RagingElephant
ANSWERED VPN connected, yet no traffic migration from original IP? need help
I need to figure out if I can get this too work while I am still on trial, before I buy a full annual license.  Can anyone look into this?  I started a ticket, but the response has not materialized yet.  I normally would wait, but my trial is up in 1 more day.
any help would be appreciated
details
win 7 x64, port UDP 53, toronto server
gigabit onboard ethernet, no router in between
my log
8/6/2013 - 8:27 PM    AirVPN client version: 1.8
8/6/2013 - 8:27 PM    Reading options from C:\Users\Administrator\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
8/6/2013 - 8:27 PM    OpenVPN bundle version: OpenVPN 2.3.0
8/6/2013 - 8:27 PM    OpenVPN current version: OpenVPN 2.3.0
8/6/2013 - 8:27 PM    Login...
8/6/2013 - 8:27 PM    Login success.
8/6/2013 - 8:27 PM    Contacting service...
8/6/2013 - 8:28 PM    Connecting...
8/6/2013 - 8:28 PM    OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan  8 2013
8/6/2013 - 8:28 PM    NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
8/6/2013 - 8:28 PM    Socket Buffers: R=[8192->8192] S=[8192->8192]
8/6/2013 - 8:28 PM    UDPv4 link local: [undef]
8/6/2013 - 8:28 PM    UDPv4 link remote: [AF_INET]184.75.214.162:53
8/6/2013 - 8:28 PM    TLS: Initial packet from [AF_INET]184.75.214.162:53, sid=8ee75184 9e25f8db
8/6/2013 - 8:28 PM    VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
8/6/2013 - 8:28 PM    VERIFY OK: nsCertType=SERVER
8/6/2013 - 8:28 PM    VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
8/6/2013 - 8:28 PM    Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/6/2013 - 8:28 PM    Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/6/2013 - 8:28 PM    Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/6/2013 - 8:28 PM    Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/6/2013 - 8:28 PM    Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
8/6/2013 - 8:28 PM    [server] Peer Connection Initiated with [AF_INET]184.75.214.162:53
8/6/2013 - 8:28 PM    SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
8/6/2013 - 8:28 PM    PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.8.0.1,comp-lzo no,route 10.8.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.8.1.42 10.8.1.41'
8/6/2013 - 8:28 PM    OPTIONS IMPORT: timers and/or timeouts modified
8/6/2013 - 8:28 PM    OPTIONS IMPORT: LZO parms modified
8/6/2013 - 8:28 PM    OPTIONS IMPORT: --ifconfig/up options modified
8/6/2013 - 8:28 PM    OPTIONS IMPORT: route options modified
8/6/2013 - 8:28 PM    OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
8/6/2013 - 8:28 PM    do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
8/6/2013 - 8:28 PM    open_tun, tt->ipv6=0
8/6/2013 - 8:28 PM    TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{83CC18C3-B390-4183-B887-053CC9A5E487}.tap
8/6/2013 - 8:28 PM    TAP-Windows Driver Version 9.9
8/6/2013 - 8:28 PM    Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.1.42/255.255.255.252 on interface {83CC18C3-B390-4183-B887-053CC9A5E487} [DHCP-serv: 10.8.1.41, lease-time: 31536000]
8/6/2013 - 8:28 PM    Successful ARP Flush on interface [15] {83CC18C3-B390-4183-B887-053CC9A5E487}
8/6/2013 - 8:28 PM    TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
8/6/2013 - 8:28 PM    Route: Waiting for TUN/TAP interface to come up...
8/6/2013 - 8:28 PM    C:\Windows\system32\route.exe ADD 184.75.214.162 MASK 255.255.255.255 69.4.134.1
8/6/2013 - 8:28 PM    ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
8/6/2013 - 8:28 PM    Route addition via IPAPI succeeded [adaptive]
8/6/2013 - 8:28 PM    C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.1.41
8/6/2013 - 8:28 PM    Warning: route gateway is not reachable on any active network adapters: 10.8.1.41
8/6/2013 - 8:28 PM    Route addition via IPAPI failed [adaptive]
8/6/2013 - 8:28 PM    Route addition fallback to route.exe
8/6/2013 - 8:28 PM    env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
8/6/2013 - 8:28 PM     OK!
8/6/2013 - 8:28 PM    C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.1.41
8/6/2013 - 8:28 PM    C:\Windows\system32\route.exe ADD 10.8.0.1 MASK 255.255.255.255 10.8.1.41
8/6/2013 - 8:28 PM    SYSTEM ROUTING TABLE
8/6/2013 - 8:28 PM    1 p=0 i=11 t=4 pr=3 a=76 h=0 m=20/0/0/0/0
8/6/2013 - 8:28 PM    41 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
8/6/2013 - 8:28 PM    10.8.1.41 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
8/6/2013 - 8:28 PM    2 69.4.134.10 p=0 i=11 t=3 pr=3 a=76 h=0 m=276/0/0/0/0
8/6/2013 - 8:28 PM    55 69.4.134.10 p=0 i=11 t=3 pr=3 a=76 h=0 m=276/0/0/0/0
8/6/2013 - 8:28 PM    .0.1 p=0 i=1 t=3 pr=3 a=94 h=0 m=306/0/0/0/0
8/6/2013 - 8:28 PM     127.0.0.1 p=0 i=1 t=3 pr=3 a=94 h=0 m=306/0/0/0/0
8/6/2013 - 8:28 PM    55.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=94 h=0 m=306/0/0/0/0
8/6/2013 - 8:28 PM    1.41 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
8/6/2013 - 8:28 PM    69.254.71.251 p=0 i=15 t=3 pr=3 a=31 h=0 m=286/0/0/0/0
8/6/2013 - 8:28 PM    5.255 169.254.71.251 p=0 i=15 t=3 pr=3 a=31 h=0 m=286/0/0/0/0
8/6/2013 - 8:28 PM    55.255 169.254.71.251 p=0 i=15 t=3 pr=3 a=31 h=0 m=286/0/0/0/0
8/6/2013 - 8:28 PM    5.255 69.4.134.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
8/6/2013 - 8:28 PM    134.10 p=0 i=11 t=3 pr=3 a=89 h=0 m=276/0/0/0/0
8/6/2013 - 8:28 PM    54.71.251 p=0 i=15 t=3 pr=3 a=79 h=0 m=286/0/0/0/0
8/6/2013 - 8:28 PM    55.255 69.4.134.10 p=0 i=11 t=3 pr=3 a=89 h=0 m=276/0/0/0/0
8/6/2013 - 8:28 PM    55.255 169.254.71.251 p=0 i=15 t=3 pr=3 a=79 h=0 m=286/0/0/0/0
8/6/2013 - 8:28 PM    SYSTEM ADAPTER LIST
8/6/2013 - 8:28 PM    TAP-Windows Adapter V9
8/6/2013 - 8:28 PM      Index = 15
8/6/2013 - 8:28 PM    183-B887-053CC9A5E487}
8/6/2013 - 8:28 PM    .255.0.0
8/6/2013 - 8:28 PM      MAC = 00:ff:83:cc:18:c3
8/6/2013 - 8:28 PM    55.255.255
8/6/2013 - 8:28 PM    .255.255.255
8/6/2013 - 8:28 PM    ue Aug 06 20:28:39 2013
8/6/2013 - 8:28 PM      DNS SERV =
8/6/2013 - 8:28 PM    etwork Connection
8/6/2013 - 8:28 PM      Index = 11
8/6/2013 - 8:28 PM    327-A464-0EABE459965D}
8/6/2013 - 8:28 PM    5.255.192
8/6/2013 - 8:28 PM      MAC = 60:a4:4c:b0:56:f3
8/6/2013 - 8:28 PM    5.255.255.255
8/6/2013 - 8:28 PM    255.255.255.255
8/6/2013 - 8:28 PM    ue Aug 06 20:27:23 2013
8/6/2013 - 8:28 PM    ri Aug 09 20:27:23 2013
8/6/2013 - 8:28 PM    8/255.255.255.255
8/6/2013 - 8:28 PM    Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
8/6/2013 - 8:28 PM    Starting Management Interface...
8/6/2013 - 8:28 PM    Checking...
8/6/2013 - 8:30 PM    Retrieve statistics...
8/6/2013 - 8:30 PM    Connected.
The TUN/TAP adapter does not come up. Can you please try a Winsock and TCP/IP stack reset, and finally a system reboot, according to the instructions here:
https://airvpn.org/topic/8320-solved-connects-but-ip-doesnt-change-on-windows-server-essentials-2012/?do=findComment&comment=8321
EDIT NOTE FROM SUPPORT: RagingElephant managed to detect and solve the problem, it was caused by PeerBlock
