lightleptonparticle
Opera loading airvpn.org incredibly slow
Opera is loading airvpn.org incredibly slowly. I can see that it gets only 1-3 kB per second, and even that seems to jump up and down between 0 and 1-3 kB/s. This problem doesn't happen with Firefox, and doesn't seem to happen with other web pages with Opera.
Does anyone else experience the same, or more importantly know why it happens?
it does not happen with some Opera versions we tested, can you tell us which version you're running? Also, does it have any extension/plugin running?
Version 12.16, no extensions installed. The "elements" load in one by one, slowly. However now it seems to for some strange reason work faster, I just tried it again when checking the version. Thanks for the reply I'll just avoid using Opera.
