/2013 - 11:23 AM Route deletion via IPAPI succeeded [adaptive]
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe DELETE 119.81.1.123 MASK 255.255.255.255 192.168.0.1
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:23 AM Closing TUN/TAP interface
12/11/2013 - 11:23 AM SIGUSR1[soft,connection-reset] received, process restarting
12/11/2013 - 11:23 AM Restart pause, 5 second(s)
12/11/2013 - 11:23 AM Socket Buffers: R=[65536->65536] S=[65536->65536]
12/11/2013 - 11:23 AM Attempting to establish TCP connection with [AF_INET]119.81.1.123:53
12/11/2013 - 11:23 AM TCP connection established with [AF_INET]119.81.1.123:53
12/11/2013 - 11:23 AM TCPv4_CLIENT link local: [undef]
12/11/2013 - 11:23 AM TCPv4_CLIENT link remote: [AF_INET]119.81.1.123:53
12/11/2013 - 11:23 AM TLS: Initial packet from [AF_INET]119.81.1.123:53, sid=1f3d8ad9 bf267595
12/11/2013 - 11:23 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
12/11/2013 - 11:23 AM VERIFY OK: nsCertType=SERVER
12/11/2013 - 11:23 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
12/11/2013 - 11:23 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/11/2013 - 11:23 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/11/2013 - 11:23 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/11/2013 - 11:23 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/11/2013 - 11:23 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
12/11/2013 - 11:23 AM [server] Peer Connection Initiated with [AF_INET]119.81.1.123:53
12/11/2013 - 11:23 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
12/11/2013 - 11:23 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.9.0.1,comp-lzo no,route 10.9.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.9.0.54 10.9.0.53'
12/11/2013 - 11:23 AM OPTIONS IMPORT: timers and/or timeouts modified
12/11/2013 - 11:23 AM OPTIONS IMPORT: LZO parms modified
12/11/2013 - 11:23 AM OPTIONS IMPORT: --ifconfig/up options modified
12/11/2013 - 11:23 AM OPTIONS IMPORT: route options modified
12/11/2013 - 11:23 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
12/11/2013 - 11:23 AM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
12/11/2013 - 11:23 AM open_tun, tt->ipv6=0
12/11/2013 - 11:23 AM TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{7EA32832-7421-4607-BA5F-31A9843A6188}.tap
12/11/2013 - 11:23 AM TAP-Windows Driver Version 9.9
12/11/2013 - 11:23 AM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.0.54/255.255.255.252 on interface {7EA32832-7421-4607-BA5F-31A9843A6188} [DHCP-serv: 10.9.0.53, lease-time: 31536000]
12/11/2013 - 11:23 AM Successful ARP Flush on interface [16] {7EA32832-7421-4607-BA5F-31A9843A6188}
12/11/2013 - 11:23 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe ADD 119.81.1.123 MASK 255.255.255.255 192.168.0.1
12/11/2013 - 11:23 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
12/11/2013 - 11:23 AM Route addition via IPAPI succeeded [adaptive]
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:23 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.0.53
12/11/2013 - 11:23 AM C:\Windows\system32\route.exe ADD 10.9.0.1 MASK 255.255.255.255 10.9.0.53
12/11/2013 - 11:23 AM Initialization Sequence Completed
12/11/2013 - 11:23 AM Starting Management Interface...
12/11/2013 - 11:23 AM Checking...
12/11/2013 - 11:23 AM Retrieve statistics...
12/11/2013 - 11:23 AM Connected.
PLEASE HELP!!
Are you on an unstable WLAN?
Do you get disconnected when streaming video without the VPN?
hi dd79
No i dont get disconnected when i am streaming video or whatsoever. The internet is good without the VPN.
this connection drops for this timeout:
If you're connecting via WiFi, please try to get a stronger signal. If you are connecting via cable, there's not much you can try (apart making sure that the cable is not damaged).
